Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Washer stopped during spin cycle
Whirlpool top load stacked washer stopped mid spin cycle and the water has not drained. Have been able to get it started back at the beginning of spin cycle (twice), but it gets stuck at the same spot between spin and rinse. Nothing seems to be stuck, but not sure where to look. The water makes it difficult to troubleshoot. Help!
  • 327 Answers
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Thanks
Posted on Jun 04, 2010
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Water will not go out
does it stop mid cycle? do you hear a hum, like its trying to drain but can't? Something may be stuck in the pump. It may also be the lidswitch if it is just stopping and not doing anything when it's supposed to drain.
Nov 08, 2010 | Whirlpool LTE6234D Top Load Stacked...
Washer fills during spin cycle
Replace the timer, you can find the product name model and serial number on two place. Either the back panel or on the lid underneath. Please rate if this helped thank you
Feb 12, 2009 | Whirlpool LTE5243D Top Load Stacked...
Washer stops in mid cycle
This is probably normal. There is a natural pause between agitating and draining, and again between draining and spinning. Hope this helps!
Feb 04, 2009 | Whirlpool LTE5243D Top Load Stacked...
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Oct 18, 2008 | Whirlpool LSR5132PQ Top Load Washer
Stoping before draining
make sure you have cold water unit rinse in cold water only,,even if it says warm...check the inlet vavle it should be humming in rines the cold sideof valve,,if not humming replace,,if working ok replace lid switch
Jul 30, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
380 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
