Question about Husqvarna Viking 1
Wound bobbin successfully but cannot get it off the winder. Help!
  • utigersdk Jun 04, 2010
    Actually I called JoAnn Fabrics and they told me exActly what to do. But thank you
  • 1,555 Answers
Here's a link for the technical manual for your sewing machine. It explains how to attach bobbin to winder and how to remove.
http://www.pitonyak.org/misc/Emerald_183_Documentation.pdf
Posted on Jun 04, 2010
I wound my bobbin on my model 1100, pulled it out, treaded the machine, and cannot stop the bobbin filler from turning. Now the machine does not want to sew. Help.
Sounds like the bobbin winder activator is stuck. As long as the bobbin winder is activated, your machine will not sew since that is a safety function.
You might try flipping the bobbin winder activator back and forth and see if that releases it--or try winding some other bobbins. If it will not release, then you may need to take the machine for service.
If the bobbin winder is worn or defective, you can look at purchasing a stand-alone bobbin winder (called "Sidewinder") available online through Amazon, JoAnn's, etc. for about $30. It saves wear-n-tear on your machine plus allows you to quickly wind multiple bobbins without unthreading the machine. You can get battery operated or one that also has an AC cord.
Sidewinder bobbin Google Search
Oct 02, 2017 | Sewing Machines
Bobbin winder not working
none I have ever had CATCH the thread . you have to thread to the bobbin and hold the end till it gets a good start .
Feb 12, 2016 | Sewing Machines
Why does my bobbin winder stop prematurely?
Define "prematurely". Bobbins shouldn't fill to the edge of the bobbin. Are they wound evenly? Uneven winding can cause the winder to stop early.
Aug 24, 2014 | Singer 3116 Simple
Hand wheel won't disengage so that bobbin can be wound
The bobbin winder may need a new bobbin tire. Does the bobbin winder move over like normal?
Nov 13, 2013 | Husqvarna Rose
I have a Freesia 425 - I have wound the bobbin successfully, but the bobbin will not come off the winder - any explanations
The bobbin is probably cracked. They get that way when bobbins are wound in correctly, or to tight. Just break it off and get new bobbins. Just make sure your theading it correctly when winding bobbins.
May 04, 2011 | Husqvarna Freesia 425
Bobbin winder shaft won't spin. LCD says bobbin winding.
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Jun 16, 2009 | Brother CS-8150 Computerized Sewing...
I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Mar 17, 2009 | Baby Lock Sewing Machines
Cannot wind the bobbin
Check to make sure that the bobbin is locked onto the winder. If is not locked on then nothing will move. I know I had this problem as well and found that the bobbin must be locked on the winder.
Aug 24, 2008 | Brother CS-8150 Computerized Sewing...
Bobbin doesn't fill in bobbin winder
The bobbin winder question is a frequent one and it is very easy to solve. If you look at the shaft where the bobbin sits on the bobbin winder, you will notice that it has a slot in the middle of the shaft, an opening if you will. This is where you use a flat screw driver and open that space more to give more friction to the bobbin so it is not loose on the shaft. That slot was made for that. There are different bobbins on the market so thats why the slot is there. If it is too tight, grab a pair of pliers and close the gap. The metal of the bobbin winder on that shaft is malleable exactly for this reason. No need to put plastic bag material or anything like that. Use it as it was intended for.
Jul 07, 2006 | Yamata FY14U4AD
Sewing Machines Logo
66 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
