Question about Husqvarna 450 e-series 18" Chain Saw
Chainsaw starts but will only run for a short time and then quits
This is a 18" Husquavarna, has fresh gas with the right two cycle oil mix and a little Seafoam carb cleaner.
    Brigadier General:
  • 4,088 Answers
Suggest that you don't use the carburetor cleaner as it disturbs the fuel mix ratio. Use it only with 4-stroke engines. 2-stroke engines depend on the correct quantity and quality of oil mixed with the fuel for engine lubrication--if starved for oil, it will quickly ruin the cylinder wall, piston skirt, and rings. Remove the muffler and spark plug--inspect the cylinder and piston skirt/rings for any severe scoring while pulling the engine through slowly. If ok, check the muffler for plugging while it is off, and check the air cleaner for plugging as well. You didn't state completely what your problem was--help. Hope this helps1
Posted on Jun 05, 2010
My six year old chainsaw won't start?
If it ran before you stored it and you left gas in it, you can thank ethanol for your troubles.Try fresh mixed gas with a heavy does of ethanol treatment or Seafoam in the tank, prime it and try to start it 10 times, then let it soak for a few days and try again. Good luck
Apr 03, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Have a poulan wild thing and the oil bar compartment has gas in it
I would drain the oil and gas or whatever is in it. I would also drain the 2 cycle mix from the gas tank and start with a fresh gas and oil mix and fresh bar oil. The mix for the Poulan Wildthing is a 40:1 mix.
You are definitely going to smell gas when using any chain saw.
Oct 28, 2014 | Poulan 18" Wild Thing Chainsaw
My chainsaw is hard to start and when it does start and i start to use it it will die
First and foremost. The right mix of oil and gas is essential to any 2 cycle engine running/performing properly.
I always use at least a 90 octane gas. My Poulan is a 40:1 ratio mix, and I use synthetic oil. I only keep enough oil and gas mix that I am going to use within say 2 weeks. This keeps my saw running great.
I have also bought a carb tool to make sure I am running tip top. You can find a very very useful video of this on YouTube posted from donnyboy73. I have added the link below.
http://www.youtube.com/watch?v=3Lw0pJcEPYo
Hope this helps.
Sep 21, 2014 | Poulan Garden
Need gas and oil mixture ratio
The gas oil ratio on all Poulan models is 40:1.
First, I recommend a synthetic oil mix if you can find it and also recommend running a 93 octane gasoline.
Second, I would mix no more than 1 gallon at a time, unless you are doing a lot of cutting.
Gas/Oil mixtures do not last that long. I don't give them more than a month, and generally try to run any mixture within 2 weeks.
Think about it, gas cam gum up on it's own when let sitting for too long. Imagine what it can do with oil mixed in it.
Good luck with your saw, and be careful when cutting.
Jul 07, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The chain saw is brand new. It starts OK but after I make one cut it stalls (Every time).
Do you have the proper gas-oil mix? It should be 40:1, which is 3.2 oz of oil/synthetic oil to 1 gallon of fresh gasoline. Make sure you push in the choke after starting it. Also make sure the chain brake is off (chain should move freely by hand when the saw is TURNED OFF.) If gas mix is right, choke is turned off after starting and brake is off, take it back to the dealer/store.
Aug 29, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Husqvarna 350 has spark and fuel wont start just quit running while in use
1- Is the mix (gas & oil) right? If its 2-cycle,check the manual.
2- Is the choke set?
hope this helps
Jan 06, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
What is right gas and oil mix
The ratio is 50to 1 . If you can get it use stihl two cycle oil mix it is a very good product that I have used for 25 years and have had no problems. You can get it in 6.4 oz. bottles that makes two and one half gallon. I like my mix a little on the rich side so I use a 2.2 gal. gas can. Hope this helps you and have a good new year. Thank you
Jan 02, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
New 18" Poulan Pro 42 cc saw, mixed up new gas
Don't use stabil. Use a modern synthetic saw oil (50:1 fuel to oil ratio) available at home centers, hardware stores, and saw dealers. Mix the oil and fuel in it's own container and be sure to shake the container thoroughly just before filling the tank each time to prevent oil starvation. If it becomes apparent that the carburetor adjustments are wrong, you will need to see your dealer for adjustment. Good luck!
Dec 18, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the fuel mixture for my new Poulan Pro 18'' chainsaw? It looks like 32:1 but not sure.Thanks! Don
If you use a mixture of 50:1 you can't go wrong.This is the industry standard and can be acheived by following the mixture guide lines one the bottle of oil.32:1 will make your saw smoke to the point of being almost unbearable and will foul the plug,so 50:1 is the mix your looking for.
Dec 15, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Was not in use about 2 years. Right now could not start. What should i do to start the engine?
dump the gas - change the plug - get fresh mix - get and use starting fluid sparingly - clean the air filter, start pulling.
Oct 13, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Husqvarna 450 e-series 18" Chain Saw Logo
156 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
