Question about Hitachi 50GX30B 50". Rear Projection Television
My picture is messed up. Its kind of unclear with
My picture is messed up. Its kind of unclear with various colours going through it. I presume it is picture tubes. Can you still get those and do you think thats what it is?
  • Hitachi Master
  • 3,459 Answers
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
My picture is messed up.  Its kind of unclear with - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jun 06, 2010
EasyCap - ''no input signal or signal is unclear'' Please Help!!!
In the ULead VideoStudio Application. Go to "Capture" tabbed panel. Select "Options" then "Video and Audio Capture Property Settings...". A window should pop up.
In the "Source" tabbed panel. Change the "Input Source" drop down menu to either "Video Composite" or "Video S-Video" depending on whether you are using the yellow or S-Video picture lead.
Change the "TV System" combo-box to PAL for colour and NTSC for black and white. On my computer S-Video option is showing black and white when using my Sky HD box, don't know why this is yet.
Try the above and you should get a picture. You can also change the frame rate and other compression techniques etc.
If it still doesn't work try changing your digital/sky/vcr/xbox picture settings to PAL for colour or others for picture preference.
Hope this helps.
Goodluck
OAC
Mar 06, 2010 | Ulead Videostudio 8 for PC
Component input colour is messed up
Go to the back of the TV and make sure, the component cables are inserted in all the way. Do the same for the source (cable or satellite receiver) component cables should be firmly inserted.
Try narrowing the problem by testing the TV with a different source, such as a DVD player if it compatible with the component. If the TV works with the DVD then your TV is fine and the problem goes back to the source (Cable or Satellite Receiver)
If the TV still not showing natural colors after been tested with another source.. then, the TV may have a bad PCB.
Best of Luck
Nour BMI
Feb 05, 2010 | LG 32LG30 32 in. LCD HDTV
Prining in colour not working?
because,some of your ink catridge colors are completed with your prior usages,, you have to replace your ink catridge,,..
Sep 27, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Laptop screen displays vertical lines of various colours
Have you tried to connect your laptop to external monitor?
If you get normal picture on external monitor, then you need to replace LCD screen, but if you get same picture on external screen, then unfortunately you will need new motherboard, because graphics card is integrated to motherboard.
Aug 13, 2009 | IBM ThinkPad R52 Notebook
The screen has cracked and colour has leeked so that viewing is unclear, any way of fixing this?
hi..you cannot perform the operation of your own,it needs
technical expert to solve the problem.
try this out..
thank you..
kindly rate my response..
Jul 20, 2009 | Sony Ericsson w580i Cellular Phone
My camcorder
If you are not getting good color picture then I would advise to perform white balance adjustments in service data with help of concern service manual.
This kind of adjustments required service data handling tools, reference color charts, proper and up to date service manual etc.
Please contact nearest Sony service center for proper fix.
Oct 07, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Unclear picture
some webcams you can not fix the unclear picture. because that is the best quality you can get. but try go to your camera settings and have a look there to see if any changes help with the quality
Mar 25, 2008 | Logitech Webcam
Goodmans LD3755HD Picture Problems
for cms voodoo, change your power module.
for tomchik, check your input voltage for voltage drop or fluctuation, if any employ voltage stabilizer, then change your power module. make sure that there is enough ventilation around your tv.
for bananahead , go and change your backlight inverter
Jan 05, 2008 | Goodmans W280NS Television
Hitachi 50GX30B 50". Rear Projection Television Logo
575 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
