Question about RCA F36645 TV
Service convergence alignment procedure
I've got an RCA 52in rear projection TV model # P52755ST.I need to find info on how to perfom a service convergence alignment on the color grids.I'm not finding any information on this particular model.Can you please advise.
    Scholar:
  • 121 Answers
Most non-LCD and plasma TVs have to be manually adjusted with special tools that are used to adjust the internal comparator circuits that align your image. It could be a cheap repair job at a shop.
Posted on Jun 04, 2010
  • Doug
    Doug Jun 04, 2010
    Would you rather I describe the entirety of a standard television so you can figure it out by yourself? Would you like to take an engineering course yourself and specialize in home electronics? Or would you rather call the manufacturer of the set so they could tell you exactly what to do, if you can even do anything without, as I said, the specific tools needed to make those adjustments.
    Or maybe you could just take it to a shop and pay hardly anything to have them adjust it for you.
60 ic7410
Just visit this link It has details about convergence procedure to rear projection television. Convergence adjustment procedure to most brands PTVs will be similar. Pull up older posts there, by its left side bar. http://electronicshelponline.blogspot.com/
May 30, 2013 | RCA P60920BL 60" Rear Projection...
How do you align the 3 bulbs on a 46" rear
you need a service remote and a cross hatch and pattern generator. you may also need the service manual for the set in question because this will guide you in the proper way to re-calibrate the tv to factory specs. the above list items are very expensive unless you have a repair shop these won't do you much good for a one or two time thing. your best bet is to take to an authorized service center or a qualified repair shop that can re-calibrate the tv for you.
Sep 04, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
I have a RCA 52in TV & the picture is arched. Model # is D52W15.
Problem description indicates a convergence alignment issue. Convergence circuirty needs to me replaced.
Jan 19, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cant find convergence on menu screen
The HD61LPW42 is a RCA DLP which doesnt have convergence. If the convergence is out of alignment you have a three CRT TV such as the D52W19, HD52W59 RCA Check the model number from the rear tag and let me know what the model number is.
Nov 21, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
Rca 52in rear projection hdtv red, blue, and green lines n double
tHIS is a convergence problem.. first question if you go into the customer setup menu. is the convergence option listed? If you have not got that option i suggest you read "the fl231 problem in the tips and trick section of this website. this can be a simple inexpensive repair..if you do have the convergence option then it can be one of three diffrent boards convergence power, convergence amp or small signal board. and will need further trouble shooting
Apr 04, 2009 | RCA Televison & Video
Convergence problem
If the convergence is out on that set you most likely do not need to make an adjustment the circuit will need to be repaired. There is a stk on the convergence amp board that needs to be replaced. A good tv shop will run you somewhere between $300-$500 to do the repair
Oct 28, 2008 | RCA P56923BL 56" Rear Projection...
Need the codes to enter the service menu
First, you will need to fix the convergence problem by replacing
the convergence IC's,then activate auto focus and last,if necessary, enter the servicer mode................T.
Nov 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
Perfect Focus 2
Use a site like servicemanuals.com and get the service literature for your make/model.Do NOT perform factory reset procedure-that is reserved for when certain parts are changed.You will need the access sequence,adjust info and add to memory step for servicer convergence.Keep in mind--you may have defective convergence IC's.If so,you will have difficulty w/alignment.Use OEM or better IC's no generics!! They won't hold up.
Sep 27, 2007 | Samsung HCN5527W 55" Rear Projection...
RCA F36645 TV Logo
89 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
