Question about Danby DWM99W Top Load Washer
Water leaks under machine when filling
Danby DWM99W water leaks under machine when filling
  • 327 Answers
Hello, if your washer leaks only when filling then you have to check these:
Air-gap device- The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
THE TUBE - There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak
inlet spout- Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tube. If the spout cracks or breaks free of it's mounting, it can cause a leak.
Thanks
Posted on Jun 04, 2010
My Danby DWM99W is just dead.
Is the circuit breaker for the wall plug tripped?
Dec 20, 2016 | Danby Washing Machines
Danby DWM99W washer agitator not working. Assuming its the v-belt?
Try to see eBay.com or Amazon.com. Try to call or visit the place u bought the washer from, they should b able to give u what ur looking for
Jun 03, 2015 | Danby DWM99W Top Load Washer
Danby washing macine is leaking
Hi There,
I have just spoken to a technician here at Danby and he suggested to replace the washer in the hose.
If that doesn't work, please feel free to contact our customer service department at 1-800-26-DANBY (1-800-263-2629)
Jun 19, 2012 | Danby DWM99W Top Load Washer
My Danby washer always drain the water when it fill the water up on the 3 and 4 water level setting. So I can't wash clothing at all. Hope get answer soon.
The answer is the drain hose. It must be routed higher than the machine or water will always drain. There is no actual drain valve.
Oct 07, 2010 | Danby DWM99W Top Load Washer
The water level will not stop filling up to the level desired. Washer will not drain out and then I need to empty it with a cup.
Your water level sensor is likely faulty. Contact your retailer, or Danby directly, for a replacement and instructions on how to do so. Note, if this is in warranty, they may require you to bring it to a service center.
Aug 27, 2010 | Danby DWM99W Top Load Washer
Daby dwm99w drains and fills water at the same time.
The outlet of the drain hose must be higher than the highest level of water in the tub. Otherwise, it just siphons through.
Aug 01, 2009 | Danby DWM99W Top Load Washer
FILLS WITH WATER AND DOES NOT AGAITE
100% sure you need a new belt, or at least an adjustment to it.
Jun 20, 2009 | Danby DWM99W Top Load Washer
I have a new Danby washing machine but leaks from the springs area and several other areas. Will not fill with water and no wash cycle will engage. Seems to drain...spins well...but has an "intermittent...
you have a new washer so why not get the service agents out under warranty to fix the faulty machine
ask why there was water in a new machine as that indicates not new but second hand
May 25, 2017 | Danby DWM99W Top Load Washer
Won't wash
I didn't realize that you have to let the faucet run the entire duration of the wash cycle. But that was the problem.
May 21, 2008 | Danby DWM99W Top Load Washer
Danby DWM99W Top Load Washer Logo
287 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Samyfam
Samyfam
Mike
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
