Question about kawasaki 2010 Gravely Zt 42 Xl Zero Turn Mower Kawasaki ()
Engine dies when Blade is engaged
I have a Gravely 52" cut 0 turn mower, it has a 21 HP Kawasaki engine, It develop a problem recently in that whenever the blade is engage the engine cuts out and he driver is still sitting in the seat. what could be the cause of this?
I notice that the fuel filter is not filling up!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
It sounds like the seat safety switch is the problem. Tilt up the seat and make sure the plug to the seat switch isn't loose or off completely, and that the switch is firmly mounted. If everything seems ok, remove the switch and test it with a multimeter. The circuit between the switch terminals should close when you press in the button. If not, replace it. Good luck!
Posted on Jun 04, 2010
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
23 hp kawasaki
Check the breather in the filler cap. slaken it off when it starts to die, if it picks up again replace the cap.
Jun 07, 2013 | Garden
Gravely model 992005 runs fine untill moving
sounds like there is still a passage that is still dirty in the carb or the float level is off
Apr 22, 2012 | kawasaki Garden
How to change the clutch on a gravely ZTR 260z. What keeps the clutch from spinning around on the engine shaft? A diagram of the clutch assembly would help. Instruction on removing and reinstalling might...
There is an "anchor" that bolts to the chassis, and it has a rod-like part that sticks up to engage a notch in the PTO clutch to keep it from spinning. Look here -- there are parts diagrams for your mower (find the right model number) that will help a lot. Good luck!
Jul 07, 2010 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Apr 18, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
What would cause my craftsman zero turn to die when i engage the blades?
First, sort out between two possibilities: 1. The safety system is killing the engine -- for example, if the seat switch is faulty or misadjusted, the engine ignition is killed when you activate the blade engagement switch. 2. The blades, spindles, or belts are binding or stuck, which would "drag" the engine to a stop. I suggest you remove the belt that drives the mower from the engine. If the engine still dies when you engage the blade switch, it's problem #1. Check all connections, and check the seat switch with an ohmmeter. If the engine does not die, then you have mechanical drag. With engine off and the belts taken off, turn each spindle to find out if one is frozen or binding. Good luck!
Apr 05, 2010 | Craftsman 21 HP 42 in. Zero Turn Tractor...
kawasaki 2010 Gravely Zt 42 Xl Zero Turn Mower Kawasaki () Logo
1,118 people viewed this question
Top kawasaki Garden Experts
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
dannydoesita
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
