Question about Individual Nuance Kai's SuperGoo 1.5 Full Version for PC, Mac
Kais supergoo will not install on my PC running
Kais supergoo, version 1.5 will not install on my PC running windows . What could I do?
Thanks.
Kais supergoo download
There is no more any official download.
For a little fee of 5$ (to buy me some cigarettes) I will send you a working copy of my installation. It works with Win7 (32 and 64 bit)
anuncipar@gmail.com
May 02, 2014 | Individual Nuance Kai's SuperGoo 1.5 Full...
I have PrintMaster Premier 8.0, I would like to install on my computer running windows 7. It will not download. I do not want to purchase another version. Is there any updates that I can download to allow...
1. These instructions from Microsoft will explain how to run a compatibility troubleshooter for your software.
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
2. Contact Broderbund directly at 800-395-0277. I use their Print Master software also and they are very helpful at the customer service area.
Sep 11, 2013 | Mindscape PrintMaster Premier 7.0
Installing windows
How can I help with Installing Windows? and waht version of Windows is it Vista, XP, Windows 7 and what versions? is it Home basic, Home Premium, Enterprise so on....
Aug 29, 2011 | Sylvania G-Netbook
Will not function with Windows 7, what is wrong?
Not all programs that worked in Windows XP will run in Windows Vista or Windows 7.
I suggest you try compatibility mode to see if it helps.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1) Right click on the Program
2) Click on Properties
3) Click on Compatibility tab
4) Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
If the compatibility is not successful, then try and runthe Program Compatibility troubleshooter:
1. Open the Program Compatibility troubleshooter by clicking theStart button.
Then click Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, clickRun programs made for previous versions of Windows.
2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
If you run Windows 7 Professional or Ultimate version, install Windows Virtual PC and Windows XP mode (http://www.microsoft.com/windows/virtual-pc/default.aspx) and execute your software in Windows XP.
If you run Windows 7 Home Premium, try VirtualBox (www.virtualbox.org) or VMware Player (www.vmware.com) and install a separate copy of Windows XP (either Home Edition or Professional) for that purpose.You can find virtualization software free of charge that will run on Windows 7 Home Premium.
Hope this helps.
Oct 28, 2010 | MGI Software PhotoSuite 3 for PC
Cannot install supergoo1.5 on windows 7 64bit
Me too . I'm right now trying to run super goo on window 7 but it says ' the default axiom application resource environment could not be found '
Sep 06, 2010 | Individual Nuance Kai's SuperGoo 1.5 Full...
Is it possible to upgrade windows xp professional x64 to windows 7 professional x64
Hello
Yes it is.
Just make sure you download or purchase Win 7 x 64.
If your doing the upgrade you need to have winxp x 64 installed on your pc first.
Jun 10, 2010 | Microsoft Windows XP Professional for PC
Kais supergoo will not install on my laptop running windows 7, error to do with 32bit and 64 bit opperating systems??
Find anyone who uses XP.
Install SuperGoo there.
Copy the the whole Folder where Super-Goo is installed to a stick.
Copy this folder to your computer (programm files (x86)).
Run the program - it works.
Apr 09, 2010 | Individual Nuance Kai's SuperGoo 1.5 Full...
Can i convert a 32 bit to a 64 bit
You can use the Upgrade option during Windows 7 installation, which preserves your files, settings, and programs, only if you're currently running a 32-bit version of Windows Vista and you want to upgrade to the 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only perform an upgrade to a 64-bit version of Windows 7. For more information, go to Upgrading to Windows 7: frequently asked questions on the Windows website.
If you want to move from a 32-bit version of Windows to a 64-bit version of Windows 7 or vice versa, you'll need to back up your files and choose the Custom option during Windows 7 installation. Then, you'll need to restore your files and reinstall your programs. For more information about performing a custom installation, see Installing and reinstalling Windows 7‍.
gl_ico.png Notes
  • To install a 64-bit version of Windows 7 on a computer running a 32-bit version of Windows, you'll need to start, or boot, your computer using a 64-bit Windows 7 installation disc or files.
  • If you start your computer using a 64-bit Windows 7 installation disc or files, but your computer isn't capable of running a 64-bit version of Windows, you'll see a Windows Boot Manager error. You'll need to use a 32-bit Windows 7 installation disc or files instead.
  • Windows Easy Transfer can't transfer files from a 64-bit version of Windows to a 32-bit version of Windows. If you're running a 64-bit version of Windows Vista but you plan to install a 32-bit version of Windows 7, you can move your files to an external location manually or use Backup and Restore in Windows Vista. For more information, go to Back up your files and
Apr 08, 2010 | Dell Precision Workstation 490 - MT -...
Cant get windows installer and java to open even after downloaded
Method 1
Unregister Windows Installer, and then reregister Windows Installer. To do this, follow these steps:
1. On the "Start" menu, click "Run:.
2. In the "Open" box, type "msiexec /unreg", and then press ENTER.
3. On the "Start" menu, click "Run".
4. In the "Open" box, type "msiexec /regserver", and then press ENTER.
Method 2
Upgrade to Windows Installer version 2 or newer version. To do this, follow these steps:
1. Start Microsoft Internet Explorer, and then browse to the following Microsoft Web site:
http://msdn.microsoft.com/downloads
2. In the left pane tree menu, click "Setup and System Administration", and then click "Setup".
3. Click "Windows Installer", and then click the appropriate link for your operating system.
4. Click "Download" to download and install Windows Installer version 2 or newer version.
Method 3
Use Windows Installer CleanUp Utility to uninstall the failed product.
Description of the Windows Installer CleanUp Utility
http://support.microsoft.com/default.aspx?scid=kb;en-us;290301
Method 4
The Windows Installer service may disabled on the machine.
1. Go to "Start" -> "Run" , type "services.msc" and press on "Enter" button.
2. Double-click on the service named "Windows Installer".
3. Check the value in the "Startup type:" field. If it's currently set to "Disabled", then this is the
problem. Change it by selecting "Manual" from the drop-down box.
courtesy:- support.microsoft.com
Nov 01, 2009 | HP Computers & Internet
Internet disconnects on using mozilla,safari,google chrome except internet explorer
This solution depends on how long ago you installed all 3 Browsers on your system.
I'm assuming you're using a Windows PC running Windows XP or Windows Vista
1- First, you want to uninstall Safari and Google Chrome (one at a time) from your PC. These two browsers are new to PC's and are not fully debugged/tested yet.
2- after uninstalling both, restart your computer 1 time.
3- After starting up again, start Firefox and try to surf to a website you haven't tried before on it.
4- If unsuccessful, check which version of Firefox you're using. If it is older than version 3.01, use Internet explorer to go to their website and download the new version.
5- uninstall the old version of firefox first, before installing the new version (always follow this rule for all future program installations, unless otherwise stated in the instructions for the program)
6- Once you have the new version of Firefox installed, run it and check for internet connectivity.
7- Firefox may ask to get settings from Internet Explorer at some point, say yes.
Let us know how it goes and rate us. :)
Jul 19, 2009 | Microsoft Windows XP Professional SP2 Full...
Individual Nuance Kai's SuperGoo 1.5 Full Version for PC, Mac  Logo
291 people viewed this question
Top Individual Computers & Internet Experts
john smith
ka4iup
ka4iup
k24674
Are you an Individual Computer and Internet Expert? Answer questions, earn points and help others
