Question about Garden
Oil in my Champion lawnmower is emulsified. How can I drain the oil tank?
    President:
  • 1,545 Answers
You can add a solvent like Diesel Fuel to it (engine) and pull the starter cord or starter to move it around...it will begin to break up the mess possibly.. You can also add Gunk Car Engine Cleaner too, to the engine oil, not the fuel.....A regular mower only holds about 20-21 oz of oil so be forewarned...
This is an interesting situation...is it even worth demulsifying?
Posted on Jun 11, 2010
Ford 3000 lift slow and jerky when cold after warm up very sensitive oil looks milky could fluid be problem
Oil or fluid will look milky if it is either emulsified (with water) or if it become aerated.
Emulsified fluid or oil will promote corrosion and aerated fluid is compressible which is unsuitable for hydraulic applications.
Jan 04, 2017 | Ford Cars & Trucks
Why is there oil in airtank, did do it to store it or is there a problem?
Presumably you are asking about the air tank of a vehicle airbrake system?
I think it depends on how much oil there is and whether it looks clean. The inside of an airtank might have a spray of something vaguely oily as a preservative when new but it is unlikely anyone would do that when an in-service vehicle is stored.
In most cases the compressor of a vehicle airbrake system is engine driven and therefore is working nearly as hard as the engine and for as long as the engine. It is for that reason the lubrication needs to be as good as the engine's own lubrication so mostly the compressor is mounted on the engine block, driven by internal chain or gears and shares the engine oil.
In theory little oil should reach the top of the compressor and be pushed into the airtank but in practice a significant amount does and depending whether the system is fitted with a drier and a self-drain sytem depends how much oil will reach the airtank and whether it will be emulsified or not.
If no automatic drain is fitted draining the airtank should be a daily job for the driver but few drivers actually remember. When I was working as a truck mechanic it wasn't unusual to have to drain a couple of pints of emulsified oil from the airtank during routine 6 month services or safety inspections.
Could be your tank wasn't drained before storage...
Feb 05, 2016 | Cars & Trucks
My son put oil in lawnmower gas tank
Drain as much as you can out. It won't hurt thing. May smoke a
for a little bit.
Oct 05, 2012 | Toro Garden
Will putting oil in the gas tank of a 2 cycle lawnmower riun the engine?
It is not good for that motor--drain and clean and expect plug may get fouled---do it the sooner the better.
Jun 15, 2012 | Briggs & Stratton Briggs Stratton...
Champion 35 lawnmower hunts
Clean the air filter (foam type) in warm soap water then apply some oil soaked in, it will smoke afterwards for a short time. Or possible minor adjustment too the mixture screw on the side of the carburetor spring loaded. Allan
May 09, 2012 | Garden
I have a champion 35 lawnmower and it starts no problem but splutters like hell, someone has suggested it could need oil but i cannot find the oil tank if there is onehelp you could give would be...
its a small circle and it looks like it has two small stems comingout of it. There shoul be a slot so go can put a flat head screw driver in there to twist it out. The dipstick is connected to it. If you are standing at the back of the mower, looking at it, it should be on the left in the rear of the motor. I would change the spark plug after checking the oil. most people dont. Take out the spark plug and bring to any auto store, they will give you a replacement. Run only premium gas in it, cost more but runs way better. Put fuel stabilizer in the gas tank i the off season so the gas doesnt go to waste.
May 20, 2011 | Champion Jockstrap and Abdominal Supporter
White liquid in gearbox
The liquid is emulsified water. Condensation in the gearbox, riding in creeks or a from high pressure car wash is where the water usually comes from. The gears emulsify the water into the oil thus turning the oil whitish. Just drain the oil then put in fresh oil, ride for a mile or two then change the oil again. No real harm has been done to the engine. Please rate my answer. Thanks!
Mar 28, 2011 | 2000 Yamaha DT 125 R
Lawn mower has too much oil. how do I drain excess on Champion RL 534 TR
Remove the small plastic oil filler plug where you put the oil in, and turn the lawnmower onto it's side to drain any or all of the oil.
Jun 13, 2010 | Garden
I have a Mountfield HP474 lawnmower. We cannot locate the sump plug to drain the oil. Please could you advise. Many Thanks Gavin
According to the operators manual there is no sump plug, instead you "dump" the oil out using the oil fill.
Below is step by step instructions copied from the Operators manual:
Drain oil while the engine is warm being careful not to touch the hot engine nor drained oil
a) Place engine level
b) Clean around oil fill
c) Remove filler cap
d) Have a container ready to collect the oil
e) Tip the lawnmower on its left side so that the oil will drain from the oil fill
f) Place the lawnmower level and top up with new oil
g) Check the oil level on the dipstick
Oil should be at "MAX" mark
h) Close the filler cap and wipe off any spilled oil
NOTE: The oil capacity is about 0.6 liter
Sep 20, 2009 | Garden
Garden Logo
97 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
