Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
My TV is 'stuck' on. Can't make any changes or turn it off....need help. The remote doesn't work nor the 'manual' buttons on the side. Absolutely nothing happens when I attempt to change the channel, volume, or turn it off.
    President:
  • 1,961 Answers
You need to open the cover of your tv go to the mainboard.at the mainboard there is a small switch soldered on the board it is the reset switch press it to reset the system and your system will work out fine..tnx and goodluck..
hope i help you.
please rate my help..
Posted on Jun 04, 2010
Why is my remote control not working despite changing the batteries.
Not sure if this will help but, I recently put an antenna on the roof of my house. I don't watch TV much but wanted to enjoy some TV, but my remote locked up and the side buttons on the TV wouldn't work either. I tried changing the battery, but no luck. There's a broadcast station 64.2 that is locking up TV's & remotes. Here's the fix that a TV repair co. gave me which did break the lock of the station 64.2.
1) unplug antenna (not roof but connection from TV to wall)
2) unplug and plug back in TV
3) find a way via remote or side buttons to scan channels
4) Go to Menu
5) EZ Setup
6) Channel Set Up-Scan Channels
7) Channel Memory
8) Digital Set Up
9) Turn Skip On for 64.2 (Delete this Channel)
10) Turn off TB
11) Hook Antenna back
You may have to play with the order to acheive the end result or figure out a way to delete 64.2, but during the process you will at least unlock from being stuck on 64.2.
Good Luck if this was the same issue!
Jul 14, 2014 | Audio Players & Recorders
Hisense tv input stuck
hi take the leads out that you have on the vidio as the tv is wating for you to plug your camra back in if this dose not work threr shoud by a reset button on the back some were thank you
May 19, 2013 | Televison & Video
My westing hous hdtv is stuck on channel 35-3 and will not switch to another channel, the remote doesn't work and neither do the buttons on the side of the tv, the power button works but won't
Try to unplug power from set for a while and plug back to reboot--immediately delete that channel from the set's memory as it may contain signal that is causing this.
Also look to see if the set has a feature to lock out the buttons and or the remote control---a few do.
Most likely something in the signal for that set caused the set to lock up.
Sep 02, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
I have a ge universal remote and a panasonic tv but i dont have the directions on how to program it or what the codes are to set it up. i need step by step instructions.please help
There are two types of GE universal remotes. Does your remote use the 4-digit code or the 3-digit code?
These codes listed below are not for combination TVs (TV/VCR, or TV/DVD). If you have a combination tv, see the appropriate code list here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
The 3 digit codes for Panasonic TVs are 003, 054, 055, 062, 070, 148, 149, 170, 171, 374, 381, 437 . If you have an LCD or Plasma Panasonic only try 170.
The 4 digit codes to try for Panasonic TVs are 1182, 0171, 0148, 0054, 0170, 0062, 0374, 0381, 0437, 0950, 0003, 0070 .
Next to program the remote: Turn on the TV manually. Press and hold the Code Search or Setup button (depending on your remote). Hold the button until the indicator light comes on and then release it. Then press and release the TV button. Type in the first code for your remote and TV combination. The indicator light should go off. Then point the remote at the TV and see if the TV turns off. If it doesn't, repeat the above steps. Once you have a code that seems to work, check if the remote controls all of the functions that you need (based on the available buttons on the remote). If you have a code that turns off the TV but doesn't control other functions, continue trying other codes.
There is an option to search through all of the codes of the remote to program the remote. Press and hold the Code Search or Setup button. Release the button when the indicator light comes on. Then press and release the TV button. Now press and release the Power button on the remote repeatedly and wait until the TV turns off. Do this slowly (pressing the Power button every 2 seconds). When the TV turns off, press Enter on the remote to save the code. Then test the remote. If the remote doesn't control all the functions of the TV that you want it to, then repeat the search.
Please note that the codes in most universal remotes are limited to those for devices released 6 months or more before the remote was programmed. If your remote is older than your TV, then you may need a new remote.
I hope this helps.
Aug 06, 2011 | GE JASRM24912 Remote Control
My tv was playing fine when I turned it off. Later, I drop the remote prior to attempting to turn the tv on.Tv will not turn on with or without remote.
OK, YES you CAN turn on the TV without the remote, in fact you can do nearly everything that can be done on your remote, on the TV itself, NOW look, CAREFULLY around the edged or sides of your set, you will find there are "Buttons" usually there are 6 - 7 Buttons, if you look carefully at them you will see they are marked, usually with a Volume Up & Down, word, or symbol, A Channel Up & Down, buttons a Menu, an Enter, and an ON/OFF button, & sometimes others. Now To turn on, Press and hold the Power button, the TV will Turn ON, you can change Channels, with the Channels, and Volume, with the Volume ones. The Menu button, will allow selection to all the other sub menus and settings. IF you need to get a remote, Please, get an original, it may be more hassle, it may take longer to get, it maybe costs more... BUT IT WILL WORK. Universal remotes, well, read through a few posts dealing with them, and you will see what I mean. IF you MUST get one, absolutely ensure that it performs every function the original one did, or you can have many headaches.
Apr 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
Tv is stuck in video mode
The best thing to do is get an original replacement remote and then you will absolutely be able to enter the menu and perform the autoprogram.
Aug 23, 2007 | Sanyo DS27820 27" TV
Quasar TV
Is there no buttons on the set to adjust the volume??? I've never seen a tv that didnt have at least under a door somewhere. Do you have an owners manual? You can get a universal remote to get this to work Good Luck!
Apr 14, 2006 | Quasar TP-917 9 in. Television
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
259 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
