Question about HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop
I am trying to make my wireless network secure by adding a password and every time I do so, the network name doesn't come up as an option to be chosen to connect to when I turn on my computer. It's only accessible if it's unsecured...What am I doing wrong?
  • 742 Answers
Choose a compatible encryption method for both the router and the PC or laptop connecting to the router.. You may choose WPA on your router and you should SET WPA also in your laptop. Just try to check this compatibility.
Posted on Jun 05, 2010
How do I reset my router password, normal one doesn't seem to work anymore.
There should be a small reset button on router which will reset to default,u will need. A pencil or similar to press it, the default username is usually admin and password is. Admin
Oct 17, 2012 | D-Link DIR-615 Wireless Router
Tip
Secure your Wireless Router - General Guide
How do I secure my wireless router? A general guide
To set up wireless router security, there are four main steps, which are the same for most routers. These are:
1) Login to your router, using a wired connection
2) Change the router login password
3) Change the network name (SSID)
4) Enable WPA encryption.
This is a very general guide, which will use the Netgear DG834G wireless router as an example. As every router is different, you will need your user manual to get the most out of this tip. (If you need help with finding a manual, see ‘How To Find a Router Manual’).
Here are the details:
1) Login to your router, using a wired (Ethernet) connection.
Make sure you have a cabled connection to your router. Then open a web browser, and type the router’s IP address into the address bar. For example, this is http://192.168.0.1 for the Netgear DG834G (Note, there is no ‘www’).
Enter username and password at the prompt.
Netgear DG834G: the defaults are username: admin and password: password (or, for UK Sky users - username: admin and password: sky). Other routers – common usernames are admin or blank: common passwords are admin, password, 1234, or blank.
If you log in successfully, you should then see the router configuration screen.
2) Change the router login password.
To change the router password, find a menu option such as Setup, Tools, Administration, Basic Settings, Management, or Utilities. On the Netgear DG834G – this option is under Maintenance > Set Password.
Set and confirm a new login password. Click ‘Save/Apply’ when finished.
Tip: Write the router login password on a label, and stick it to the router.
3) Change the SSID (network name):
The SSID or Network Name is the name you see when you are looking for an ‘available wireless network’.
To access this setting, find a menu option such as Wireless, Wireless Security, Security, or perhaps Advanced Settings. For the Netgear DG834: the Network Name/ SSID option is under Setup > Wireless Settings.
Change the SSID from the default, to anything you like. It is case sensitive, and you can use up to 32 letters – but do not use something that could identify you, or your location. Click ‘Save’ or ‘Apply’ when finished.
Find the Wireless Security or Wireless Encryption Options section - often in the same section as the SSID (eg for Netgear – it’s still in Wireless Settings).
You may have a number of encryption options. Select WPA-PSK or WPA2-PSK (good choices to start with).
You then need to enter a network key. The box to enter this may be labelled Network Key: it may also be labelled WPA-PSK, WPA Shared Key, PSK, Security key, Passphrase, Pre-shared key, Authentication key . On the Netgear DG834Gv3 it is labelled ‘Network Key’.
The network key should be a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers - eg, 451ThisisGooDFunforgEeks7899. It is case sensitive. (If you think your connection is likely to be hacked, pick a very strong network key.)
Note down your network key carefully. You will need this to connect wirelessly. Click ‘Apply/Save’ when finished.
That's it - you have done enough to secure your network, and can close the screen.
There are further security options to enable if you wish, but these three are the most important.
When you next connect wirelessly, you should see your wireless router with its new name in the 'available wireless networks'. When you attempt to connect, you are asked for the network key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
If you get stuck with any of this, consult your manual, or post on Fixya. Good luck with securing your router.
A word about WPS: WPS is a shortcut method to help you implement security on a wireless router. Consult your user manual if your router is WPS enabled, and you prefer to use WPS.
All information is offered as is, without warranty. If you choose to use it, it is entirely at your own risk. Thanks to all Fixya contributors who helped with this tip. Advice and links current at time of writing. Written by ‘eecom’, Jan 2009.
on Jan 10, 2009 | NetGear DG834G Router
How to set up a internet password for a mac with net gear
  1. se an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
    For Steps 4-9, refer to Figure A below.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  5. Under Wireless Network, enter your desired network name in the Name (SSID) box.
  6. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  7. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrasebox.
    • WRITE DOWN or KEEP NOTE of your network name, security option and passphrase - you will require them to connect wireless computers and devices to your network.
  8. Click Apply to save the settings.
Mar 08, 2012 | Computers & Internet
Set up wireless
How to Access Netgear Wireless Router Settings
Netgear wireless router settings must be changed using the router's web-based interface. Any computer on the network can be used to access it. From the Settings menu, options such as "Encryption," "Network setup details" and "Passwords" can be customized.
There are a few different variations of login credentials. Though these steps will use the details that work for the most common router models, the alternate login details that other models of Netgear wireless routers use will also be included.
Things You'll Need
Computer connected to the network
1 Open any web browser, such as Internet Explorer or Mozilla Firefox. In the address bar, enter "192.168.0.1" (without the quotes) and press the enter key. This will bring up the login prompt for most Netgear wireless routers. If that doesn't work, try "www.routerlogin.net", "192.168.0.5", or "10.1.10.1" until the login window appears.
2 Enter the username "admin" (again, without the quotes), and the password "password" in the appropriate fields, then click OK to login. If that password fails, try "1234," "Password" (with a capital "P"), or "admin" until you are greeted with the settings screen.
3 Make any required changes to the settings. Under security, it is possible to specify a new username and password for added security. Once you are done, close the window, and the system will automatically log you out.
Tips & Warnings
Always secure a wireless network to prevent outsiders from being able to change your network settings.
Jan 09, 2012 | NetGear RangeMax Computers & Internet
I have a nieghbor who has somehow found out my password. How can I change my password so he can't use it anymore.
you can change your wireless encryption password by going to internet explorer
the default login/pass
  • Username = admin
  • Password = password
    • For older devices, password = 1234
if this does not work you will need to reset your router by holding the reset button for 30 seconds or more when you power it on.
  1. Use an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  3. When prompted for a Username and Password, enter the default username and password (admin;password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  7. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into thePassphrase box.
Mar 29, 2011 | NetGear MR814 Wireless Router
How do i hook my mi-fi internet to the xbox 360? i have purchased an adapter and can not figure out how to get the internet working
Here's how to configure your wireless settings:
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. If you are prompted to select a wireless network, complete these steps, otherwise skip to step 4.
    1. Select the name of your wireless network.
    2. Enter your wireless network password and select Done.
    3. The console will automatically try connecting to Xbox LIVE. If you get an error message, go to the following webpage for help: support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx (http://support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx)
    Note If you do not see the name of your wireless network, select Advanced Options. Then select Specify Unlisted Network and enter your wireless network name. Select your wireless security type (WEP, WPA, WPA, or No Security). This security type needs to match the security of your wireless network.
  4. Select Configure Network.
  5. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article: 977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  6. Select Scan for Networks.
  7. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article: 909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  8. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  9. Press B on your controller, and then select Test Xbox LIVE Connection.
Mar 07, 2011 | Microsoft Xbox 360 Console
How to use dual band on router?
You can only use it in the 2.4 ghz mode or the 5 ghz mode:
1. Log in to the Router by going to http://www.routerlogin.net or http://www.routerlogin.com
and entering the default user name admin and default password password, or using whatever
LAN address and password you have set up.
2. Select Wireless Settings under Setup in the main menu to display the Wireless Settings
screen.
3. Select the region in which the wireless interface will operate.
4. Set up the 2.4 GHz wireless network:
a. Enter the SSID name. The default is NETGEAR.
b. Select the operating channel for the wireless mode. The default is Auto. When Auto is
selected, the router finds the best operating channel available.
If you notice interference from nearby devices, you can select a different channel.
Channels 1, 6, and 11 will not interfere with each other.
c. Leave the wireless mode set to the default setting of Up to 145Mbps for 2.4GHz.
5. Select security options for the 2.4GHz wireless network.
The wireless Security Options are set to None by default. NETGEAR strongly recommends
that you use wireless security. You can select a different Security Option and a different
passphrase for each wireless network. For the highest performance of the 2.4GHz wireless
network and the most secure encryption, NETGEAR recommends that you use WPA2-PSK as
your security option.
6. Set up the 5GHz wireless network:
a. Enter the SSID name. The default is NETGEAR-5G.
b. Select the operating channel for the wireless mode. The default channel is 36. If there is an
Auto option in the channel list and you select it, the router will find the best operating
channel available.
c. Leave the wireless mode set to the default setting of Up to 300Mbps for 5GHz.
7. Select security options for the 5 GHz wireless network.
passphrase for each wireless network. For the highest performance of the 5 GHz wireless
network and the most secure encryption, NETGEAR recommends that you use WPA2-PSK asyour security option.
8. Click Apply to save your changes.
please rate it and give a testimonial for my response
Thanks, Joe
Feb 02, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
How to set a security cod for wifi
This is a Quick and easy fix!
  4. Under Wireless Network, enter your desired network name in the Name (SSID) box.
  5. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  6. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
  7. Click Apply to save the settings.
Dec 12, 2010 | NetGear WGR614 Wireless Router
I want to set up a secure netgear wireless connection
THIS IS A SUPER QUICK AND EASY FIX!
  1. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  2. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  3. Under Wireless Network, enter your desired network name in the Name (SSID) box.
  4. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  5. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
  6. Click Apply to save the settings
Dec 11, 2010 | NetGear WGR614 Wireless Router
I am trying to connect another computer to my wireless network but i do not know my netgear code, where do i find this?
Netgear code? Can you be more specific?
Are you referring to the password required to connect to your wireless network called "Netgear"? I assume you're being asked for a password on the 2nd computer when trying to connect to the wireless network called "Netgear".
  3. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  4. Under Wireless Network, enter your desired network name in the Name (SSID) box. This is currently set to "Netgear" most likely.
Once you've set this password, you can use it to connect to "Netgear" on your second computer.
Jul 25, 2010 | NetGear WGR614 Wireless Router
HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop Logo
49 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
