Question about Cameras
I have a Minolta 5D Maxxum SLR. It turns off when I press the shutter button. If I press the button a second time (without turning the samera back on) I get an 'Err' message in the view finder. Is this a problem worth repairing?
  • 1 more comment
  • hkunnanz Apr 09, 2008
    Thanks for the advice.
    I've removed the card and get a "Card" error instead. I've removed the Lens and get a "No Lens" error in stead. When I turn off the check for Lens and check for Card setting I get the original issue where the camera turns off.
    When the problem first occurred I bought a new battery pack thinking it was defective, but there was no change.
    This model doesn't have the video capability so I can't check that one. I have noticed that the shutter makes the normal clicking noise when I first turn the camera on - is that a sign that the shutter is still working?
    Any other thoughts?
    Nope ... didn't drop it. The camera initially stopped working when I was in Yosemite ... took one picture and then the next wouldn't work.
    I tried to suggestion of shocking the camera - I look the lens, card and battery pack out and tapped it twice. Unfortunately there's no change.
    I also tested the zoom and it does work.
    Sounds like it's a shutter issue and I'll have to take it in. The estimate I've gotten is about $300 ... does that seem reasonable?
    I'm not sure if I did the rating right (first time using FixYa), but thanks pauldonp and coolguy for the suggestion and machine for all the info.
    Master:
  • 788 Answers
Konica/Minolta left the camera business in 2006, Sony is handling repairs right now. There was a recall (http://www.dcviews.com/press/Minolta-Service-Advisory.htm) for a similar but different problem.
My guess is a problem with the electronics, if you could find a 5d with broken optics or a bare board you could replace it. Sending the camera to Sony is probably going to cost a pretty penny.
The manual is available here: http://ca.konicaminolta.com/support/manuals/digital_cameras/dslr/dynax5d_maxxum5d/2186_OM_5D_E_.pdf
Not much info in there for troubleshooting, the best advice the manual has is to remove the battery for a while and trying again.
Pick your continent on this page: http://ca.konicaminolta.com/support/contact/sonylist/index.html to contact Sony if you want to try that route.
Does the error still come up without a flash card in the body? Remove all accessories and see if it goes away.
Does the camera still record video? If so might be a shutter problem or power supply problem to the shutter.
Posted on Apr 09, 2008
  • Dean Joly
    Dean Joly Apr 09, 2008
    If the noise is normal then it might be ok. My money is on an electronics fault. Not much hope I'm afraid.
    Genius:
  • 3,422 Answers
try this out it worked for most of them who had a similar problem like urs:
Gently tap it twice at the end of the camera to ur plam and it will work again.
Goodluck,
Don't forget to rate me as fixya..
just tap it very lightly against the bottom of the camera holding it upright.
If you still face the problem then i suggest you to get it repaired
Goodluck,
  • Priya darshan Apr 09, 2008
    I am sorry please ignore my double posts and also please rate the best solution.I believe that pauldonp's solution seems to be more appropriate.
    No probs.Have a nice day..
    Scholar:
  • 133 Answers
Ya this is the problem with your camara
you didn't tell that camera droped down from hands ? ? ?
and may be its because of any shock while that time
my suggestion is to just go to nearest service center and please dont try to repair on your own
ya but if you have warrenty do to service center and explain them situation
if minor damage is there they will do it in short time
otherwise my suggestion is to buy new one ( if they tell about more damage )
  • 4,102 Answers
Does it come up with error code if so what is the exact error code
  • 3 more comments
  • paul proctor Apr 09, 2008
    Hi usually the problem relates to their being a fault with the shutter or the lense in your case its more than likely the lense it could be that pressure has been put on the lense causing the error or if the camera has been put down whilst on and knocking the lense can cause havoc with the camera.
    Have you tried removing the battery for a while then give it another try.
    You know before you push the shutter button does the zoom feature work ok if the zoom is fine then it will be a fault with the shutter.
    Its worth trying this remove battery and mem card if it has one then shock the camera into the palm of your other hand dont do it to hard but doing this will remove any grit or dust preventing the shutter from working properly as the chances are this is all your problem is going to be so give this a go then get back to me ok
    Thanks coolguy were all along the same lines though,
    if shocking into the palm of your hand dont work then the chances are the shutter has become jammed witch would be the reason you would get the message has the camera been anywhere where it can get damp or has it been dropped at all as the problem is more likley the shutter if you can you the zoom feature then the lense wont be the problem so i would go towards the shutter.
    Also the price of repair could cost more than the camera to buy so just be warned in case you do take it to repair shop.
    If you were to remove cases yourself be warned it is difficult and i dont advise you to do this if you dont have a clue what you are doing or if you have had no experiance in this sort of equipment.
    Let me know how you get on ok
    Have you tried my way as sometimes this can remedy the problem failing that then the chances are the board will need replacing this is expensive and difficult to do if you are unsure of this work.
    from your last post it does sound like the board itself has failed and the chance of getting the board repaired is slim the best option would be replace and try selling yours for spares as alot of people would be glad of spares from your camera like battery etc, keep mem card as you can format this to work in most digital devices
    they say $300 but it could easily go over that depending on the problem but you could get them to look at it first then if it is going to cost more then trade it in for a new one if they make you an offer on your the chances are you get repair done and depending on age of unit you could face more problems but its worth a look
    before you give up try hitting the camera into the palm of your hand but do it quiet firm not a gentle tap do it quiet hard as this usually does the trick if not what have you go to lose you cant really do any more damage i dont mean hit it as hard as you can but give it another try.
    As for the rating you should wait untill you have tried all experts answers before rating i know its a bit confusing at first but thanks for using the site
I just bought a Minolta maxxum QTsi from a lady and it had no manual with it, I can't figure out how to load the film. Can you take me step by step on how to load the film and how the camera works when...
Hi, I've found the instruction manual online for you, http://www.mediacollege.com/equipment/manual/konica-minolta/camera/maxxum-qtsi.pdf that way you have it for future reference. For loading film you open up the back of the camera and make sure that the end of the roll of film is aligned with a red mark and then you close the back. For taking pictures you press the shutter button half way in order for it to focus, when the image you want is framed you press the shutter button the entire way and it'll take the photo.
May 13, 2011 | Minolta Maxxum QTsi 35mm SLR Camera
I have a Konica Minolta Maxuum 4, how do you turn off the date on the camera? I am in a film class and my teacher told me I need to figure out how to turn it off for class purposes.
Press the DATE button on the back of the camera to cycle through date, time, and none (just dashes). Press the shutter release button to set the format.
If you need a manual, you can download one at
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_4/2164_E_B.pdf
Feb 02, 2011 | Konica Minolta Maxxum 4 / Dynax 4 QD 35mm...
No images show up on screen after shutter releases
If the images are recorded on the card but not shown immediatly after the shutter release, press MENU, go with the control dial to the recording menu (the one symbolised with a camera) and press AF, the center knob.
On page 1, the third item controls the instant playback, it can be set to OFF, probably your setup, 2, 5 or 10 seconds.
Oct 21, 2009 | Konica Minolta Dynax 5D / Maxxum 5D Body...
Need to set self timer
Press the MENU button, select "Drive Mode," then select the self-timer (one-handed clock). To start the self-timer, press the shutter release button.
Sep 06, 2009 | Konica Minolta Dynax 5D / Maxxum 5D Body...
Minolta Maxxum 5000
I had the same problem with a maxxum 7000. Traced it to a bit of corrosion in the battery pack. It let just enough power through to run the computer, but upon releasing the shutter, it shut off.
You might check that. corrosion can be cleaned with vinegar.
-John
Oct 07, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta StSi Maxxum
It's the shutter speed. I copied this out of the manual :
The number 60, or 125, displayed in the
data panel stands for 1/60th or 1/125th of a
second.
• Usable apertures will depend on the aperture range of the lens you are using. • The seconds indicator appears in the
viewfinder and data panel if the shutter
speed is one second or longer.
Albeit copy and paste made it fit weird into here.
May 27, 2008 | Minolta Maxxum STsi QD 35mm SLR Camera
Bracketing in Maxxum 5D
Hey arnelsartwor,
To set both exposure and flash bracketing you need to press the drive mode button, and then use the up/down arrows to select bracketing and then use the right/left arrows to highlight the drive mode option and then press the center button to select the desired drive mode. These instructions are on page 50 of your user manual. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 23, 2008 | Konica Minolta Dynax 5D / Maxxum 5D...
Shutter blades out on Minolta Maxxum 7000
It is possible to fit them back since they are flexible. It does require a gentle touch, with a lot of patience. I use angled tweezers for this task.
Replacement parts are no longer available. Used cameras can be found on ebay and the like.
Feb 13, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Konica Minolta Dynax 5D/Maxxum 5D turns itself off after first shoot
It sounds like that's the first black frame problem that is a fairly common defect with the cameras, so much so that Sony is repairing it for free, for more info, see:
http://ca.konicaminolta.com/information/20070202/01_en.html
then go to:
http://eservice.sony.com/webrma/web/index.do to set up for service.
Oct 18, 2007 | Konica Minolta Dynax 5D / Maxxum 5D...
Problem with "P mode"?
Press 'mode' button and simultaneously turn scroll button situated in front of the shutter release button to move from P to other settings.
Oct 26, 2006 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Cameras Logo
64 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
