Question about Dryers
My dryer squeels when you first turn it on. Once it gets warm, it stops
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
DryerMy dryer squeels when you first turn it on. Once - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on Jun 08, 2010
My dryer won't spin and is squeeling
It sounds like either the belt is loose or the drum is frozen. Try the following links to see if they help.
Appliance411 Home Service Appliance Repair Manual for Whirlpool Kenmore...
This will help if you have never repaired a dryer.
User Manual Downloads
Feb 05, 2016 | Kenmore HE2 6.7 cu. ft. Gas Super Capacity...
Makes a squeeling sound when I turn on my dryer. Could be the belt.
The squeal is probably the wheel on the bulkhead nearest the heat source. This dryer is not hard to repair. If yall know the trick. Get the door off first and then you can remove the front panel. Once the panel is off that exposes the hooks that hold down the top. Once you get the top up you can get the drum out. Use zoomspout oil to lube the wheels and idler. It is safe for dryers and heaters.
I wrote about it and included a service manual HERE
Feb 05, 2011 | Maytag Neptune MDE5500AY Electric Dryer
MATAG DRYER, MAKES A VERY LARGE HIGH PITCH SQUEEL
heatman101
Apr 15, 2010 | Maytag Dryers
11087088601 dyer squeels at start; will stop after a bit
The belt is loose and is most likely due to the belt being stretched out. Replace the belt and the tensioner also to solve this squeal.
Apr 14, 2010 | Dryers
How do you get access to the turning drum of a heavey duty large caapacity dryer. The drum is sqeeling
first thing, check on the rear of the dryer there should be a sleeve bearing in the center of the back panel try some lite lube and see if the squeel stops if so you will need to replace that sleeve bearing
Oct 17, 2009 | Dryers
Whirlpool dryer, elctric runs but squeels. sometimes it stops squeeling once it's run for a while but lately it seems to do it the whole time. it does get quieter after it's run for a while
sounds like your "Drum Glides" need replacing, open the door and cheat the door interlock and you should be able to hear it closer by bottom of drum by lint filter if yours is located there depending on model
Jul 28, 2009 | Dryers
Motor Pulley Squeeling - Maytag MDG5500AWW
try spraying wd 40 on the motor ends to see if it will stop if not try the rollers normally they go bad and make the belt squeel.
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Squeels at start for first two seconds
The squeeling could be from a worn belt or if oil drips on belt overnight. Replace the belt first to see if that fixes it.Good luck.
Dec 30, 2008 | 2002 Jeep Liberty
Maytag Dryer squeeling
Drum support rollers. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Maytag Neptune MDE5500AY Electric Dryer
62802 stops running after a few minutes
It sounds as if you have a defective drive motor.  After the motor runs for a while and heats up, the internal thermal switch cuts it off before it gets too hot and becomes a hazard.  Once the motor cools down and the thermal switch makes up again, it will run and then repeat this process.
Oct 15, 2007 | Kenmore 62602 Electric Dryer
Open Questions:
Dryers Logo
60 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
