Question about SunBlade 1500 (A43UAB1-9AB-D512AY) PC Desktop
Are they p4 or p3 - SunBlade 1500 (A43UAB1-9AB-D512AY) PC Desktop
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
The processor Spec for this system is
1 x 1.062GHz UltraSPARC IIIi Cpu
This is a P3 System. Good Luck.
Posted on Jun 04, 2010
I have nothing to plug p3 and p4 into when all on no signal
Sometimes if a VGA cable is not screwed into to both your Tower and your Monitor, it can get loose and thus resulting in no signal.
Another cause of a Monitor Displaying the no signal message would be due to the Graphic Card failing, or possibly due to the Graphic Card not correctly being seated.
Other Thoughts
Usually P3 and P4 refers to a cable on your power supply that needs to be attach to your motherboard to supply extra power.
Note:
If your P4 cable is not plugged in before turning on your computer, this will also result in your Monitor displaying the no signal message.
Keep in mind though, if your computer has not been opened or is not a custom built PC, you should not have to worry about such issues as your P4 cable should in theory be connected. However I guess safely checking won't hurt anyone.
Mar 30, 2015 | Computers & Internet
Tip
How to use a P3 power supply with a P4 or newer motherboard.
Well its fairly simple, You need the following cable to convert your P3 power supply into P4 power supply.
The pictures pretty much explain every thing, this is the only plug that is not present on a P3 power supply. You can make this cable your self by salvaging connectors from non-working power supplies and other computer peripherals. The connections are straight forward just connect both the yellow wires to the single yellow wire and the black wires to the black wires and your done.
on Feb 09, 2010 | Computers & Internet
Does p3 sound cards support in p4 machines
Probably it will not support.But you can downlaod drivers for your p4 from below link:
http://members.driverguide.com
Enter your motherboard model number and search and download from results.
Regards,
Rahul
Jul 15, 2013 | Computers & Internet
My nokia 6500 slide is not detected on my p3 processor computer
hi ,
on your p3 laptop/desktop go to the device manager and update usb drives (DO NOT CONNECT your phone). Before that uninstall pc suite. Then reinstall again.And follow the on screen guide how to connect the phone.
Apr 11, 2009 | Nokia 6500 Slide Cellular Phone
UPGRADING P 3 PC
THE SE440BX2 MOTHER BOARD CAN SUPPORT P3,P2 PROCESSORS(P3 850 MHZ)....,BUT NOT P4 AND HIGHER VERSIONS...THIS MOTHER BOARD SUPPORTS UPTO 768 MB OF RAM,NOT MORE THAN THIS...
Aug 19, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
Using an extra connected motherboard as a backplane
BASED ON INFO FURNISHED 'NO',you need the BIOS to activate board systems
Jun 21, 2008 | Computers & Internet
Changing a P3 motherboard for a P4 motherboard
P-4 boards want at least a 300w power supply, P3 were not so picky. Next, swapping boards is easy but remember to stay in the same form factor, (the relative size length and width) a server board won't fit in a micro case.
The location of the stand offs (where the screw holes are) may have to be changed. P4 boards have 20 pin or 24 pin power connectors so the appropriate power supply will need to be ordered. If you are running a lot of peripherals a 450w ps at least.
Now you decide if you want a board with on board, video,nic,sound,etc.
then you have to order the supported processor/heatsink and fan/thermal grease/supported Ram etc.
I've been doing this for years so i probably left out a lot.
Lately because of costs I've resorted to backward building.
I decided since DDR2 is cheap, find a board that supports that ram in a processor socket I want to use (socket 478-775) etc.
Mar 21, 2008 | Intel Motherboard
Dvd/cd drive problems
I think it is desktop DVD ROM. P3, P4, P5 are power connectors for HDD and DVD.
Upside down the DVDROM. you can see 4 screws there. remove the screws. Open the tray using a small hole in the front panel. You can easily remove the top panel now.
Jul 02, 2017 | Acer AL1716Bbd 17" LCD Monitor
Intel p3 audio driver
hi kumar i need a sound driver for my p3
Feb 05, 2008 | Intel Steinberg Nuendo AudioLink PCI 96...
Replacement
you should be able to use the same HDD, Floppy drive & CDrom drives, You should be able to use the case, if it has a removable plate for the outputs as they will most certainly differ from your original mobo. However you need to check your PSU as the P4 has a requirement for a 4pin 12 volt line which is not present on the older PSUs, however you can get a new PSU and fit it into your case for about £30-£40 Your P4 motherboard is also unlikely to use the same RAM as your P3 so that will need to be replaced. (as it will be incompatible with the new processor)
Oct 08, 2007 | Intel 845GE Motherboard
SunBlade 1500 (A43UAB1-9AB-D512AY) PC Desktop Logo
44 people viewed this question
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
k24674
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
