Question about HP DeskJet 5150 InkJet Printer
No power to the printer - HP DeskJet 5150 InkJet Printer
  • 53 Answers
Check power connections and cables
Posted on Jun 04, 2010
Reset canon printer MP500
The reset method for Canon Pixma MP500 All-In-One Photo Printer
1. Entering into Service Mode
  1. Start with printer connected to power cord (electric source)
  2. Press and hold STOP/RESET button.
  3. Press and hold POWER button.
  4. Release STOP/RESET button without releasing power button.
  5. Click STOP/RESET two times and then release power button.
2. Reset the Canon Pixma MP500 All-In-One Photo Printer
  • After the printer entering into service mode, prepare paper on the printer paper tray
  • Press Stop/reset button for 1 times and then press power button, await till printer finished print.
  • Press Stop/reset button for 2 times and then press power button, The printer will print again. Await till printer finished print again.
  • Press Stop/reset button for 3 times then press power button to reset EEPROM.
  • Press Stop/reset button for 4 times then press power button to reset Waste Ink Counter.
  • Switch off the printer. if printer doesn't turn off, press button power until printer off
Jul 26, 2014 | Canon Pixma MP500 All-In-One InkJet...
Xerox Phaser 7760 shows the error 004-350, what can I do?
You can find answers to your Xerox questions at www.xerox.com/support .
Solution : Power Off the Printer, Wait 45 Seconds, Then Power On the Printer Some problems can be resolved by powering the printer OFF and ON.
WARNING: Only use the power switch on the printer to power the printer OFF and ON. Damage may occur to the printer if power is interrupted by other means.
CAUTION: When cycling power on the printer, any incomplete jobs in the queue will be lost and will have to be resent.
  1. Power OFF the printer using the power switch located on the top, right side of the Control Panel.
  2. Wait approximately 45 seconds, then power ON the printer.
Oct 23, 2013 | Xerox Phaser Office Equipment & Supplies
Epson PLQ-20 is not power on. Then how to power on printer?
printer power problem no powering on (epson plq20 printer supply show digram and layout of both side please send me
Dec 19, 2012 | Epson Passbook PLQ-20 Matrix Printer
Good morning, i was printing and the printer shut
Try to unplug the power adapter from the printer. Unplug the power cord from the power outlet in the wall. Replug the power cord after at least 10 seconds - bypass any power surge devices or power strips. Replug the power adapter into the printer. Your printer should automatically power on, otherwise, press the power button. If the printer still won't power on, please contact Lexmark technical support for additional assistance.
May 12, 2011 | Lexmark X5470 All-In-One InkJet Printer
Continuously says "entering power saver mode" i've pushed
It seems the printer is stuck on the power saver mode. Unplug the power adapter from the printer. The power adapter is the rectangular black box behind the printer where the power cord is attached. Wait at least 30 seconds before plugging back the power adapter in the printer? That should reset the printer. If the printer won't automatically turn on, press the power button. Hope this helps.
Jul 28, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Printer will not power on
Try these out:
1. Check for any physical defects on the power cord. Plug printer straight to the power outlet in the wall without using any extensions or power strips.
2. Plug the printer to a known working power outlet in the wall.
3. Unplug the printer's power supply (the black box behind the printer where the power cord is attached). With the power cord still attached to power supply and the other end still plugged in to the power outlet, it should feel warm but not hot. Then, plug it back in the printer.
4. If still no power, press the power button.
5. If after doing these and the printer is still not powering on, you might be looking at a defective power cord or defective power supply.
Apr 08, 2010 | Lexmark X2500 All-In-One Printer
Orange and green lights blinking
Hello try to press the power button to turn off the printer, then press the power button to restart the printer.
If the lights continue to flash,press the power button to turn off the printer,disconnect the printer from the power source,reconnect the printer to the power source and finally press the power button to turn on the printer.
Good luck
Jan 15, 2010 | HP DeskJet 5550 InkJet Printer
Ink carts are full. cannot get to reset w/o the ! pt flashing. HP J3680
Hard Reset
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds then replug the power cable to the wall out let and then to the printer.
Power Drain
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds now press and hold the power button on the printer and replug the power cable to the wall out let and then to the printer after the power cable is connected you can let go off the power button..
Partial Reset
Power Drain
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds now press and hold the # and the number 3 button on the printer and replug the power cable to the wall out let and then to the printer after the power cable is connected you can let go off the buttons..
Aug 11, 2009 | HP J3680 Officejet All In One Printer
Hp laserjet 1020 meltdown
Try this out:
Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below. Instructions If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .” If the printer uses a power module Follow the steps below to ensure power is properly supplied to the printer:
  1. Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
  2. Disconnect the power cord or adapter from the wall outlet.
  3. Disconnect the printer data cable from the printer.
  4. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
  5. Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
  6. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. NOTE: "The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
  7. If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  8. If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
  9. If the power module/cord works on the other printer, then this printer is defective. Service your printer.
  10. If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
If the printer uses only power cord Follow the steps below to ensure power is properly supplied to the printer:
  2. Disconnect the power cord from the wall outlet.
  5. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  6. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  7. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
  8. If the power cord does not work on the other printer, it is defective. Replace the power cord.
  9. If the power cord works on the other printer, then this printer is defective. Service your printer.
  10. If another printer is not available to test with, carefully inspect the power cord for damage.
  11. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
Goodluck,
Dont forget to rate me as fixya..
Jan 30, 2008 | HP LaserJet 1020 Printer
HP DeskJet 5150 InkJet Printer Logo
73 people viewed this question
Seeker5211
Seeker5211
