Question about Toshiba Satellite P105-S6124 Notebook
P105-S6124 computer hangs in internet explorer with gray line across bottom of screen
    Master:
  • 404 Answers
Memory "ram defect"
Posted on Jun 05, 2010
How do I access internet explorer
When it is installed on your computer, click the logo on the bottom left, and then type internet explorer or IE. Then you see the program above the line you were typing click on the line.
If the internet explorer does not show, it is not installed.
To install it, click Configuration screen, then programs, then standard programs then setup standard programs and choose IE.
Jan 24, 2015 | Microsoft Windows 7 Home Premium 64BIT...
Does the Toshiba Satellite p105-S6124 feature an air-filter?
well not exactly it's a filter for the heatsink for the CPU and is usually on side towards back or underneath
that can get clogged with dirt, making cpu run hot and slow computer down a bit.
we use a plastic ended vacuum hose on medium to remove that dust and dirt from outside of laptops
May 24, 2012 | Toshiba Satellite P105-S6124 Notebook
I turned my laptop on and an Adobe Flash Update appeared & completed the update as usual. This information may be irrelevant, however I noticed a thin vertical line appear about an inch from the right...
Try to do a System Restore back to earlier restore point.
If you are using Windows XP, click below link and follow the instructions.
http://support.microsoft.com/kb/306084
If you are using Windows Vista or Windows 7, use the link below.
http://windows.microsoft.com/en-US/windows7/products/features/system-restore
However, if this will not fix the issue, try to install an updated driver from Toshiba Website.
Hope this helps.
Jun 12, 2011 | Toshiba Satellite P105-S6124 Notebook
I cant get connect to a internet everytime i click internet explorer it say cant find a dsn error or internet explorer i have internect service at home and still cant get connected
are you sure its DSN and not a DNS error if the latter
Open your Internet Explorer browser. It doesn't matter what page your browser opens to as long as it is open. Click on the Tools option at the top of your Internet Explorer screen. Next, click on Internet Options followed by security Tab In the Security Tab, click on the Custom Level tab located at the bottom of the screen. Check the Medium security level drop down box once on the Custom Level screen. You will also need to browse through the options find the setting Access Data Across Domains and put a check in that box to enable the feature. Finally choose the Apply option and the exist the program. You might need to restart your computer for the changes to apply hope this helps
May 17, 2011 | Computers & Internet
Model is Satellite P105 S6024, serial # 86019106W About one inch from right-hand side of screen, a 'white line' (in appearance) has appeared. It is about one inch in width, and goes from top to bottom of...
When you get vertical lines from the top of the screen to the bottom of the screen, it means you have bad LCD panel, you need the new one. It will get worst with more lines as time goes by.
Mar 04, 2010 | Toshiba Satellite P105-S6024 Notebook
Toshiba P105-S6124 DVD Drive replacement.
there is usually one screw holding the dvd drive in, lay the PC closed, upside down, and lay the replacement drive in line with the old drive, this may tell you the exact location, or where to look (it may be under another removable panel, once the one screw is removed, the drive should slide out, if you eject the drawer, it is easier to remove after you pull out the screw, most have a manual eject (Pinhole in front by eject button) insert a straightened paper clip straight in. let me know if this helps or you need more info
gomez
Mar 30, 2009 | Computers & Internet
Toshiba Satellite P105-S6124 Screen lines
Are these lines on the screen during the whole boot process? If so then the screen cpu and/or the video cpu has gone bad. Connect an external monitor. If the picture is clear, no lines, then the problem is the LCD screen. If the lines appear on the external monitor during the boot process then the mother board will need replacement.
Good Luck
Mar 22, 2009 | Toshiba Satellite P105-S6124 Notebook
How can i recover my laptop to factory settings?
Applicable Models: Satellite L15-S104, L15-S1041, L20-S310TD, L20-SP231, L25-S119, L25-S1194, L25-S1217, L25-S1213, L25-S1215, L25-S1216, L25-S1196, L25-S1211, L25-S1214, L25-S1212, L25-S121, L25-S1193, L25-S1192, L25-S1195, L35-SP1011, L35-S2366, L35-S2316, L35-S2206, L35-S2194, L35-S2174, L35-S2171, L35-S2161, L35-S2151, L35-S1054, P100-ST7111, P100-ST9212, P100-ST9712, P100-ST9742, P100-ST9772, P100-ST9762, P100-ST9752, P100-ST1072, P100-ST9732, P100-ST1071, P100-ST9412, P100-ST9612, P100-ST9012, P100-ST7211, P105-S921, P105-S931, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6134, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S6034, P105-S6024, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6074, P105-S6054, P105-S9312, P105-S6014, P105-S6002, P105-S6004, P105-S6012 << hideThe printed instructions included with the Recovery and Applications/Drivers Media disc are correct for most computer models. For some models, however -- including those listed above -- booting from the Recovery disc requires pressing the F12 key, rather than the 'C' key. The instructions below are correct for these models.
CAUTION: The Recovery process reformats the computer's hard disk drive, which completely erases its contents -- including all applications, all documents, and all other data stored on the drive. Be sure to back up your documents and other data before following the instructions below.
Follow these steps to erase the current contents of the hard disk drive and to re-install all of the software that was installed on the computer when it was manufactured:
1. With the computer on, insert the first Recovery disc into the optical drive.
2. Shut down the computer (click the Start button, click Shut Down, select Shut Down, click OK).
3. Press the computer's power button to turn the computer on, and then immediately press and hold the F12 key. Release the F12 key when the menu of boot options appears.
4. Use the arrow keys to navigate to the CD/DVD option. Press the Enter key to select it.
The computer will restart, and will boot from the Recovery disc.
5. Follow the instructions on the screen to start the Recovery process.
CAUTION: Once the Recovery process has begun, do not interrupt it.
The computer's hard drive will be formatted, erasing its contents. All of the software that was installed on the computer when it was manufactured will then be re-installed.
6. Once the Recovery process is complete, remove the Recovery disc, and press any key to restart the computer.
- mc/wa
Jan 27, 2009 | Toshiba Satellite P105-S6207 Laptop
Tv tuner
go type in the exact brand of tuner into google in quotes and the word driver and download it. If you cant find one check the companies website and search for drivers
Jun 05, 2008 | Toshiba Satellite P105-S6104 Notebook
Toshiba Satellite P105-S6124 Notebook Logo
47 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
