Question about KitchenAid Dishwashers
KUDS24SEBS5 Dishwasher. Sitting idle water slowly fills bottom of dishwasher. Have to run to rinse cycle to clear water. Please help?
  • KitchenAid Master
  • 909 Answers
Close water tap off overnight and see if water still comes into machine. If not, your water valve is defective. If it still does, it is comming from the drainage pipe.(water feeding back.)Need to raise pipe about half height of dishwasher.Some units dont have a one way valve.
Posted on Jun 04, 2010
    President:
  • 1,430 Answers
The problem is the water inlet valve has failed. This is easy to replace and inexpensive. Here is a video that will walk you thru the replacement.
http://appliancehelponline.com/dishfloatwaterinletvideo.html
http://appliancehelponline.com/dishwasherwaterinlet.html
I have Hobard LXIH dishwasher, it is working OK but during rinse cycle instead of taking in rinse agent it is actually fill rinse bottle back with water. Rinse pump is working, it was replaced in June
Check the rinse pump. The tubing needs to come from the supply into the bottom of the pump, and the pump should be running clockwise. If the pump tube is worn, the rinse pressure will blow through the pump filling the bottle
Dec 12, 2013 | Hobart Dishwashers
After rinse fill the pump will not start
Hello, is there water in the bottom of your dishwasher? If there is water in bottom. Then try running the dishwasher throught another washing cycle. Now, if there is not water in the bottom of your dishwasher. Then the dishwasher has finished its washing cycle, rinsing the cleaned dishes. GB...stewbison
Sep 17, 2011 | Dishwashers
Water standing in tub
If there is a lot of water sitting inside the applicance, it's possible that the high water float switch has been activated and is preventing the dishwasher from running. Open the door, remove the bottom rack, dip as much water out of the bottom as possible with a shallow ladle or even tupperware container. When that is accomplished, shut the door and try to run a drain cycle. If the unit won't start, you may have to remove more water. You don't have to have the rack in place to run the drain cycle.
Jul 09, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishes are not always dry, even after sitting overnight
hi
make sure you are using rinse aid as this helps to evaporate the water at the end of the cycle in the drying stage. I know tablets have rinse aid built into the tablet but this can wash away on some wash cycles and do nothing so even if you are using tablets i reccommend still using rinse aid.
Jan 24, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Detergent packs are not dissolving
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Apr 21, 2009 | KitchenAid 24 in. KUDS02SRSS Stainless...
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Bosch dishwasher will not drain - causing moldy odor
Hello Mimhoff it depends on how much water is down there. The sump area always has a little water in it to prevent the circulation pump seals from sticking. Usually around 1 to 2 inches. If there is more than that, check the slots at the bottom of the sump on the left side for being clogged and check the end of the drain hose to make sure it is clear. If you are getting a moldy/odor from the dishwasher, try running Dishwasher Magic or Tang thru the dishwasher. This will remove any build up of food or detergent from the dishwasher. If you are running the dishwasher every few days and just scraping your dishes, then either leave the door ajar or run the rinse & hold cycle to help keep the odor down. Bosch doesn't reccommend running bleach thru the dishwasher as this can cause damage to the rubber seals. However 2 tablespoons of bleach once a year won't hurt.
Feb 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher fault
If you have tried to run any cycle and still end up with this problem, then most likely a failed timer unit. The next step is for the water switch to enact the next step which is to start the timer.
Jun 17, 2007 | Electrolux 18 in. ESL424 Built-in...
Dishwashers Logo
104 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
