Question about Frigidaire FAC124 wall/Window Air Conditioner
Through the wall vs. window installation
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model..do these mount as through the wall as well ? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
  • Anonymous May 26, 2008
    size of hole for my aircondtioner is 18 x26 baught the ac a long time ago. can only find window ac. Old ac is 220 eer 8.2 22.5000 btu please help
  • Anonymous Jul 11, 2008
    where do I buy an air conditioner for a wall mount 18x26"?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Posted on Apr 15, 2008
My exist. unit is a very old sears coldspot through the wall mounted in a 12x18 in.exact sleeve. Can i remove unit and replace with FRA052XT7 ?. Exist sleve is vented on both sides & back.This is...
Get rid of the old stuff,too big to be used
Newer unit can't be inside the old sleeve as you call it
Just install the new unit how you see fit, to seal
it up
5000BTU is too small
A 7,200,8,000 or 10,000 BTU is the same size & about
the same price.
Jul 18, 2011 | Frigidaire FRA052XT7 Thru-Wall/Window Air...
Hi, My husband and I recently purchased a couple thru wall/window air conditioners. We are planning on putting them in our windows, but they did not come with any mounting kits. We are having a hard...
Hello, you can purchase mounting kits at a local heating and cooling supply store. Here is a link to a online store that carries window kits http://www.apwagner.com/index.php?main_page=index&cPath=10_48
May 26, 2011 | Toyotomi Heating & Cooling
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
Using a Wall Air Condtioner in Window
It is called a mounting kit and can be purchased at Home Depot, Lowes, or an appliance store.
Sep 29, 2008 | Frigidaire FAC124 wall/Window Air...
Putting a window air conditioner in the wall
I dont see a problem with these working in the wall, however you will probably need to install a condensate line to drain away the water that will be left from condensation. These items may be purchased from any hardware store.
Hope this helps Ya please rate me
Jun 22, 2008 | Heating & Cooling
Is this the right unit? Can it be used with a sleeve?
If a sleeve came with it then it should be used unless you are replacing a unit and the existing sleeve is properly mounted. Then sleeve should have a slight backward angle so that condensation does not drain into the living space.
Jun 12, 2008 | Heating & Cooling
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
Can a window air conditioner fit in an exhisting wall mount?
I bought window AC (5000 btu) that fit 17 in. at home depot. made by Zenith. Keep in mind of your room size.
Good luck.
Jun 10, 2008 | Frigidaire FAC124 wall/Window Air...
Frigidaire FAC124 wall/Window Air Conditioner Logo
905 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
