Question about Moen & One Handle Tub & Shower Faucet
Leaks again replaced 4 months ago and leaks again #88431
    Scholar:
  • 81 Answers
This is almost always caused by debris in the plumbing from the pipes or the water heater.
Sometimes it is caused by a defective OEM cartridge. Always buy genuine Moen parts.
Remove and inspect the cartridge. While it is out, briefly turn the water to the valve back on to insure the valve is free of particles and then reinstall. If the drip persists you will need to replace the cartridge again. Always flush the valve before installing new parts.
Posted on Jun 04, 2010
My truck builds air 4 or 5 times in a row on its own. Then all the sudden it stops and wont. If i put it in nutral and rev it up real high it will start building air again. What is causing this?
Sounds like your Unloader is hanging up. What type truck and year?
1 check air line to govenor make sure no leak.
2 Check dis-charge hose or pipe.
3 Check to make sure air drier pop off valve is not leaking
4 The unloader valve in compressors become gummed up and o-ring break and cause valve to hang up in open position which prevents it from building air.
Good luck
Jan 31, 2016 | Cars & Trucks
P0302 #2 cyclider misfire
Sounds like the pintle in the #2injector is not properly seated allowing fuel to drip into that cylinder when the engine is off .
Dec 10, 2012 | 2000 Mazda Millenia
What could be wrong with my 99 Mazda Protege now? 5 months ago it overheated, replace alternator and belt, now battery wont hold charge and is overheating again, and loosing water coolant.
For a coolant leak you need to check all the hoses and fittings by radiator, heater core, expansion tank for leaks and/or integrity. Also make sure that your water pump is not leaking along with radiator cap and thermostat body. Overheat condition has no effect on battery - if it does not hld charge it is because it is chemically worn out and needs replacement. Until you correct water loss, have extra water in car at all times and run your heater full blast - windows open!!!!
Sep 05, 2017 | 1999 Mazda Protege
I'm hearing a grinding sound underneath my suv when i press on the brakes. i replaced my brakes about 4 months ago
If You are hearing a grinding sound when you press on your brakes it probably has something to do with the brakes again so I would take it back to the place that replaced them 4mo ago and have them fix it cause they should be responsible for your brakes if you just paid them to replace them 4mo ago
Mar 21, 2012 | Kia Sorento LX Cars & Trucks
2000 chevy venture overheating problems
Sounds like you still have a cooling system leak issue like a cracked cylinder head.
Mar 15, 2017 | 2000 Chevrolet Venture
I have a Kenmore 80 series about 4 years old and it is leaking. Had a repair man over 3 months ago and it did not leak. However, I see my baseboard behind the washer pulling away and ran a small load...
check to make sure the drain hose is all the way in the drain pipe in your wall. there should be a strap, or tie wrap holding it in place to keep the water pressure from pushing the pipe out of the drain during the drain cycle. if not, the water pressure will cause the drain hose to rise up and allow water to leak down the wall. use a flashlight. you should be able to see a trail of water residue leaking down the wall. slide the washer out a bit and run it. see if the water is coming from the wall, or leaking out of the washer itself. let me know and we can go from there.
Nov 20, 2010 | Kenmore 24902 Top Load Washer
2.3l ranger keeps overheating, been through two radiators already.
Hello Ranger Joe, eight months and two radiators is very uncommon. Question, Have you visually confirmed the leak in the radiators or is the leak near the hose connections? Replacing the radiator, cap, water pump, & the thermostat leaves only two others, the hoses and the engine block/heads. Far fitched will be something or somebody poking holes in the radiator.
Nov 07, 2008 | 2003 Ford Ranger Regular Cab
Moen & One Handle Tub & Shower Faucet  Logo
185 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
