Question about Canon PIXMA iP3300 InkJet Photo Printer
Error b200 on canon iP3300 - Canon PIXMA iP3300 InkJet Photo Printer
  • Canon Master
  • 4,737 Answers
There is no specific solution for this error, but most problems related to Error code B200 is fixed after restarting the machine. Please follow the instructions below:
1. Turn off the machine (if power button is not working or seems hanged, unplug the power cord from the printer.)
2. Disconnect both the usb and power cord from the printer.
3. Delete the printer from the Control Panel of the computer. Start > Printers and Faxes > and delete the printer, right-click the printer's name and select delete.
4. Now reconnect the printer on the usb port and plug in the power cord. Power on the printer and reinstall the driver when asked.
If there's no mechanical problem, your problem will be definitely fixed. It could be related to the usb cable, so try with another cable and make sure there's no problem related to transmission/communication between printer and your computer.
If the problem persists, there's no other alternative, the only solution is from the Canon, you can use this link to contact canon. They will assist you what needs to be replaced and what are the steps to be taken before replacing any parts.
Good luck.
Thanks for using FixYa.
Posted on Aug 17, 2010
4 Suggested Answers
SOURCE: CANON PIXMA iP3300
1. turn off printer
2. Hold down resume, dont realase and press power button
3. realase resume button, now press twice resume button but dont realase power button
4. realase all.
5.now press twice again resume button and plug off power cable
6. turn on printer with plugin power cable
7. your printer will reset.
iff not working, you must chek pointing contact in head printer, use some claener with cottonbuds to clear the contact.
may you sukses!!!
Posted on Dec 19, 2008
uxair shah
  • 812 Answers
SOURCE: Error b200 on canon iP3300
Hello thanks for using FixYa
According to Canon's documentation, this is simply listed as a printer error (not very descriptive). It is likely a hardware fault on a board, a physical hardware malfunction.
Turn off the machine, and unplug the power cord of the machine from the power supply. Again connect it and turn on.
If the problem is not resolved,
then best option is to take it back where you purchased it or contact Canon service center about the error code. They will surely solve it.
I hope this solution will also helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Posted on Feb 11, 2011
Flashing lights green and yellow 10x and the printer head is stuck to the right
10 times
B200 VH monitor error.
You will have to replace the printer.
Nov 01, 2013 | Canon PIXMA iP3300 InkJet Photo Printer
Canon Pixma Mp258 B200 Error
My printer is canon mp258 there was an error B200 . how t fix this?
Apr 07, 2011 | Computers & Internet
Feb 11, 2011 | Office Equipment & Supplies
How to reset b200 error?
Well every advice is the same except a little altered (use a warm cotton swab to clean inside machine and on print head channels) but then it says if possible replace print head but honestly this has become a primitive Machine for turning humans into corpses - buy a new one.
Aug 15, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
What is service error B200? The printer doesnt work and it says it has a "service error B200"
According to Canon's documentation, this is simply listed as a printer error (not very descriptive). It is likely a hardware fault on a board; a physical hardware malfunction.
This is Canon's official stance on the error:
Turn off the machine, and unplug the power cord of the machine from the power supply. If the problem is not resolved, contact your Canon service representative.
After looking a bit more, I discovered that the B200 error is a Voltage High Error on the iP4500 chip. Try calling Canon tech support at 1-800-828-4040. If your printer is still under warranty, they will probably send you a new printhead or a new printer.
May 26, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
Service error B200. camcel printing and turn
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Feb 08, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
Please help, my printer canon ip 3300 has message B200
Okay from canon on this one this is a Hardware Failure there is nothing more that can be done unless you have $50 bucks for the main singal proccesor board that sends the signal from the printer to the computer and vice versa. So a unwavering support indeed I gave but the fix can be expensive would recommend just recycle it and buy a new printer for under $50 buck you can get twice the quality from lexmark!! Thanks and this tech deserves his 4 thumbs up and a pat on the back don't you think? Do it today we earn your respect as techs by your ratings and feedback thanks and May god bless your family during this holiday season!!
Nov 24, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
CANON PIXMA iP3300
1. turn off printer
4. realase all.
may you sukses!!!
Jun 21, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Canon PIXMA  iP3300 InkJet Photo Printer Logo
2,646 people viewed this question
old marine
old marine
