Question about Sharp AR-507 Copier
We have a sharp Ar-507 copier. We replace the fuser unit and we now get an error code F2-31. How do we fix it?
  • 47 Answers
Try the finisher area, the f code refers to finisher, otherwise call sharp
Posted on Jun 04, 2010
Is there a reset code for a Sharp AR-507 copier, error H2-00?
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
May 04, 2010 | Sharp AR-507 Copier
Error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
Dec 16, 2009 | Sharp AR-M455N Copier
Error code h5-01 appeared on my sharpmar-507
Check the fuser unit and make sure its installed correctly.
Dec 02, 2009 | Sharp AR-507 Copier
I have sharp ar-287 error ha-04. How to fix?
this sounds like you have a jam in your fuser unit.To remove this jam open the door at the left hand side,you should see a green lever to the back end lift up and take paper out,after doing this you then have to reset this error code.To enter service mode press P interupt C interupt key in 14 press start key then press CA.Photocopier should reboot if this does work then you need to get your service engineer out
Sep 15, 2009 | Sharp AR-507 Copier
I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
May 08, 2009 | Sharp AR-507 Copier
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
Sharp Ar-507
An F2 code depending on the secondary code is related to the toner or drum.
F2 00 Toner control sensor open 22 LCC 24v power abnormality
02 Toner motor connector unconnected 50 Non supported option connection (Desk Unit)
31 Process control trouble (Drum surface reflection) 51 Non supported option connection (LCC Unit)
32 Process control trouble (Drum Mark) U7 00 RIC communication trouble
37 Drum marking sensor gain adjustment error U9 00 Operation control communication trouble (ICU)
39 Process thermistor breakdown
Jan 02, 2008 | Sharp AR-507 Copier
H2 Error
You have a thermistor open. That means that the device that reads the temperature in the fusing unit, has broken. You will need to replace the fusing unit to fix this problem. You could try a Sim 14 reset. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
Dec 31, 2007 | Sharp AR-5320 Black and White Copier
H4-00 Error Code for Sharp AR-168D
Your Tech is correct in replacing the Unit.
If the Fuser is not reaching the correct Temp it will give the H4-00 Code
The time and money it takes to repair the unit is greater than replacing.
Oredering all the parts for the unit takes longer then ordering the unit.
The only thing a tech can do is clean the Thermistor, reset with sim 14..
If that works, it might work for a hour, might work for days?
I personally carry this Fuser Unit in my car stock as this happens frequently..
Good luck
Oct 22, 2007 | Sharp AR-235 Copier
Sharp AR-507 Copier Logo
189 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
