Question about Maytag Neptune MAH5500B Front Load Washer
Water not draining
Our Maytag Neptune machine, after it has completed a cycle, is not draining the water out. All of the water is just sitting inside the machine.
Please help.
  • 159 Answers
It must have drained water out at some stage because it got to the end of the cycle.It sounds as though the pump may be blocked.The pump can be gotten to by removeing the rear panel on the back of the machine,make sure the machine is unplugged.water will come out so first try syphoning the water out of the machine.if the drain hose comes out from the bottom of the machine then just lay it down into a bucket to get the water out.
Posted on Jun 04, 2010
Mah7500aww
what it sounds like is the drain from your house wher the washing machine drain hose hooks into is daraining slow so after it spins and pumps the water out the pump shuts off but the drain hose is syphoning the water back into the machine,theres probally lint built up in your drain pipe
Jul 09, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Water leaking from my Maytag Neptune model FAV6800AWW Serial number 15646382GA Leaks during wash cycle imediately and during complete cycle. Enough water to saturate 2-3 towels and clothes come out...
Could be a Tub Seal leak my 1st choice. Could also be a leak caused by a cracked outer tub, issues from the hoses from the drain line connections to the drain pump, drain pump and or drain line.
Are you going to try to DIY the fix?
Sep 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune front loader always retains water after the rinsing cycle is complete. This has lead to mold in the door gasket and a moldy smell. Is it normal for water to stay in the machine after the...
pump is probably clogged not allowing all water to drain out. Should never see water in the tub at the end of a cycle. About once a month you should run your washer through a cycle with hot water and bleach. Doing that should keep the moldy smell down.
Mar 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
There is always water in the drum even after a laod but after it sits empty the tub fills with more water
This might be a problem with your locking mechanism which is preventing the washer from actually performing a complete spin cycle. It will drain and appear to function but the high speed spin never actually takes place.
Aug 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have sitting water in bottom of outer ring after wash cycle.
The Neptune will typically have a bit of water in the front seal area after the cycle.
Take a towel and wipe the area clean and dry after heavy loads. There is a drain in the bottom. Wiping this area will help keep the drains clearer and help prevent ordors too.
Jul 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water leaks from the bottem of Maytag Neptune front loader
Your sewer drain may be backing up.
Check the drain during a final spin.
Feb 26, 2009 | Maytag MAH8700AWM Neptune Front Load...
Maytag Neptune MAH5500B Front Load Washer Logo
233 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
