Question about Jandy Pool & Spa
Aqualink RS4 reads code 6700 REV C
Aqualink RS4 reads code ''6700 REV C'' and all the display lights are activated. Pool heater and filter and spa seem to be working fine . Changed battery, but not the problem. This happens one day and not the next.
  • 1 more comment
  • medmoth Jun 04, 2010
    Could I get a little more detail on where the sensor device is located and what it looks like. Thanks
  • medmoth Jun 05, 2010
    Now the display reads 6758 REV C. Any further info on this code?
    That was the dumbest answer ever! Of course it's an error code. I already said it wasn't the battery. Pretty obvious that there is something wrong. If this is "expert" advice, then I am disappointed in this site.
  • 10,865 Answers
The display '6700 REV C' is the controller part number and the version of the Micro Controller. The only instances this would be displayed would be when:
  • one or both of the communication wires (yellow & black) is/are not connected or wire/line open;
  • connectors/terminals are corroded;
  • firmware/software glitch.
Corrective action would require:
  • momentarily pressing on the reset button located on the left side of the indoor controller;
  • checking/repairing/replacing the 4 conductor cable.
  • Should this be not corrective, then a Jandy Service Controller (P?N 7057) would be required to diagnose/check programming and configuration/settings. Unfortunately, this device is not a user unit and would require an authorized service personnel. Joe
Posted on Jun 04, 2010
    Brigadier General:
  • 4,090 Answers
If either of the communication wires are broken ("open circuit"), but the power supply wires are connected,
the display screen will indicate a break in communication by displaying the controller part number and the
version letter of the Micro Controller (e.g., 6543 REV B01 or 6700 REV C).
Pressing the Reset button, located on the left side of the Indoor Controller, will momentarily display the
software part numbers and revision letters for both the Controller's Micro-controller chip and the Power
Center's PPD chip. The Reset button also resets the Micro-controller, but does not remove any programming,
AUX labels, etc. (see chart on Page 16 for list of Part Numbers).
Time/Date Backup: Supplied by 9-volt battery located at Power Center
Programming and Memory Backup: Stored in EEPROM on Power Center PCB, stored indefinitely,
even with no power to unit.
Thanks for using FIXYA
Posted on Jun 06, 2010
  • dennis bullard Jun 06, 2010
    Forgot to mention i have the service manual if you would like it. I would need your email address.
    mine is admin@nettiser.com.au
  • medmoth Jun 06, 2010
  • 6,993 Answers
the error code means that there is something wrong. I wouldn't know precisely what's wrong, but there is something not right with the Aqualink RS4, that's why its displaying the code. The code is an error code. Its not a battery problem.
I will advice that you reset the Aqualink RS4 and observe is the error will display.
Take care.
Posted on Jun 05, 2010
    Genius:
  • 1,417 Answers
It is a wiring problem
The "6700 REV C" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
WHOEVER, sensor reading is out of range (below 23 degrees F or above 217 degrees F)
what you need to do to fix up the problem is to unscrew (OPEN ) it and then clean up all form of water on the wire and change any wire that have gone bad after all this the problem is solve
Thank you and thanks for using fixya.
    Water temperature WHOEVER? What does that mean?
Display panel shows 6522 Rev HH
check wiring to controller either wires touching at plugs or wires cut
Sep 11, 2012 | Jandy Aqualink Rs4 One Touch Control...
I have an aqualink RS8, which controls the on/off timing of the pool/spa, fountain feature, solar heater and yard lights. 1 - the display reads "6520 rev hh" 2 - the spa has been turning on by...
first disconnect the spa side remote if they go away replace the spa side remote if they don't go away go to system setup and go to programs either cancel if all button or delete or edit if one touch or PDA
May 25, 2011 | Jandy Aqualink Rs4 One Touch Control...
My Jandy Aqualink, all the buttons are lite up and the display says 6700 REV C
This is a common problem with the communication between the RS Aqualink remotes and power centers. These can be fixed quickly and reliably at www.fixyourboard.com
May 21, 2010 | Jandy Aqualink Rs4 One Touch Control...
Jandy aqualink says Firmware Rev B11?
my pool power is on but the remote in the house does not work.
firmware rev b-11 is showing on the display and the display lights up.
what could be the problem?
Apr 11, 2010 | Jandy Aqualink Rs4 One Touch Control...
Spa does not turn off.
There SHOULD be a valve that you can close to disable the spa.
Sep 27, 2009 | Jandy Aqualink Rs4 One Touch Control...
Pool & Spa Logo
2,888 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
