Question about Hunter Sontera 52" Ceiling Fan with 3-Light Fixture and Remote
MY FAN MADE A ARCING SOUND .. I THOUGHT IT MIGHT BE THE BRUSHED. TAKING THE COVER OFF I DISCOVERED THAT THE WIRING TO THE ARM. WAS BURNED. THE COILS ARE IN TACT THE WIRING IE ACCESSIBLE. HOWEVER.. I CAN'T FIGURE WHICH WIRE TO THE COILS GO TO WHICH WIRE FROM THE AC. CAN YOU HELP ME.. ONE WIRE IS STILL IN TACT. THANKS
  • 17,970 Answers
I think that you can find this information in ceiling fan
Other details HERE (photos and schematics).
Hope helps.
Posted on Jun 04, 2010
Passenger side fan not working, car does not run hot, but the inside of fan is burned and melted.that was the plastic fan cover.
Yes needs to be fixed soon but should not affect inspection depending on the state however it will affect the performance of engine
Apr 21, 2015 | Cars & Trucks
Why is there a burn hole inside the oven, on the cardboard?
That's actually a mica "window" (cover) for the microwaves to come out. And it sounds like the magnetron started arcing and burned a hole in that cover. Either that, or some food (frequently spaghetti sause) got splattered on it, and the microwaves heated it up so much that it burned a hole in the cover. Does the microwave oven still work (heat)? Do you see or hear any arcing? If the microwave oven still works and there is no arcing, you can just replace that cover. Check SearsPartsDirect.com or RepairClinic.com.
Jul 10, 2014 | Kenmore Microwave Ovens
My heat coils stay on when the dryer,only turn off if dial is on off position
A contact in your control switch has failed. Your fix is to order a new one at your local appliance
parts store (or online), and replace. In olden days, these switched were open, and burned contacts
could be "shined" with fine-grit sandpaper, but since appliance manufacturers discovered that old
arcing switch contacts could start fires (due to lint infiltration over time), the switches are now enclosed in sheet metal and must be replaced as a unit.
Apr 17, 2011 | Dryers
Need fan blade arm for Hamton Bay 52 inch Cameron II Plus Model 266028
Contact "King of Fans" (kingoffans.com) in Ft. Lauderdale at 800-330-3267. They made or make Hampton Bay fans. I just ordered an arm for mine. Have your UPC number handy.
Aug 03, 2010 | Hampton Bay 52 In. Cameron II Plus Ceiling...
Clicking sound, not cooling and freezing, water & ice dispenser not working, is lighting and receiving power...
See if the compressor is hot to the touch. Check if the fan is blowing by that compressor. Clean the coils and check the relay. It takes multiple sets of copper windings to get a compressor going but once it is going it takes half as much to keep it going. How do they do it? With a relay. Over time the arcing and amp draw associated with boosting the compressor takes its toll on that relay.
Apr 10, 2010 | GE GSL25JFR Brushed Steel Side by Side...
The canopy doesn't seeem to fit flush up against
You just need to wrap it and tuck it .. You might need to cut some of the fan wires shorter so there is not so much bulk under the canopy cover. The fans are shipped with enough wire leads to be able to use a down rod, They can be cut shorter when the fan is being installed.
Mar 02, 2010 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Microwave is arcing on the antenna blade.
Arcing is often the result of the cover over the magnatron (The thing that produces the microwaves) being aged, burned or damaged. If you look inside the oven, you will see a cover (usually square or round and around 3-5 inches across depending on the machine)made from a flakey silver plastic/fibre material. If this is burned or has a hole, it needs replacing and this will probably cure your problem.
Mar 13, 2009 | GE Microwave Ovens
GE Microwave is arcing inside
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is the plastic ceiling.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced.
If you need more specific help, please reply back with your brand and full model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Nov 13, 2008 | GE JES1384SF Microwave Oven
Hunter cieling fan switch replacement
My switch broke, so I'm in the process of replacing it.
Before taking it apart, I made note of the wire colors:
L=Black
1=Grey
2=Brown
3=Lt Blue
Jul 18, 2008 | Hunter 20761 52'' The Stratford II Brushed...
Hunter Sontera 52" Ceiling Fan with 3-Light Fixture and Remote Logo
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
