Question about General Electric Health & Beauty
GE Senographe 600TS Error 30 Code - General Electric Health & Beauty
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
F3 - error code, wont stop beeping at us.
Hi luvashley28,
F3 error code means that there's an open or shorted oven temperature sensor (RTD). To resolve this you have to Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Error code F3 on my microwave
Hi jlariz,
The F3 error code on GE is about open or shorted oven temperature sensor (RTD. You have to check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Feb 10, 2011 | GE Spacemaker JVM1740 Microwave Oven
I am getting an F0 error code on my GE JTP15. It was working and then just shut-off. Then the error code appeared. I removed power for 30 minutes but the oven control did not reset.
F0
Stuck touch pad Usually means that either the touch pad or the oven control
(also called clock or ERC) is defective and needs to be replaced. If this fault
code cannot be cancelled, replace the oven control (also called clock or ERC),
touch pad, or both.
Jan 30, 2011 | GE JTP15 Electric Single Oven
After a power outage my dishwasher has a "Er" code. I downloaded the manual and it says nothing about that specific code. Please help! "Er" code GE Profile Dishwasher GSD4930X66WW
the er means error. you may have a damaged control from the power outage. try to turn the power off to the unit for 30 min then put it back on. see if it resets it.
Jan 10, 2011 | GE Dishwashers
My G.E. electric oven will beep and shut off after 15 min. or so. The read out says "F-2". What is going on?
This is what GE recommends:
“F— and a number You have a function or letter” flash error code in the display • Press the CLEAR/OFF pad. Allow the oven to cool for
one hour. Put the oven back into operation.
If the function code repeats. • Disconnect all power to the oven for at least 30 seconds and then reconnect power. If the function
error code repeats, call for service.
May 18, 2010 | GE Profile JTP56 Electric Double Oven
F9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Jul 30, 2009 | GE Ovens
GE Profile double Built-In Oven error Code
According to the GE User manual... any F# error code means you have a function error and they suggest you press the CLEAR/OFF pad and allow the oven to cool for one hour. Then put the oven back into operation. If the function code repeats, disconnect all power from th eoven for at least 30 seconds and then reconnect it.. If it still comes back.. call for service.. however it has been my observation that F0 is usually a shorted off key on the keypad. Hope this helps..
Sep 21, 2008 | GE Profile JTP56 Electric Double Oven
Error code
Same thing happened to me. Reset your stove top by flipping your fuse off. The stove top will reset and the error code will go away.
Jan 21, 2008 | GE 30 in.JP950 Electric Cooktop
GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Jun 14, 2007 | GE JTP15 Electric Single Oven
Health & Beauty Logo
53 people viewed this question
Top General Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a General Electric Health and Beauty Expert? Answer questions, earn points and help others
