Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
Engine dies when throttle is given - Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
  • 420 Answers
Typically those symptoms indicate the engine is not getting enough fuel, the first thing to check is to make sure the fuel/oil is fresh as over time the gas evaporates and leave a mixture with too much oil. Once you do that start it up and look for air bubbles in the fuel line(s), if bubbles are present you have a tiny air leak and that's all it takes to make them not want to run on high speed. If no air bubbles are present then the high speed circuit is at fault and the carb must be disassembled and cleaned or replaced.
Posted on Jun 04, 2010
Why does my Vintage Cub Cadet 125, Kohler 12HP engine pop/backfire and die when given any throttle?
Carburetor needs adjusted. May need rebuilt or just cleaned. Could be one of the jets is plugged.
Jul 19, 2014 | Cub Cadet Garden
What is causing my 12hp kohler engine to backfire and quit running when given any throttle?
That sounds like either bad (old) gasoline or the carburetor needs cleaning very badly - it's running very lean.
Jul 19, 2014 | Kohler Engine 12hp Cs Command Horizontal...
Son has a 1992 GMC Sierra 2500 2 wheel drive with a 454 engine. Has been using an excessive amount of fuel. Stalls at stop lights and then has to feather the gas pedal or will die. Replaced the Dis
If it has a caby then check why the float is not controlling the needle and seat that controls the amount of fuel into the carby. Check the needle and seat for something like a hair or the rubber on the needle is cracked or the seat is loose in the carby body. Concentrate on the carby as the over fuelling problem is in that area. Check that the choke is not coming on
Dec 14, 2013 | 1996 GMC Sierra
Hd 96 roadking efi. Idles ruff and when given gas in gear wants to die unless i give it full throttle. Put in new wires and plugs and after a few minutes of running plugs were black. Also back fires when...
Check the air filter is clean, and the ignition for correct operation. The plug indications are that the engine is running rich (too much fuel) or that the ignition spark is weak.
Mar 17, 2012 | 2000 Harley Davidson FLHR-FLHRI Road king
'93 chevy lumina euro dies when given gas
Is yourd check engine light on? If it is, I would have the codes read first thing. If not, it could be clogged fuel filter or air filter, loose vacuum hose, or bad throttle position sensor or other sensor but the sensors or any electrical problem will set off check engine light.
Jun 24, 2009 | 1999 Buick Regal
Troy-Bilt TB75SS 31cc string trimmer dies when given throttle.
Your carburetor needs cleaned. Disassemble carb. and spray with carb. cleaner. Make sure that the small screen is free of debris. Use a Den Tek Brush,
(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Reassemble and start. If this doesn't work for you then you will have to buy a carb. kit and replace all appropriate parts. If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
Starts but won't stay running
Have someone help you do the following. Turn on the vehicle,before it dies,quickly tap the idle air control valve with a wrench or anything you have. If the engine does not die after you tap the IAC,this means that the IAC is faulty. The IAC is under the plastic plate that is behind the throttle body.
Sep 20, 2008 | 2003 Ford Explorer Sport Trac
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
1,442 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
