Question about Frigidaire FRS26H5AS Side by Side Refrigerator
I purchased a water valve from Sears and I'm having trouble connecting the colored water lines Part No. 240531101 There are four (4) water inlets to the valve. What Line goes where? Green - White - Tan - Yellow Water lines coming from the refrigerator Frigidaire Model # FRS26H5ASB6 I would like to a Water Valve Schematic on installing the water lines Thanks, your help will be appreciated. **** Knuckles dicknuc@suddenlink.net
    President:
  • 1,430 Answers
Posted on Jun 04, 2010
Testimonial: "Thanks, Just what I wanted. Water Line Schematic. "
Water Supply ConfusionFRS26ZRFW1
you never mentioned you use teflon tape for tighter fit.
Feb 05, 2014 | Refrigerators
How do I hook up the plumbing. Do you have an exploded diagram of the back panel where all the water hook ups are at.
It depends on the refridgerator. Some have two inlet valves. Basically, you have a water line from the home. Usually copper line. You also will have two places for water lines on the opposite side of the inlet valve. Sometimes you may only have one. The line leading from fridge ( if ice and water through door) will hookup to the line where you have the fridge connactor. The quick connects to the inlet valve. The second one will be for ice maker. That water line runs up the back of fridge into freezer. Make sure you place the quick connects in the right spot. Process of elimination because some inlet valves wont let you change the hoses once installed. Connect the main water line from the home. Connect both quick connects dont connect water lines yet. Push the water thru the door botton and see which valve opens on the inlet. Which valve on inlet opened and allowed water to come out. That is for fridge and other is for icemaker.
If you need further assistance please feel free to contact.
Jul 24, 2011 | Refrigerators
I need to reinstall awater inlet valve on my
Parts & Accessories | Shop & Find Lawn & Garden, Appliance Parts at Sears PartsDirect | SearsPartsDirect.com go here,put your model number in and hopefully this will help you,next time you need help send the model number,good luck,just take off one line at a time and install it into the new valve,the lines are different sizes and the solenoids are colored so it's kind of hard to do this wrong,also there should be instructions with the vavle
Jan 10, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
Can't connect water line from the icemaker to the new water valve
the valves they have now only have push locks. so the only thing you need to do is push the water line in and it should lock.
Nov 04, 2009 | Refrigerators
My ice maker is not making ice. Where do I start the trouble shoot?
The likely culprit will be a damaged inlet assembly
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush
or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Sep 07, 2009 | Refrigerators
Ice maker is not making ice. Water is not coming
Jul 10, 2009 | Amana AFI2538A Bottom Freezer French Door...
INVENSYS CONTROL FOR KENMORE ELITE SIDE BY SIDE
Hi, you can purchase replacement part on amazon, here: Amazon com KENMORE ELITE INVENSYS CONTROL I hope this was helpful. Cheers
Apr 27, 2009 | Kenmore Refrigerators
Bosch SHU 4000 series dishwasher; Water keeps on filling
The inlet valve will be at the dishwasher end of the (hot) water inlet line. On this dishwasher I ~believe~ the inlet valve is near the rear of the unit. That means that you will need to pull the dishwasher out to get to it. Remove power from the dishwasher as soon as you can before messing with the unit.
Just past the connection of the supply hose and the connection on the dishwasher, there will be the valve (a solenoid valve with two wires coming out of it.) That is the little beast that has most likely failed.
Good Luck!
Jan 14, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Hotpoint DF31 Dishwasher
You need a new inlet valve. Axcessed through bottom panels below door there are screws in the four corners of the upper one. Inlet valve is where the water line meets a plastic body with wires going to it. www3.sears.com for parts.
Oct 05, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
243 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
