Question about GE (PSS26MSRSS) Side by Side Refrigerator
The problem I have is with a side by side Fridgidaire fridge/freezer model FRS20WRH. The defrosting is what I think the problem is because of the ice build-up on the coils. There is a circular device with elec. wire that is attached to the copper tubing that wraps around the coils and attached to the piece of metal stuck inside the drain. Could this be a faulty device?
  • 17,970 Answers
May have a problem in one of several areas, keep in mind poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
1.- Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
* The defrost timer
* The defrost thermostat (also called the bi-metal switch)
* The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem.
2.- Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Keep in touch.
Posted on Jun 04, 2010
Tip
Defrosting Tips for Your Fridge & Freezer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Defrosting fridge/freezers is much easier with a two-control model. That way, you can use the fridge to keep foodstuffs frozen while you deal with the freezer.
Are you thinking of defrosting method for your freezer or fridge? Then check this out.
Always switch off and unplug the freezer before cleaning or defrosting.
Load the contents of your freezer into large dustbin bags and cover the bags with a duvet or blanket. The food should stay frozen for several hours. But use a cool box for ice cream or soup which melts quickly.
After defrosting, wash fridges and freezers with a solution of two teaspoons of bicarbonate of soda to 1 liter (2 pints) of warm water-it removes lingering smells.
Rub the inside of your freezer with glycerine, available from chemists, after it has defrosted. When you next have to defrost it, the ice will come away from the sides more easily.
Use a wet/dry vacuum cleaner to **** up any water left on the floor.
If you do not like defrosting, you can always pay more for a frost-free freezer which never needs it. www.victorwod1234.blogspot.com
on Apr 05, 2010 | Refrigerators
Kenmore refrigerator side by side. EnergyStar sticker says model series 56541-56551. Freezer side cold; fridge side between 50 and 60 degrees. I unplugged for at least 2 days for ice to melt. Fan at...
If there is ice built up on back inside freezer wall, you have a defrost problem. Either defrost heater, defrost thermostat, or defrost control (timer or Board) is bad.
Sep 05, 2017 | Kenmore Refrigerators
The freezer works but not the fridge, we unplugged and defrosted and the fridge began to work we already have the cover of in the freezer and it defrosted yesterday but not today? We do not know what coil...
check and make sure your fan is working, if it is ,, it could be one of the following, adaptive defrost timer, tells it when to defrost,, defrost heater,, melts the ice,,, or the defrost thermostat,, all parts can be found on repair clinic the only way you can check the derost timer is listen and see if it shuts off,, the heater you can check with a ohm meter,,
Jan 19, 2011 | Frigidaire FRS3R5EMB Side by Side...
The Electrolux refrigerator is not working it's not cold but the freezer is working I was told it may be the thermostat. Food and milk in fridge is getting spoiled. It's been out for 3 days already. Thank...
First thing to check is if (a) the evaporator fan is running in the freezer and (b) if there is a build up of ice on the freezer wall. If the fan is not running in the freezer the ref. side won't cool. If there is a build up of ice on the freezer wall, then you a defrost system problem and there won't be any circulation to the ref. side. If you have a defrost problem, the defrost system consist of 3 parts: timer, bi-metal thermostat, and heaters. With fridgidaire more than likely the adaptive defrost board(timer) located in the fridge on the upper left side behide some white pastic is bad. If you change it go ahead and change the bi-metal thermostat, located behind the freezer wall, as well because its a very cheap part and will save you from having to do it later.
Nov 01, 2010 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
My Fridgidaire Professional series refrigerator has a puddle of water in front of it about once every other day. The puddle is around the front on the freezer side of the fridge. What can I do to fix this?
Drain line in the freezer section is clogged, needs cleaning. There is a small drain pan on the bottom of the rear wall in the freezer. It is covered with ice. Defrost or remove ice, and get to the drain hole. try flushing with hot water, if does not help - clean mechanically on both sides of the drain line - in the freezer and in the back of the fridge, where it comes to the drain pan near condenser/compressor.
Oct 16, 2009 | Frigidaire Professional 26 cu.ft....
Samsung fridge RS2630, icing up on freezer and fridge not cooling
Could be the defrost element. If it does not work and melt the ice off of the evaporator, icing will continue and serve as an insulator. Freezer and refrigerator temps will suffer.
If you unplug the unit and let it defrost for a day and plug back in it will work fine till it freezes up again.
Jun 25, 2017 | Samsung RS2630WW Side by Side Refrigerator
Only the freezer side is working
I don't think the darkness is related to the fridge not being cool. The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridgidaire Gallery Series Side by Side Refridgerator
"jennycub" sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine. very common problem( easy to detect. water on the floor of freezer compartment) as far as the other posting by" humblerumble", ive seen where the drain tube under the refig has pushed a hole into the drain pan under the refrig, in which case it will only leak after a defrost cycle, with the kickplate removed grab a flashlight and look under the unit for the drain pan as you pur water into the back of the freezer sect to trace water flow
Oct 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Aug 28, 2006 | Kenmore 50522 / 50524 Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
32 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
