Question about LG Shine CU720 Cellular Phone
T9 messaging setting
How do I set messaging to T9
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 95 Answers
Go to messages, select new message then select input method to tap or t9. Alternatively when on new message mode just select the harsh button till the t9 comes on
Posted on Jun 05, 2010
Testimonial: "Thank you helpful"
Dictioary i need to turn off
You can go to message settings or the options in message and look for dictionary or T9 and turn T9 off.
If you want the alarm to ring each morning you can go to clock or alarm and set a particular time and set the repetition to everyday or weekly as you desire. You can also cancel the alarm simply by deleting or removing the alarm time that you have set which will be given in the options
Sep 17, 2012 | Samsung Galaxy Note - 16gb - Black...
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
Is it my imagination or is it true my new env3 does not support t9 or preemptive text?
From the front screen and keyboard:
(i.e. with the phone closed)
While entering a message, hit the main "OK" button for "Options".
Item #2 in this menu is "Entry Mode."
T9 is on this list.
Operating from the internal LCD screen and QWERTY keyboard:
Hit OK to get to main menu
Select "Messages"
Once in that menu, the left option key beneath the main LCD screen is "Settings" - hit that
On that menu, item #2 is "Entry Mode" where you can select T9
I have read of difficulties getting the enV3 T9 mode to add new "user" words that you might want to program into the T9 dictionary, so don't be surprised if you have trouble with that.
Oct 03, 2009 | LG enV3 VX9200 Cell Phone
How to change it to T9
when txting go to options while you have a message open and it should show a list of txt inputs
Aug 01, 2009 | Motorola Mobility RAZR V3
Krzr won't stay on t9 text
open a new text message go to "options" select "Text Setup" and change the primary text: to iTap English instead of TAP English this will fix ir :]
Mar 07, 2009 | Motorola Mobility KRZR K1m Cellular Phone
Cant set T9 as the default entry method on LG cu920
yes you can set T9 as default on the Vu just go to the new message touch options and touch text entry mode and touch T9 Abc and that will become your default
Dec 24, 2008 | LG Vu CU920 Cellular Phone
Predictive Text
To get predictive text on or off on the LG Shine go to:
>Menu
>Messaging
>New Message
>Text
>Options
>T9 languages
>T9 on/off
Sep 01, 2008 | LG Shine KE970 Cellular Phone
Text Messaging
You need to go to options and take the setting of T9 out. T9 is the setting that will spell out words for you as you go through typing the word.
Aug 28, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Changing language so i can text message
open a creat new tex message options and look for somethin like edit T9 dictionary, input language input type failing this come out of the thx message to messages and find settings and repeat above
Jun 17, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Predictive text on a motorola w375
Go to Messages -->Create-->SMS/EMS-->the message multiline appears . Now press the round button in the centre of directional keys, this will take you to message editor. Now go to Entry set up . In the Primary setup select TAP english and in the secondary set up select TAP English.
Oct 24, 2007 | Motorola Mobility W375 Cellular Phone
LG Shine CU720 Cellular Phone Logo
163 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
