Question about Muratec F320 Plain Paper LED Fax
Alarm says replace drum soon. Can the message be
Alarm says replace drum soon. Can the message be reset to go away?
    Genius:
  • 1,218 Answers
The "replace drum soon" indicater is a warning for you to have a new replacement drum "on-hand". Soon the display will change to "REPLACE DRUM" AT WHICH TIME THE UNIT WILL STOP PRINTING.
When the new drum cartridge is then installed...the REPLACE DRUM indicator will be reset. DO NOT replace the drum before the machine says to.
Posted on Jun 07, 2010
How to reset " replace drum" for brother MFC-7860DW
Time to really order a new drum and really replace with a new one.
Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
2.Replace the drum unit and toner cartridge into printer.
3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
4.To clear this error message, you need to reset the drum counter as instructed below.
5.Make sure that the machine is turned on.
6.Press Options.
To confirm you are installing a new drum, press 1.
7.When the LCD shows Accepted, close the front cover.
8.Your drum is now reset.
Jul 30, 2014 | Brother MFC-7860DW Laser All-In-One
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
I recently noticed a message that said "drum end soon" on the screen portion of my printer. With that I went and replaced the drum and toner. The problem is this: The "drum end soon" message never quit...
This message would continue to appear if the drum unit counter was not reset when you installed a new drum.
To reset the drum unit counter, follow the instructions below:
  • Press Menu on the Control Panel.
  • Press the Up or Down Arrow key to select Machine Info..
  • Press OK.
  • Press the Up or Down Arrow key to select Reset Menu.
  • Press OK.
  • Press the Up or Down Arrow key to select Drum.
  • Press OK.
  • Press 1 to reset the drum unit counter.
Thank you !!
Jun 09, 2010 | Brother MFC 7840W Printer
Change drum soon message won't go away after changing drum and toner. what do I need to do?
35YRTECH, aren't you being a wee bit flippant? I just changed my drum, had the same problem, and no where in mys instructions does it tell me how to inform the printer that I did reset the drum.
Anyway, here's how to do it (form the brother web site)
  • This message would appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
    1. Open the front cover.
    2. Press the Clear/Back key.
    3. Press 1 to reset.
    4. Close the front cover, pressing firmly on each side until they click into place.
Jan 07, 2010 | Brother Office Equipment & Supplies
Brother 8360p says change drum soon
You have to open the front door and then press options, should see Replace Drum? just answer yes.
Sep 09, 2009 | Brother MFC-8440 All-In-One Laser Printer
Intellifax 4750e, prompted us to change the drum soon. We did change the drum but it is still telling us to change drum soon.
We went to Brother website and obtained a manual and we were forgetting to reset the counter. Once the counter was reset, the message went away.
Jan 13, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
"Change Drum Soon" Message; not change when we changed the drum.
Description:
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
Aug 07, 2008 | Brother MFC-7820N Laser Printer
Continous 'change drum soon' message after I change the drum.
5750e fax machine: To reset the drum counter follow the instructions listed below :
Get the message to appear in the LED
2. Remove and Re-insert Drum/Toner unit
3. Press the CLEAR key.
4. Press 1 to reset.
5. Close the front cover, pressing firmly on each side until they click
into place.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000007572&Sympt=Why+does+the+message+CHANGE+DRUM+SOON+continue+to+appear+on+the+LCD+display+after+I+replaced+the+drum%3f&Model=58&ProductGroup=2&Keyword=Change%20drum%20soon%20message&ProductID=PPF5750e
Jul 08, 2008 | Brother Office Equipment & Supplies
Replace Drum Soon Message
Read your manual. There is a counter that goes off, that can be reset when you change the drum.
With power on and front cover open press set, then select reset drum
Mar 25, 2008 | Brother MFC-7820N Laser Printer
Drum on Brother MFC-7420
Why does the message "CHANGE DRUM SOON" continue to appear on the LCD display of my Brother machine, after I replaced the drum? Description: This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below. Open the front cover. Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO". Press 1 to reset the drum count. Close the front cover.
Jul 27, 2007 | Brother MFC 7420 All-In-One Laser Printer
Muratec F320 Plain Paper LED Fax Logo
984 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Ben
Ben
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
