Question about Jolly Giant QWS3270 Secure (QWS3270SECURE) for PC
Need example of code to screen scrape data from host to Excel
I need an example of code to establish connection via Excel, "screen scrape" a field from my mainframe system, and paste it into Excel..
Cannot Establish a Microsoft ActiveSync connection between host PC and MC9090
Motorola MC9090
Motorola MC9090 Target Platform fetch.php?media=installation:symbol:mc9090.jpg This guide is intended for use with a Symbol MC9090 running Microsoft Windows Mobile 5.0. Assumptions
  • Technician should be familiar with connecting the terminal via cradle, USB and ActiveSync.
  • Technician already has the SyVox Client CAB and a grammar CAB (either the generic one or a site specific one)
Installation Procedure
  1. Set up and save your wireless configuration.
  2. Establish an ActiveSync1) connection between your PC and your terminal.
  3. Copy the SyVox Client and Grammar CAB files to the device in a known directory.
  4. From the device, install the SyVox Speech Client and Grammar CAB files by tapping on them from the directory you installed them in.
  5. If this is your first time running SyVox on this terminal, SyVox will request a License Key. Go to the Menu ? License screen where you will be given a screen with a field for your License Key and your SyVox Serial Number (your device's unique identifier). Contact Genesta with the SyVox Serial Number displayed to receive a 16-character License Key for the top field. Enter it and tap OK.
  6. To perform a simple test of your installation after SyVox finishes loading the speech engine, tap Menu ? Options ? Host Settings.... Choose the File option; then select the demo.xml file provided with installation; and, then the OK selection to accept that demo file. Select the Press to START Listening button near the bottom of the screen to begin the demo. Remember to have your headset nearby as the built in microphone is not sufficent for production environments.
  7. Once you are ready to use this device with a remote host, to connect SyVox to a remote host, tap Menu ? Options ? Host Settings.... Select a Connection Method, enter a Connection Address, and tap OK.
    • A Socket host address is entered in the format *.*.*.*:*, (IP or hostname, colon (:), port (optional; defaults to 3001)).
    • A Web host address host is entered in the format http://*:*/ (http://, IP or hostname, colon (:), port (optional; defaults to 80), rest of address).
Notes
Warm Boot
Sometimes Windows Mobile devices require you perform a warm boot. This can be achieved on this device my holding down the red on/off button for approximately 30 seconds. You will know when the warm boot has completed when a white screen is displayed and the unit restarts the operating system.
Cold Boot
Program installations and settings on Microsoft Windows Mobile 5.0 devices will persist even after a cold boot. To achieve the effects of what a cold boot does on other devices, you must perform a clean boot. Because a clean boot requires interaction between a PC and a terminal in the first place, SyVox is currently not designed to reinstall automatically after a clean boot. Therefore, if you perform a clean boot on your terminal, you will have to repeat the procedures listed in this guide. 1) ActiveSync acts as the gateway between your Microsoft Windows-powered PC and Windows CE-powered device and allows you to transfer data between the two. Download it here: http://download.microsoft.com/download/5/4/6/5467c040-a935-4987-aa30-5dcbc36a57db/setup.msi hope that helps
Mar 20, 2014 | Motorola Computers & Internet
How do i publish my site? I have VodaHost as my hosting but I can't seem to get the two to connect
this is very simple, once u finish all works like domain registratin,web design...finaly u have to reach a hosting company to host ur site/publish ur site if u need any hosting assistance have a look at this http://www.tucktail.com/
Aug 26, 2009 | Cosmi Perfect Website Creator (ROM03919)...
CODES for entering an I.D number using vba
Try the help built into Excel and give yourself time to absorb it; Excel has some of the best help in the business. VBA may be more complex than you need to solve a data entry problem. If you're trying to add data input masks in a database, why don't you try Access (the help for which is admittedly weaker because database programming is among the most complex of all productivity apps)? I learned VBA from 3 books I rented from a good public library over the course of a project that was about a month long, (because) at some point Microsoft abandoned the idea of teaching it via help screens. Still, you might join a MS developer site and those are loaded with detailed explanations and many other experts. I hope this helps... I feel your pain.
Mar 22, 2009 | Microsoft Office Excel 2003 for PC
Procedure how to establish aging of account receivable in excel
Once your data has been input into Excel - I assume you can do this via importing an outstanding debtors deport.
The easiest way I can see is by Pivot Table.
Your data should include open invoices and their respective due dates, it will be easier if you could covert these due dates into months - Create a pivot entering customer, outstanding values as your data and due months as your range.
Feb 22, 2009 | Microsoft Computers & Internet
Count with 2 or more criteria
Can you do this using a pivot table where columns B & C are Row Fields and Count of B&C is data fields.
Jan 17, 2009 | Microsoft Excel for PC
Can't connect psp component cables to tv
okay. here's what you need to remember as i encountered the same issue and had it resolved.
1. connect the psp tv out component cable to the tv. make sure you have every cable in their correct plug-ins.
2. on your tv remote, press output until your tv displays the correct output data info. it will display component 1 or component 2. make sure this aligned with where you connected your component cable.
3. turn on the on the psp, then press and hold the display button ( it is near the start and select buttons on your psp, with a box like icon. after 5 seconds, it will give you a gray screen with a box icon and an arrow which means you are transferring the data out from the psp to your tv display.
4. enjoy your psp on tv!
Aug 08, 2008 | Video Game Consoles & Games
Copying data from one sheet to another if two fileds match
Nope, sorry, although I am truly an expert at Excel formulas, I do not understand what you are trying to end up with in the final cell. We can compare a specified field with two spreadsheets - use named ranges and index/match lookup formulas. But then where you really lose me is in reading "a generic field" to find a match, and then placing what "data from another field" into what "other sheet" - ? See the confusion?
Best way to compare 2 given parameters would be to use a nested if formula, with index/match combo. Here is a simple Excel example of how such a formula could be structured:
Sample Data (columnar arangement):
A1: Part B1: Code C1: Price D1: Find Part E1: Find Code
A2: x B2: 11 C2: 5.00 D2: y E2: 12
A3: x B3: 12 C3: 6.00 D3: y E3: 11
A4: y B4: 11 C4: 7.00 D4: x E4: 12
A5: y B5: 12 C5: 8.00 D5: x E5: 11
To retrieve the price for part y with code 12 and return the value to cell F2, type the following formula in cell F2:
=INDEX($C$2:$C$5,MATCH(D2,IF($B$2:$B$5=E2,$A$2:$A$5),0))
Press CTRL+SHIFT+ENTER to enter the formula as an array formula. The formula returns the value 8.00.
To take this one step further, with range names, this example will find one value at a specified location which matches a specific row header value and column header value. Let's say the range is home values (Range=HomeVal), Column A of HomeVal contains street addresses,"row headers" (Range=StAddress), and Row 1 contains dates of the various values that are in the body of the table, "column headers" (Range=Dates). To return the specific value from the range HomeVal to another sheet, where A1=address specified and A2=date specified:
=INDEX(HomeVal,(MATCH($A$1,StAddress,0)),(MATCH($A$2,Dates,0)))
Then make sure to press CTRL+SHIFT+ENTER to enter the formula as an array formula - if you only hit enter, these types of formulas will not work properly.
Please post back if you need further help, with more details, otherwise thank you for using and rating FixYa!
Jul 08, 2008 | Microsoft Computers & Internet
Access 2007
Breaking a field's title on a report into two line is done in the form design screen. Data table view does not support you need.
Jun 24, 2008 | Microsoft Office Professional 2007 Full...
Excel
Hi, Pivot tables are quite complex but basically you have a table of data which you sort based on different fields from your table.
Send me your email address and I will email you further instructions with an attached example file ok.
Regards
SeaJade
Mar 01, 2008 | Computers & Internet
Export data in excel shld yoeet through VB
When i first figured out how to pull data from SQL and put the results in an excel file i referenced these two articles....
Reading and writing excel file using VB.NET (http://www.codeproject.com/KB/vb/Work_with_Excel__VBNET_.aspx)
Get the Values From DataBase and Stored into excell Sheet (http://www.codeproject.com/KB/vb/Getvaluesfromdatabase.aspx)
This is the code i ended up using.... (check out those links to see how you need to import the ms office excel reference file with visual basic)
Const stcon As String = "Provider=SQLNCLI;server=xxxxx;database=xxxxx;uid=xxxxx;pwd=xxxxx;DataTypeCompatibility=80"
Dim stSQL As String = "select * from scs_rate_class_money where irate_book = 124 and snew_used = 'U' and sclass = '2' and splan = 'T4' and sopt_code = 'F1'"
Dim cnt As New ADODB.Connection
Dim rst As New ADODB.Recordset
Dim fld As ADODB.Field
'Open the connection.
cnt.Open(stcon)
'Open the recordset.
With rst
.CursorLocation = ADODB.CursorLocationEnum.adUseClient
.Open(stSQL, cnt, ADODB.CursorTypeEnum.adOpenForwardOnly, _
ADODB.LockTypeEnum.adLockReadOnly , _
ADODB.CommandTypeEnum.adCmdText)
.ActiveConnection = Nothing 'Disconnect the Recordset.
End With
'Close the connection
cnt.Close ()
Dim exp As Export = New Export()
Dim xlApp As New Microsoft.Office.Interop.Excel.Application
Dim xlWBook As Microsoft.Office.Interop.Excel.Workbook = xlApp.Workbooks.Add(Microsoft.Office.Interop.Excel.XlWBATemplate.xlWBATWorksheet )
Dim xlWSheet As Microsoft.Office.Interop.Excel.Worksheet = CType(xlWBook.Worksheets(1), Microsoft.Office.Interop.Excel.Worksheet)
Dim xlRange As Microsoft.Office.Interop.Excel.Range = CType(xlWSheet, Microsoft.Office.Interop.Excel.Worksheet).Range("A2")
Dim xlCalc As Microsoft.Office.Interop.Excel.XlCalculation
Dim i As Short
'Turn off Excel's calculation.
With xlApp
xlCalc = .Calculation
.Calculation = Microsoft.Office.Interop.Excel.XlCalculation.xlCalculationManual
End With
'Write the fieldnames.
For Each fld In rst.Fields
xlRange.Offset(0, i).Value = fld.Name
i = i + 1
Next
'Populate the range.
xlRange.Offset(1, 0).CopyFromRecordset(rst)
'Close the recordset.
rst.Close()
'Make Excel available to the user.
With xlApp
.Visible = True
.UserControl = True
'Restore the calculation mode.
.Calculation = xlCalc
End With
'Release variables from memory.
fld = Nothing
rst = Nothing
cnt = Nothing
xlRange = Nothing
xlWSheet = Nothing
xlWBook = Nothing
xlApp = Nothing
Jan 03, 2008 | Computers & Internet
Computers & Internet Logo
190 people viewed this question
Top Jolly Giant Computers & Internet Experts
David Payne
David Payne
Are you a Jolly Giant Computer and Internet Expert? Answer questions, earn points and help others
