Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Smoke coming out when i engage the blades - Craftsman 42 in. Deck 19.5hp Lawn Tractor
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
Most likely the mower belt is rubbing and causing this. But don't try to find it with the mower running! With the engine off, lower the deck and inspect the mower belt for worn or burnt spots. The problem isn't the belt, though. Look under the mower deck - is a branch or other object stuck in there? Get it out, and replace the belt if it's badly burnt.
If it's not a stuck object, than you probably have a frozen spindle (the bearings that hold the mower blades) or idler pulley. Remove the belt and spin each of these by hand to find the problem. The pulleys are not expensive, but the spindles are. I hope it's just a branch. Good luck! Please rate if helpful, thanks!
Posted on Jun 04, 2010
3 Suggested Answers
  • 404 Answers
SOURCE: white smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Posted on Jul 16, 2010
suzukiracing
  • 200 Answers
SOURCE: smoke bellows from exhaust and stalls
sounds like the piston rings are worn out.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Posted on Jul 20, 2010
Mower blades won't engage
Did the smoking stop when you disengaged the blades? If so it is most likely your belt that is smoking. Make sure all the blades turn freely by hand to ensure you have not hit anything that may have bent a shaft on one of the blades. If one of the shafts is bent and wont turn FREELY, the belt driving the blades would slip and start smoking as it tried to turn them.
Apr 19, 2015 | Garden
Rough idling & smoke comes out of exhaust
check to see if the choke cable comes in contact with any linkage on gear selector sounds like a choke issue
Jan 21, 2014 | Garden
When I engage the blades, I smell and see blue smoke, so disengaged the blade
Its not the drive belt. You have a bearing or etc. out.
I just have problem. The spindle bearing was bad.
Oct 01, 2012 | John Deere 22HP VTwin 48" Riding Mower
07 mtd yardsman mower with 13.5 tecumseh runs great untill engage mower , then dies down and blows black smoke
This sounds like a micro switch acting up, the first switch to check is the seat switch, make sure the block connecter is pushed fully home on the switch ( there is often a fail safe inside the connecter should the block come away from the switch )
Jul 08, 2012 | Garden
Husqvarna riding mower smokes when cranked and dies when engaging blades
If it dies when engaging the blades it's not getting enough juice to do so. Test the battery and make sure you are getting at least 12 volts. If not, charge it. If so, the solonid is going bad.
Apr 13, 2017 | Husqvarna Garden
White smoke coming out of mower
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Smoke when blades engaged on yardman 42'' yard tractor
The oil on your pulley could definitely be the culprit. You need friction in order for your belts to work properly.
Apr 17, 2010 | Mtd Garden
Engine only runs at low idle and smokes
So now, without the blades engaged, it smokes and then dies?
In your first description it sounded like the engine was under a strain. Overfilling with oil could produce a strain, but since it ran ok until you said you engaged the blades, I would have to ask if the blades themselves, were causing the strain. Sometimes if you cut wet grass, the clippings stick to your underside of the deck and can really build up. Also some rope, wire or twine would around the spindles could creat one. Check this out...
Now, with the "smoke" issue (I'm assuming a blue smoke from burning oil) I'm inclined to think your rings aren't compressing any longer and you're burning oil. You might be in for a rebuild... I hope not.
Aug 31, 2009 | Husqvarna 19.5hp 46" Yard Tractor
White smoke and blade won't engage
Sounds like a low compression problem. The piston rings have most likely failed and oil is seeping past them and burning, thus the white smoke. An engine needs three things to run...Spark, Compression, and Fuel. Just take the mower back as it is still probably under warranty. Mike. Rate 100% please.
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
278 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
