Question about Citizen CI-500e Matrix Printer
Citizen CI 500e displaying AL83: HD Short - Citizen CI-500e Matrix Printer
How do i get acu edit for my macbook. i have the janome 500E
contact Janome they might have the proper software you need .
Apr 12, 2016 | Janome Sewing Machines
I have a suzuki gs 500e 1990. when i td start the
Sounds like your starter relay. Follow the live cable from your battery and you should come across a relay with the wire in and a wire out. Turn your ignition on and short across the 2 terminals with a screwdriver and see if it tries to start. CAUTION: Only do this for a short time until it tries to fire or starts up and do not touch the frame with the screwdriver. If it tries to fire up or even starts, then replace this relay.
Oct 19, 2014 | Motorcycles
Citizen eco drive watch doesn't work
My Citizen Red Arrow wristwatch which I purchased last Christmas has a blank display and won't reset . Any ideas would be appreciated
Nov 07, 2009 | Citizen Eco-Drive Modern Watch
Say ci intermitent in the display and sometimes stop cooling
The error code should be C1 and this would mean that the return air sensor is either disconnected or faulty. The sensor is clipped onto the fin plates of the evaporator where the air is drawn into the evap.
Oct 28, 2009 | LG Art Cool LA1000PR Air Conditioner
Replace Control panel cover on dishlex dishwasher 500E
If your 500E is the same as my 500E then the controls are electronic touch buttons. The are part of a self adhesive strip and stuck to the front of the door. No screws involved. Only the LED lights are mounted on a circuit board with screws on the back of the plastic front panel. ?????
May 09, 2009 | Dishwashers
Looking for manual for Vulcan Dishlex 500e dishwasher
Probably fatigued wiring from the chassis to the door where it bends every time you open and close the door. On my 500E, I took the sheet metal door skin off and found a couple of burned spots on the wires inside a clear plastic strain relief.
Apr 11, 2009 | Dishwashers
Cant se time Citizen 8988-q02047 HSB wristwatch
In the time mode, press the upper right button for 2 seconds and the time display will flash. Then press the same button untill the entire time will flash, or both hour and minutes flash at same time. When the hour and minutes flash at same time, this adjust mode is the adjusting of the analog left display (A1). Now, press the lower button for adjusting de hour shown at the digital display that shows the same hour at analog display. This method is to adjusting the 8982 that is the "father" of 8988. Like a Citizen collector, and don´t know any website that you can view the setting instruction of 8988, only the 8982 is disposable here: http://www.citizenwatch.com/downloads/techguides/8982.pdf
Nov 20, 2008 | Citizen Watches
Citizen CI-500e Matrix Printer Logo
90 people viewed this question
Top Citizen Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
