Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
No power or signs of power
Turned my Kenmore Elite dishwasher on. Next I notice their is no activity. No power at all. Disposal is wired to same circuit breaker and it works. No signs of over heating. Don't think it would be the thermostat. Can anyone help? Spent 1100.00 on machine and no more warranty. Had it for 14mo. Thanks!
  • chrizzoclark Jun 04, 2010
    Does it have any lights on at all? if not try actually plugging another appliance into the socket that the dishwasher is in to be sure there is power even though its on the same circuit as disposal.
  • 30 Answers
Check the power going to the machined,
check the fuse or circuit breaker.
check selector switch or pushbutton switch.
Posted on Jun 04, 2010
We have a Kenmore Elite 630.16304401 dishwasher, lately we are getting small black greasy spots on the plastic dishes, also same spots on the plastic parts in the sump where you clean the filter? We h
A couple of thoughts:
1) It could be a gasket somewhere starting to break down. Check your door seal.
2) Food particles could have gotten caught somewhere in the drain hose, or something, and then turned black with mold and bacteria, then when you wash, they get siphoned back into the dishwasher if the flap which composes the anti-siphon check valve on the drain hose is starting to stick open.
Try putting a cup of bleach in the top rack and run a complete cycle with no other dishes in it. Then, load up some plastic dishes and wash them as normal. See if that helps. If it does, replace your check valve.
Also, insure that your drain hose is looped up above the bottom of your sink to prevent debris from your garbage disposal backing up into your dishwasher.
Good luck and keep us posted!
Oct 22, 2014 | Kenmore Dishwashers
Why kenmore elite dishwasher will not drain?
If it is connected to a disposal remove the drain hose and check for a restricted area in the hose or disposal this is common also check the drain hose for kinks be sure to elevate the hose before the drain area. If the drain hose is clear and the drain is clear then you could have a bad drain pump in the dishwasher.Most problems are a restricted drain or hose
Jul 22, 2014 | Kenmore 24" Built-In Dishwasher with...
Kenmore elite dishwasher is leaking water from diverter
I think you are talking about the air gap on the sink. If so, the drain line to the disposal or drain is plugged or pinched .clean it out and problem solved.
Jan 05, 2014 | Kenmore 24" Built-In Dishwasher with...
Jenn air dishwasher won't fully drain
Your garbage disposal is clogged . Or your hose from your garbage disposal is flowing in the down position
Oct 22, 2012 | Kenmore Elite 45986 Front Load Washer
Kenmore elite dishwasher has no lights or any sign of power. Breaker not flipped, power good....
press back and forth the sani rinse button and high temp button..keep pressing back and forth repeatidly until lights will light up and it resets the system...
Feb 27, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore ELite 21086 Washing Machine
On many dishwashers there are secondary fuses located near the power hook up. Check you owners manual and see if you model is equiped this would be like the reset button on a garbage disposal. If this is not the case look for a loose ground wire often time these piece of equipment will not operate unless there is a ground connection. Lastly, these sudden abrupt failures are often a sign that something is wrong on a larger scale, look into leaks that may cause a short or abuse that has caused the issue.
Dec 01, 2009 | Kenmore Elite 21086
Kenmore Elite model 665.17052400 dishwasher will not drain
Check disposal to see if d/w knock out was removed form disposal. If so check drain hose for kinks or restrictions.
Ie unistally hose from disp and see if d/w will drain into bucket. IF not uninstall d/w and check for kinks.
Jul 18, 2009 | Kenmore 15899 Built-in Dishwasher
Kenmore Elite Not cleaning dishes
You might want to check where the hose from the air gap connects to the disposal there is a plug that has to be removed to allow for the washer to drain.
Mar 15, 2009 | Kenmore 24 in. 17303 Built-in Dishwasher
Dishwasher doesn't drain fully
Hello. Are you using liquid or powdered soap? In some models liquid soap will foam up and the drain motor can't pump out bubbles. Foaming can also happen if you pre-clean your dishes with liquid soap used for washing by hand. If it is foaming, you can poor non-dairy creamer or cooking oil into the bottom of the unit while it is in the wash cycle.
If foaming isn't a problem then the water level switch may be bad, the pump may be not pumping out as quickly as it should or you may need to take the hose off completely to make double sure that there isn't anything in it.
Did you check the air-gap next to your kitchen sink faucet. If you don't have an air-gap it may be hooked up to the garbage disposal and if you don't have a high loop in your drain hose the water can run back into the dishwasher especially if the disposal backs up.
Dec 03, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher will not drain
if you have a garbage disposal make sure to take the plug out.
or the motor sylinoid is burn out.
Jun 12, 2008 | Kenmore Dishwashers
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
223 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
