Question about Refrigerators
The ice maker only makes a little bit of ice. It used to make a full drawer. What can I do?
  • 420 Answers
The first thing to check is the condenser coil and fan (if equipped) to make sure it's clean.
Posted on Jun 04, 2010
I have a Model HZB-15/BF ice maker the handle on the ice bin is up and I cannot remove the bin. What do I do?
maybe its frozen.leave the door open for a little bit, or use a hair dryer to warm it, Matt gently push in on the drawer or tap on it
Jun 26, 2015 | Chard International LLC Chard Stainless...
U Line Ice Maker not working at all
if your drain pump is the one you plug your ice maker into and then the pump into the wall plug the pump is full and will not let the ice maker run. must be something wrong with pump
Nov 14, 2013 | U-Line Icemaker
How do I replace a broken ice full guide?
The ice maker is easy to remove once you get the drawer off the slides. There are two plastic clips located near the back of the drawer that attach it to the slides. Pop those out and lift the drawer out. Pull off the plastic ice maker cover to expose the mounting screws. Remove the two screws holding the assembly to the top of the freezer, then slide the ice maker forward about 1/2 inch. It will drop down a few inches, allowing you to unplug the wiring connector and remove it as a unit. The ice full guide is then easily removed.
Sep 06, 2013 | Samsung RF265AA Bottom Freezer French Door...
How can I stop automatic ice maker from continually making ice?
There should be a metal wire that hangs over the drawer. When the drawer is full, the wire flips up and shuts off the ice maker. You have to manually lower the wire back down to restart the ice maker. It sounds like yours is hung up, missing or broken. Have you checked this?
May 08, 2010 | GE GSS22IFR Side by Side Refrigerator
12 year old sub-zero refer-the ice maker drawer will not open. Something will not allow the drawer to be pulled open.
There is a plastic sled that fits on a wire bail, connected to a microswitch that tells the unit that the ice level is low and it needs to turn on the water to fill the ice cube trays. The wire bail falls out and catches on the drawer. If you pull too hard, you will break the plastic sled where it attaches to the bail. You can still buy the entire ice maker unit and re-install it easily, or if you are really handy, you can attempt a temporary fix with a little bit of wire at each end of the plasitc sled to keep it attached correctly to the wire bail. The older units were famous for this problem. I fixed mine, but ultimately had to replace the unit. Parts cost around $130.
Jan 04, 2010 | Sub-Zero 561 / F
My galaxy ice maker stopped working. At first i thought it was just jammed. We cleared it of ice. We thought maybe the drawer wasn't put back in correctly, took it out and put it back. Worked for a little...
ck the temt of freezer . it must be 15 deg or lower . sounds like it 20 deg and is having a hard time. set freezer to lower tempt and clean the coils undr neath and make sure the fans both top and bottom are going . as no air flow no ice. or poor cooling .. **** hope this helps / feed back pls .
Dec 23, 2009 | GALAXY Microsystems 25.4 cu. ft....
Ice maker makes too much ice
In my Kitchen Aid bottom freezer there is a metal arm(?) that I lift up to stop the ice maker from making ice. When I start running low on ice, I push the metal arm(?) back down for it to make ice again. Hope this is the solution for your Kitchen Aid too.
Jul 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
Sub-Zero 642 ice maker
When the drawer is opened, trhe "full arm" swings up and out of the way. When the drawer is pushed back closed, the arm should swing back down. If it is unobstructed, the icemaker should make ice.
One thing to try is with the ice tray removed, push the plate (that holds the ice tray) back into the freezer. Lift the full arm up and down. It should easily move and you should be able to hear a slight "click" when moving up/down. If not, you might have a bad switch in the ice maker unit...replacement time.
Mar 25, 2009 | Sub-Zero 642
Dregdrawer full
drain machine, turn off power , get vacuum cleaner nozzle into drawer slot (make sure its dry or u'll have to post a repair for vacuum cleaner repair) remove all deposits for chamber , shake and bang machine to lossen deposits. if drawer has metal clips or something that looks like sensors (does not have to have wires attached to be a sensor) clean !
Feb 02, 2008 | Gaggia Syncrony Espresso Machine
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
