Question about Frigidaire 21 cu. ft. / 595 liter Upright Freezer FFU21C4C
Model GLFH21F8HWD LCD DISPLAY ERROR AFTER BLACK OUT, HOWEVER FREEZER WORKS OK
Ok, upright freezer, frigidaire, read -12 after power outage but working ok..when I tried to reset temp to 0, light went off, freezer went off, front display reads 56..any ideas?
Thank you for your post, Cynthia!
Based off the information you have provided your Frigidaire freezer is not cooling properly and is now displaying the temperature of 56. It sounds like your freezer is not on, even though it has power the compressor is not turned on. I would suggest pressing either the down or up arrow three times within five seconds. That should power on your compressor and it should start cooling properly. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Feb 28, 2015 | Frigidaire Freezers
Error code 0F
Good Morning Stephanie Garcia, thank you for your post!
From the information you have provided your Frigidaire freezer is displaying an error code of "OF". Typically, an "OF" stands for power off, you should be able to press the up arrow three times in a row within five seconds to turn your freezer back on. If that does not help correct your issue you may want to perform a reset and you can do that by unplugging the power cord for roughly ten minutes. I hope this helps. -Matt
Jan 17, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
Filter changed but still 1% on display panel
Is this a side by side fridge freezer? Most Whirlpool models with LCD display on front- reset filter indicator to display 99% by pressing and holding 'OK' button until filter resets to 99%. If you have a different model, or of this doesn't work, advise on model number and I can instruct further
Aug 10, 2009 | Whirlpool Freezers
I am working on a delfield model 6176-s and the display board is showing error 4. what does that mean?
Wow, what a challenge.
I found what I think you are looking for.
First, this only applies if the controller is an MCII. Should be printed on the face of the control.
In their 1996 manual for 6000 series reach-ins, it states that the number "4" error code is "Continuous operation with overtemp condition." It also says "What to do." and lists "Check refrigeration system and control system."
Hope this is what you are looking for. Good Luck.
Jul 23, 2009 | Delfield 66.5 cu. ft. Commercial Freezer...
Freezer don't get cold-fan turns on ,timer is ticking,black thing under is vibrating,coils are clean
1st check the compressor working or not working .OK compressor is working system gas leak ,not working check the capacitor and timer contector
Jun 20, 2009 | Frigidaire Freezer FFU11FC2CW 11.2 Cu.Ft....
I have a beko fridge freezer. I had an error code
I got the answer myself and thought I would share it.
The E4 code means that the auto defrost is not working. Call beko and tell them the code and they will tell you what part it is. I think the part number is 421445. It is a little black tube with two wires comming out. The part costs about £10. To fit the part you have to go into the feezer side of the fridge and carefully remove the white plastic at the back which is held with clips and one screw. To find where the part goes look for a long white fatish wire. The black fuse or thermostate is hidden in that. You will see where the wires go when you remove the old one. It is easy to do. Once you replace the part the error light will still be on but will go out after the fridge is back to being cold. Don't forget to replace the inside of the freezer when done! Hope this helps. John
Jun 18, 2009 | Freezers
Freezer wont freeze - digital display has no display at all -
Melanie--
Because this occurred as a result of a power outage, you need to check that the outlet is OK. Plug something in the outlet like a lamp and see that it works normally. If that is OK, check the display for a light bulb that is burned out--incandescant bulbs do that occasionally in a power outage. If it is an LCD or LED display, the power supply is bad on the display board. Is the motor humming and making normal noises?--and your freezer is just not cooling? If no motor noise, look for a reliable and trustworthy appliance repair person. If the damage is costly, try to pursue a claim with the power company.
Dave M
Dec 17, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer not working
I have a Kenmore Freezer model # 253.9251310 serial # s510347256
10\95 Makes all kinds of noises and now is defrosting. Sounds like fan is working but no noises besides fan. any ideas
Dec 12, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Sep 05, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Frigidaire 21 cu. ft. / 595 liter Upright Freezer FFU21C4C Logo
109 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
