Rca 52 inch projection looks like 3-d movie
I have a year and a half old rca 52 inch hi def ready projection tv. The convergence option is gone from the setup menu, and the picture looks like a 3-D movie. I am pretty sure it needs convergance chips. What else might it need? Where can I buy these parts, and how do I find out what kind of IC chips I need? The tv model is R52WM24YX61
  • 4,234 Answers
Open up the back, the convergence ICs are large and attached to a heat sink. They should be marked STKxxx. In most cases, replacing the ICs is enough. Sometimes the feeder resistor fails because of too much current draw. Change the ICs before looking for more parts. Also, try resoldering the ICs. Bad connections can cause this problem as well.
Dan
Posted on Apr 09, 2008
My mom has 52 inch rca and the convergance option on the menu is gone
Very easy and inexspensive repair. You can get the RCA repair kit called the ITC222 & ITC222A convergence option missing repair kit from www.tvrepairworld.com the kit contains the parts and the instructions for the repair
Apr 27, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I need a convergence kit for a rca 52 inch rear projection tv
what type of problem with convergence? no convergence at all? pitcure bowing? this in the setup menu do you have the convergence option? a convergence ki in a standad porojection has stk ic/s this model does not .you might have the fl231 fuse problem.. generally its board replacement. then the problem becomes alighnment.
Aug 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The screen has gone dim
If this has happened over time, then this is not so unusual for a 5 year old projection TV. If happened suddenly then there is a problem in the video circuit. The best thing would be have a technician look att he TV. Please take a few moments to rate my answer. Thanks...
Nov 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca r52wh74 - no auto convergance
The model number of your TV probably falls under the ITC-222 chassis design. Do a search based on that criteria and it should point you in the right direction. If I remember right, you need to replace FL231 on the deflector board though. Good luck
Dave.
Jun 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence off line
How did you fix it?????? I though I tried everything!
Feb 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
52 inch rca shows picture in 3 colors will not focus
is thr convergence adjustment option still listed in the on screen menu? Let me know and I will try to assist you.
Jan 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
208 people viewed this question
Top Televison & Video Experts
