I have a B&K power amplifier(home not auto). The original two wire power cord is damaged. I want to replace it with a three wire(positive, negative, ground) Originally one wire went to a fuse and the other wire went to a strip of plug-in wire connectors. I purchased a IEC power cord socket and wired it in. Then i pluged it into the all. I blew the fuse coming off the positive line. so i switched them. Blew a fuse again. Any assistance would be greatly appreciated.
    Scholar:
  • 75 Answers
Get an electrical tester (screw driver with live indicator built in) and check which socket on your wall is live, connect the live/phase line to the fuse and the neutral to the other plug-in wire connector. conect earth or ground to any part of the power amp housing (should be conductive). do not connect earth to any part of the circuit board. urs is an amp that is not built to have earth connection on the board. be careful.
Posted on Jun 06, 2010
Protect mode?
You added speakers in parallel which reduced the effective impedance to to a value low enough that your Rockford Fosgate amplifier had to enter protect mode to prevent damage to its output stages.
Jan 22, 2014 | Car Audio & Video
Tip
How To Bi-Amp And Bi-Wire Speakers!
What is the difference between bi-wiring and bi-amping?
Bi-wiring is using the same power source (amplifier) but separately connecting that power source to a woofer and a midrange/tweeter on a speaker.
Bi-amping is using two separate power sources (amplifiers) and connecting one amplifier to a woofer and the other amplifier to a midrange/tweeter on a speaker.
How do I bi-wire?
Your speaker must have two separate positive and negative connections (one set for the woofer and one set for the midrange/tweeter). Connect one wire between the positive terminal on the amplifier/receiver the positive terminal on the speaker. Connect the other wire from the negative terminal on the amplifier/receiver to the corresponding negative terminal on the speaker. Remove the jumper straps connecting the two sets of speaker inputs. Repeat this process for the second set of terminals on the speaker, connecting them to the same positive and negative terminals on the receiver/amplifier. Repeat the steps for each speaker you wish to Bi-Wire, connecting them to the appropriate terminals on your receiver/amplifier.
How do I bi-amp?
Bi-amping is similar to bi-wiring, but involves separate amplifiers: one for the woofer and one for the midrange/tweeter. Passive bi-amping involves a direct hookup between each amplifier and the speaker terminals. True bi-amping involves hooking the preamp to an electronic crossover that replaces the passive crossover network in the speaker. The active crossover then connects to multiple power amplifiers.
on Jul 13, 2010 | Audio Players & Recorders
Need to fix my car sterio system
Start by checking your grou;nd if that does not work take your positive wire and your remote wire on your amplifier make you jumper wire in touch both the positive an remote only in and see if it comes on if it does not then you need to go further and maybe replace amp 6_28_2013_8_57_31_am.jpg
Jun 19, 2013 | Audio Players & Recorders
Power wire arch
the amp fuse should be inline under the hood by the positive battery terminal.
Oct 03, 2009 | Crossfire VR402 Car Audio Amplifier
I'm trying to replace the power cord on the Maytag Atlantis MDE7400AY. originally it has a three prong cord but i need to put on a four prong. in the back of the dryer it seems to only have three...
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Sep 04, 2009 | Dryers
Kicker zx750.1 Amp in Protection Mode (Red LED)
My kicker amp zx1500.1 keep going in protection mode I unhooked the sub speak wires and put the ACR cords back in and it didn't go in protection mode what next
Mar 18, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
My Amplifier keeps blowing fuses.
It probably has shorted output transistors.If it's like many of the Asian amplifiers, the outputs will be larger than the rest of the devices clamped to the heatsink. If you measure the resistance between the legs of any individual output transistor and read anything near 0 ohms, the transistor or one in parallel with it is likely shorted and will need to be replaced. You'd have to remove it from the board for definitive testing.
The donut is a power transformer. The coil with the black stick is an inductor.
The following page will help acquaint you with the components inside the amplifier.
Amplifier Repair Primer
Aug 15, 2008 | Nitro BMW-482 Car Audio Amplifier
Power lights
no that is not normal. That means your amplifier is still getting power. Try connecting your remote wire from your cd player, to an on / off switch (auto parts store) and from the on / off switch to the amplifier. When you turn your car off, turn the switch off and your amp will no longer have power.
Feb 20, 2008 | Audiofonics ADF-241 Car Audio Amplifier
Runs but no heat
check for power promblem 220 not getting to drier reset the breaker it will run on 110 but not heat fools people check out let and power cord at terminal block if cord is burned in two just means it was loose when installed no drier falt just replace cork terminal block or both
Dec 27, 2007 | Kenmore 63942 Dryer
Overcurrent protector
The woofer or the wiring may be shorted. Remove the speaker wires from the terminals of the amp and power up the amp. If it powers up, check the wiring and the speaker. If it still goes into protect, the amp may be defective. A short in the wiring or speaker can damage a brand new amp.
Dec 17, 2007 | Sony XM-1600GSD Car Audio Amplifier
54 people viewed this question
 Grubhead
Grubhead
