Question about RCA Televison & Video
RCA R52WH74 HDTV started black outs for 10 -40 minutes
RCA R52WH74 HDTV is slow coming up with picture. Has started black outs for 10 -40 minutes when the picture will come back. Is this a consumer repair with parts, or a repair by a service technician?
  • James Alexander
    James Alexander Jun 04, 2010
    unclear as to what is wrong, local repair shops have both Great and Poor reviews, like to have a better idea of what is wrong besides the symptoms.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue is with the convergence ICs going bad and needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself you can buy and repair it yourself.Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 04, 2010
    President:
  • 1,099 Answers
This is a repair by service techanician and can solve by first check for dry soldering, if found resolder , but if otherwise replace the z-sustain board and then check all the fuses again .
Thanks for asking...
Hope this will help out ..
  • 1 more comment
  • James Alexander
    This is a new condition, we have had the TV for more than 2 years.Can a 'dry solder' occur over time?
    the "Z-board", is that a part or unit that may need to be replaced? Any idea of what the costs should be?
  • Sanyade Akinwale
    Sanyade Akinwale Jun 04, 2010
    Hello
    It is possible you can have a dry soldering ,all you need is to check if there is one.
    the Z sustain board cost 160 pounds plus VAT.
    Thanks for the comment.
  • Sanyade Akinwale
    Hello
    It is possible you can have a dry soldering, all you need is to check if there is one,
    the Z sustain board cost 160 pounds plus VAT, try eBay.com.
My rca hdtv r52wh74 the green light comes on and off 3 times and nothing else no picture or sound just goes off
Thats a deflection issue. You can get the ITC222A deflection board Bar code PSB-260 from www.tvrepairworld.com which will usually fix the 3 blink error on that model
Sep 24, 2011 | RCA Televison & Video
I have a RCA R52WH74. When you turn it on there's
replace the deflection board. You need the ITC222A deflection board PSB-260 you can get a replacement deflection board from www.tvrepairworld.com which also has the CD that shows how to remove the old board.
Apr 11, 2010 | RCA HD52W56 52" Rear Projection HDTV
R52wh74 fades to one color then dark, then black
awewryte,
I have the same TV and now have the identical problem that you described. Did you ever get it fixed or find out what the problem was? If so, will you please pass the information on?
Thanks.
Aug 08, 2009 | RCA Televison & Video
When I push the power button on my RCA HDTV R52WH74, the green light turns on for about 5 seconds and then off. NO sound and no picture.
Sounds like the bulb went out.
Go to http://www.purelandsupply.com/RCA-Projection-TV-Lamp.html and order a new bulb for under $200.
They are easy to intall; a screwdriver and 10 minutes.
Jun 24, 2009 | RCA R52WH73 Projection Television
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
Problem with my rca projection television
my RCA R52WH74 HDTV IS STARTING TO LOOK BLURRY. ALSOMY SCREEN LOOKS LIKE IT STRETCHING MY TV PROGRAMS....... CAN U GIVE ME A SOLUTION
Mar 16, 2009 | RCA HD52W59 HDTV Projection Television
Locating the ''flyback transformer '' on a rca mod #R52WH74
It is usually large and black. Its the one with the rather thick red wire coming out of it. The other end of that wire either connects directly to the picture tube or into a distribution block which distributes the high voltage to the 3 picture tubes (guns) in projection TV's. Be aware that this transformer produces high voltage and can store voltage even when the set is unplugged. I hope this helps.
Mar 10, 2009 | RCA Televison & Video
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R52WH74 rear proj 52inch...gets dark and then fades to black
Yes ,your set like so many others is one of RCAs biggest mess i would say if under warranty get to service center fast!!!! other wise you might be one of the lucky ones that only needs power supply broad solder start with Flyback transfomer solder all pins.
May 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
154 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
