Question about Panasonic PT-47WX42 47" Rear Projection Television
Blue Ghosting Images
This is driving me nuts. When there is a sports ticker, or any white throughout the picture, a mirror image of it appears a few inches away in blue. When dialing the red and blue in on Convergence 1 and 2, the blue is noticably off...but it will only adjust left to right, or right to left...not up and down as red does. This is not isolated to any one input...it happens on Cable, DVD, etc. Any help or suggestions would be greatly appreciated.
Thanks!
  • DEVBALLY Jul 14, 2008
    MY PT-47WX42 47INS WAS BOUGHT ABOUT 4YRS AGO. JUST THIS WEEK JULY 10TH, 08 THIS BLUE GHOSTLY IMAGE IS AT THE BOTTOM, I TRIED ALL THE ADJUSTMENT ON THE REMOTE, BUT THE BLUE X IS ONLY MOVING FROM LEFT TO RIGHT NOT UP OR DOWN, PLEASE HELP ME BECAUSE THIS IS FRUSTRATING. DO YOU HAVE AN AFTER HOURS NO. SO I CAN TALK TO SOMEONE.
  • Panasonic Master
  • 8,617 Answers
You need new convergence ICs STK392-110 you need to replace both of them. Heres where you can order replacements and they provide free step by step instructions along with free online instant messaging with a tech so you can do the repair yourself. takes about an hour from start to finish. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Apr 09, 2008
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
Sony KP-53S75 blue convergence problem...
what about settings cool med warm ? did sumone chage those
Jan 18, 2008 | Sony KP-53S75 53" Rear Projection...
I have a Zenith 65 in. TV model #R65W28 serial #271-33220211. The words are blurry and there is a green outline on images in the picture even if i reduce color to black and white. what can i do to fix it?...
It sounds like the convergence drive circuit has gone bad. When that circuit goes the red, blue and green don't line up properly. Have a repair shop check it out. While they are in there have the shop clean the lenses and mirror.
Oct 16, 2009 | Zenith R65W28 65 in. Rear Projection...
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Ghosting of images and buzzing when on mostly white screen X2gen 19" monitor (HP/Vista )
Please bring the unit to an authorized service center as there's an internal electronic part/s of your monitor that is cold soldered / defective. regards
May 27, 2009 | X2Gen MG19VT 19" LCD Monitor
RCA 52'' Projection HDTV Blue ''ghosting''
Go to menu ,now go to setup see if convergence is on menu if not then fuse FL231 is opened 0.6 amps it is located on right side of flyback transfomer the fuse in the middle they look like small square capacitors brown there is 3 in a roll.
Dec 11, 2008 | Televison & Video
Picture Quality
i have a brand new optical block for a 50we610. if you would like to purchase it please e-mail me at copcarp71@hotmail.com
Mar 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Pinkish image ghosting when watching tv
It sounds like you have a bad optical assembly. Depending on labor prices in you area you will likely have a repair bill somewhere between $700 and$1000.
Dec 03, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Convergence images?
The blue picture tube of a projection tv is usually the weakest in ability to focus and in most cases loses its focus ablility before the red and green. Connect a cross-hatch generator to the rf inputs of the unit and check to see which areas are most out of convergence. The corners are usually the worst. HD will always bring out the slightest imperfections. If the unit was totally out of convergence, I would have suggested replacing the convergence IC'S.In my experience with rear projection, your problem is normal wear . You could conceivably improve the picture by adjusting the blue focus on the screen focus block. Scrivitron
Jun 15, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Ghost images
Sounds like a light engine issue to me. Is there anyway you can post a picture of the issue itself?
Mar 28, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Panasonic PT-47WX42 47" Rear Projection Television Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
