SOUND DRIVE HAS FORMATED - Computers & Internet
My netbook boots only to the word window
Sounds like the HDD is corrupted what you need to do is goto the drives manufactures website and download their hard drives utilities software,
follow the instructions on how to make a bootable disk then shut down the computer reboot and run the utilities software, if you have nothing you need to save off the drive, Then do a low level format this can take upto an hour or more depending on how big the drive is
once you have done the low level format (this wipes everything off the drive) then reboot the system and format the drive in windows this will rewrite the master boot record in windows format
some manufactures don't have a format utility because there are so many differentsystem file formats.
Feb 28, 2011 | ASUS Eee PC 1000HE Netbook
Cd/dvd isnt recognized in windows xp
There are many compatibility issues still with CD/DVD formats and disk drive manufacturer's.
Check the format of the disk (CD-RW, CD+RW, etc...)
Sounds like the drive isn't recognizing the format this disk was written in. Google CD/DVD format types for a better understanding.
Jan 10, 2010 | Computers & Internet
IBM deskstar 120 GXP 40GB will only format to 22GB. Its an old drive setup in an external usb enclosure
sounds like you're trying to format with FAT 16 or 32 which limits the partition size.
Try formatting with NFS which has no limit on partition sizes
Oct 25, 2009 | IBM Deskstar 120GXP 40 GB Hard Drive
64GB Kingston DataTraveler won't format
Try using someone else's computer to format it. If that doesn't work .... then it sounds like the drive itself has sustained physical damage. I would contact whoever sold it to you and ask them for a Return Merchandise Authorization (if you bought it recently) because it is probably dead.
Jun 12, 2009 | Kingston Technologies 512MB DataTraveler I...
Ibm pc did not sound i need a sound drive for install i already formate the sys dont get the drive
ibm pc did not sound i need a sound drive for install i already formate the sys dont get the drive
May 18, 2009 | IBM 16 bit for ThinkPad Sound Card
Does not boot from SATA drive.
Hi Grumpy
It sounds like your mainboard is not set up to allow for a SATA boot drive.
Have a look in your bios and ensure the boot order is set to the SATA drive first
Then, make sure the SATA drive is formatted and has an operating system installed.
Alternatively, boot the system from a boot disk ( your XP or Vista disk will allow this) and check to see if the board can see the drive and can read the drive if it is already formatted.
If not, format it and install the O/S onto it and make sure you answer YES to the question " do you wish to boot from this drive?"
Both my systems use SATA drives and I only had a boot fault because the "pre-formatted drive" I bought was not formatted and formatting under windows during O/S installation solved this issue..
Swoop...
Sep 09, 2008 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Formatedmy sansa e250 ntfs
To format it..on your device..go under..menu, setting and there should be a format option option there.. or you can change the device mode to MSC instead of MTP and right click on the drive which is listed under my computer and click on format..
let me know if that doenst work for you...
Hope this helps
P.S.Please rate accordingly...
Thank You
Computerrep
Jul 30, 2008 | SanDisk Sansa e250 MP3 Player
Floopy drive
Sounds like you have a bad floppy drive. If you are unable to read a disk and it wants to format it so it can read it try letting it format a floppy with no data on it or with floppy you don't care about. If it can format and you can read and write to it, then bad disks. If not then you know you have a bad floppy drive. Replace and enjoy.
Feb 12, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
