Question about Frigidaire FTF530FS Front Load Washer
I have a fridgaire ftf530fs1 washing machine, which has been acting up and now it won't even turn on. The problem is similar to some of these posts such as stopping in mid cycle for long periods of time. There wasn't any loud noise's when it was operating it just stop working all of a sudden. The problem not is that it won't do anything, I put ot a wash cycle, close the door the door lock comes on, which indicates that the door is locked and after 5 minutes of waiting still nothing and i can open the door. Any help would be appreciated
    President:
  • 1,430 Answers
This is usually caused by the door switch. These are fairly inexpensive and very easy to replace. First unplug your machine. To check you will need to remove the wire ring that holds the front door seal to the front panel. To do this go to the six o’clock position and you will see the spring of the wire clamp, grab this with a pair of needle nose pliers. Grab it right where it connects to the wire part of the clamp and pull it parallel to the front panel. This will stretch the spring so it can be pulled over the flange. Next carefully peal the door seal off of the flange. You do this with a sort of rolling motion towards the opening in the door. Next remove the screws that hold the door switch in place. Make sure you have one hand supporting the switch assembly while removing the screws. Now pull the whole assembly out the opening. Mark wires if you need to and then remove the wires. Now connect your ohmmeter to the 2 wire on the bottom you should have a reading of 1500 ohms no less than 1400ohms. If it is below the 1400 or more than 1700 replace the switch. To reassemble reverse the order of disassembly. Making sure the little arrow on the door seal lines uo with the mark on the front panel. The spring can be a little trick to get back on but grab in same position as removal and use the other hand to push it over and around the seal. Here is a tutorial to walk you thru http://appliancehelponline.com/washerdoorswitch.html . If it is within this range the main control board is at fault. Not inexpensive. You can enter your model # at www.appliancehelponline.com to view diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on Jun 04, 2010
Ftf530fs1 not filliing not spinning
Hello rickclancyar - Is the washer make a humming noise? If so either the drainage hose or pump is clogged and needs to be clean. If not, then the unit could possibly be experiencing an issue with the control board, wiring failure, faulty pump, timer, or door lock assembly. Consult a professional for an accurate diagnosis and to assist with the repairs.
Feb 11, 2013 | Frigidaire FTF530FS Front Load Washer
I have a kenmore top load high efficiency washer. When i press start it acts like its going to start then it unlocks and won't wash.
My problem is similar to one posted top. My HE Kenmore washer stopped in the middle of the cycle. I repaired the latch lock, thinking that would solve my problem, but now it will start the cycle, and stall at the rinse setting. I have to physically set it to rinse and spin, and sometimes that doesn't even work. Washer will be two years old this August. I have NEVER had a problem with a Sears washer, and I am VERY disappointed in this one. My last two gave me twenty years of service without a repair. Maybe Sears needs to go back to making theirs in the USA.
Apr 27, 2012 | Kenmore Washing Machines
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
Fridgaire FTF530fs3 door lock buzzing and not locking, washer won't start
fit a new door lock as if it doesnt engage it wont allow the machine to start the washing cycle
May 31, 2011 | Frigidaire FTF530FS Front Load Washer
WHERE IS PRESSURE SWITCH LOCATED ON FRIDGAIRE FRONTLOADER ATF7000EGO
they usually located in one of the rear corners near the top either right or left.  has a hose similar to an aquarium air filter hose and a wired plug running to it.
Aug 03, 2010 | Washing Machines
Timer goes thru all cycles to final rinse - to fast
HI. This is a defective timer motor. I would replace this defective timer module asap. Once replaced, this issue will be solved.
Oct 13, 2009 | Frigidaire FTF530FS Front Load Washer
Fridgaire washer is leaking water about 1/2 gallon of water
If you take off the front panel in the VERY back you will see a hose, that hose has seemed to have come disconnected, there is a valve back there that is just slips onto. This will stop your water leak
Feb 08, 2009 | Frigidaire FWS833A Top Load Washer
Frigidaire FTF530FS Front Load Washer Logo
897 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
