Question about GE WBSE3120B Top Load Washer
Magnetic Lid Switch or Other?
I have a wbse3120b top load ge washer i bought in 2003. I had this problem 2 yrs ago... The washer fills, but won't empty, agitate, or spin. When this happened once before, I let the hose down to drain and got so frustrated, i smacked the lid of the washer and it worked instantly! This time, I had to take the front panel off. I lightly jerked the wires attached to the lid switch, pump, and motor, then i heard the click of the switch, and the water pumped out instantly. I jerked it again and it stopped. Jerked a 3rd time, the switch activated the pump emptying all the water. Then switch deactivated again on it's own and hasn't turned on since, no matter how i jerked. I can hear electrical humming and the circuit board is fine. Is it the switch or something else? By the way, we do just let the lid slam a lot. Please help...
  • 4,070 Answers
I would try the lid switch, part 388 on this diagram and parts list. You can check to see if this is the problem by taking the old one off and tape the two wires together and see if it will work. Using it without the lid switch creates a safety hazard. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=229918&diagram_id=21464425#d21464425
Posted on Jun 04, 2010
Can a faulty lid switch cause a washer to spin but not drain
Hum only means something is blocked mechanicaly. Not likely lid switch since it cuts power when lid is open.
Aug 14, 2014 | GE WBSE3120B Top Load Washer
Washer would wash, or spin. the water appears to drain ok and fills ok
the magnetic lid switch is bad,its located underneath the lid toward the right side of where the lid lays,yoiu will see the magnet under the lid,the switch is below this
Jul 06, 2011 | GE WBSR3140DW Top Load Washer
Dosen't spin, dosen't fill water
your lid switch is a magnetic switch. make sure you have the magnet attached at the lid. if you do still the switch may be bad. question : did the washer fill with the lid open?. if it not then that would be an indication the switch bad. let me know
good luck to you.
Feb 07, 2011 | GE WBSR3140D Top Load Washer
My washer is not spinning or washing but drains and fills fine ,it is about six yrs old and is in good shape . Could it be the magnetic connection in the lid that could be causing the machine not to...
Sorry to read about your problem, I hope this helps you out.
yes you could have a lid safety switch issue
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | GE WBSR3140DW Top Load Washer
Wont fill or spin runs dry
Check the water pressure switch for proper operation
Oct 19, 2009 | GE WBSE3120B Top Load Washer
GE WBSE3120B toploader washer leaks only during agitation when super load selected. Is it the pressure switch for water fill level or another possible leak?
knowing this is the only time it leaks helps
sounds like your suffering from suds leak
try cutting way back on your soap 1 tablespoon per load that should take care of your issue
Oct 04, 2009 | GE WBSE3120B Top Load Washer
THE START BTTON ON WASHER PUSHES IN BUT DOES NOT TURN WASHER ON
HI, check the lid switch for its operational value. if the lid switch is showing good Resistance, replace the start button.
Jul 22, 2009 | GE WBSE3120B Top Load Washer
WASHER WON´T WASH OR SPIN
Hi
Sounds like a lid switch issue to me. the washer wont run if it thinks the lid is open. its a safety mechanism. Replace the lid switch. it's a cheap try and probably the right answer
Dec 10, 2008 | GE WPGT9360EPL Top Load Washer
GE WBSE3120B Top Load Washer Logo
268 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
