Question about Panasonic NV-GS150 Mini DV Digital Camcorder
PANASONIC NV-GS140 LCD screen broken
The screen is broken. I need a new one, cheap!!
vac8
  • 15 Answers
SOURCE: Panasonic NV-GS60 with horizontal lines appear on screen
Clean the heads(use the specified cleaning tape sparingly).
Change tape. Using Panasonic video tape? It sounds like no. You might get by with Sony... Try Panasonic.
The tapes are different thickness, durability and therefore suitability for cameras. Try to get ME -type tape( metal evaporated) instead of MP( metal particle) as the particles tend to flake off more readily. The blue often means no signal(video) was recorded in that space(on the tape). Let me know it it helps.
vac8
Posted on Jan 14, 2009
SOURCE: LCD broken Panasonic PV-Gs 320
Hey, all.
I also have this problem, but have a little more to add:
Here is a website that carries the lcd screen: http://www.pasc.panasonic.com/Epartr/PartsList.asp
I think that its the following part number:
L5BDDYH00022 LCD DISPLAY (MONITOR) 87.56
$87.56 sucks, but it could be worse. Problem is now, I'm not sure how to replace it without taking the entire camera apart.
Let me know if someone does this successfully.
Thanks!
EAL
Posted on Jan 24, 2009
zohail
  • 1223 Answers
SOURCE: Panasonic lcd ribbon cable
u can order them email them the part discription they can send u one if u go to panasonic they will ask for a price of new cam
link for order or try ebay for this it iwll help
http://www.partmaster.co.uk/cgi-bin/search.pl?query=Panasonic%20NVGS35&pg=3&path=98821,112403:98828&brand=Panasonic&model=NVGS35&part=
you first need to strip both the camcorder and the lcd door to get the actual cable out. It might just push into a terminal connector at either end or it might be soldered to the circuit board at either end. Once you find that out then you could probably get a piece of ribbon cable to replace it from an electronic parts supplier. You also have the option (if you have a decent soldering iron) to just use standard multicore cable and solder a colour-coded set to replace the ribbon. If the board uses connectors you would have to unsolder that too and then make up your own cable loom using very thin cable.
It's a delicate operation requiring patience and a BIG magnifying glass ..I had to fix the ribbon cable when I blew up my LCD monitor...the terminals are really tiny but it can be done!!
plsw rate me FIXYA if i helped
Posted on Mar 28, 2009
electronios
  • 126 Answers
SOURCE: panasonic sdr-s7 camcorder broken lcd panel
how can i help you?better ask the nearest panasonic service
Posted on Oct 14, 2009
electronios
  • 126 Answers
SOURCE: panasonic camcorder nv-gs35 ribbon cable damaged
ASK NEAREST PANASONIC SERVICE
Posted on Nov 19, 2009
Lcd screen monitor
its may be LCD flex damage
http://www.ebay.com.au/itm/NEW-LCD-Flex-Cable-Repair-Parts-Panasonic-NV-MD10000-MD10000-F0081-/151132846898?pt=UK_Replacement_Parts_Digital_Camera_Parts&hash=item2330383b32
Mar 14, 2014 | Panasonic NV-MD10000 Camcorder
I have a nv-gs140 with a usb cable. I can transfer pictures to my pc - but I don't know how to transfer the video tape to the pc?
You must connect using a firewire cable to the camera firewire port and computer. Firewire may also be called iLink or IEEE1394a.
Open Windows Movie Maker for PCs or iMovie using a Mac.
Any other video editing application will also work.
May 15, 2011 | Panasonic NV-GS150 Mini DV Digital...
Lost camera's (panasonic nv-gs140) original Cd , have new computer and need to install it to transfer video clips. Where can I download appropriate software?
You do not need the CD that came along with the camera to access the video clips, connect the camera to the USB port in your computer using the cable that came along with the package. You can download the additional editing utilities that was available on the CD from the following link
http://panasonic.jp/support/global/cs/info/vista.html
Mar 02, 2011 | Cameras
The glass screen on my Sony NVU94T is broken. Sony in Toronto advise that they can import a screen from the USA and with labour....it costs more than a new GPS. Where can I obtain a screen from ...cheap...
Sorry to interrupt, Do Not buy that lcd screen as it belongs to NV-U73T and your unit model number is NV-U94T that might have different lcd screen, make sure it is exactly same lcd screen that has been utilized in your unit model.
Please be aware of that both models might have different lcd screens.
Thanks.
Aug 17, 2010 | Sony NV-U73T GPS Receiver
I have panasonic PV-GS32 camcorder. The lcd was working fine for 2-3 years but suddenly stopped working. If i flip open the LCD screen then the viewpoint also goes blank. Is there some setting that needs...
It does look as if your LCD screen is dead, they are not cheap to replace, but you could pop it in to your local Camera shop, they will mostly be glad to help you.
Jun 16, 2010 | Panasonic NV-GS17 Mini DV Digital...
My dvc NV-GS25 lcd screen is not working
Common problem with this model, flat cable that connects lcd assembly to the main board is broken, replacement part comes as hinge assembly witch includes cable and the hinge.
Nov 11, 2009 | Panasonic NV-GS25 Mini DV Digital...
LCD screen goes blank on my Panasonic NV-GS17 camcorder
you need to replace your camara's flex cable (LCD HINGES-technical name).
Jun 02, 2009 | Panasonic NV-GS17 Mini DV Digital...
Panasonic NV-GS150 Mini DV Digital Camcorder Logo
56 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
