Question about Dometic Rooftop RV Air Conditioner
Sounds like A/C compressor goes on but fan doesn't. Most times compressor doesn't even start and I just hear a "clicking" noise when I turn on the A/C from thermostat... Breaker is OK.
  • 674 Answers
The clicking noise is the contactor for the fan and compressor. First take a look at it and make sure the contacts are ok. Turn the power off first. If the contactor is ok then check the capacitor(s). You can check them with a multimeter with the capacitor check function. You can also google "check a capacitor". If that doesn't get it let me know.
Posted on Jun 04, 2010
Mr Kenmore refigerator started making a loud SNAP when the compressor starts and stops a while later. This apart from the fan noise. Relay?
Sounds like the compressor start relay might be the culprit. It generally clicks when the comp turns on or off but you normally do not hear it.
May 04, 2014 | Refrigerators
My vt60 winw cooler doesnt cool , it will show the degrees you want to set it at then few seconds later it goes back to the room temp. of 76...also makes clicking noise to start compressor then again a...
Sounds like the compressor is frozen - sound you hear is the clixon a special sort of resettable fuse on compressors. When they do not start or overheat, it kills the power - when it cools power is restored until it reheats again and .......................
Use ammeter to confirm this - it will show a much greater than normal current draw.
Apr 22, 2014 | VinoTemp VT-60 Wine Cooler
Not freezing or cooling and compressor clicking on and off
From your description it sounds like the start components (start relay, overload and capacitor) are having problems. The clicking you hear is probably the overload kicking out to protect the compressor. It is quite possible that the compressor simply has gotten too hot and after sitting a while will restart when plugged back in. The start components are not generally considered 'user serviceable' parts. When the compressor has cooled to pretty much room temp, plug it in and be listening for those clicks. If you hear them, unplug it because it could eventually damage the compressor. Those components give the compressor an extra jolt to get the compressor running then they drop out of the circuit. If the compressor doesn't start, it creates heat until the overload drops out.
Mar 29, 2014 | Maytag MZD2766GES Side by Side...
Fan won't run / won't cool
It may have a faulty compressor relay or overload, best to change both at the same time. It's either that or a bad compressor.
Jan 06, 2018 | Kenmore 73055 Air Conditioner
GE Profile - model PDS20SBSALSS - constant clicking noise
The clicking is the compressor trying to start. If the compressor is extremely hot, try allowing it to cool. The condenser fan should run even if the compressor is out on overload; that may be the cause of the compressor failure. Check the supply to the fan and replace it if it doesn't run.If the compressor has been overheating for some time, it may be damaged and also need replacing.
Jun 13, 2012 | GE Refrigerators
Ice in icemaker is melting. refigerator is making buzzing sound for several seconds at a time like a faulty switch that is having a hard time making contact.
it sounds like the compressor is the problem.
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
Mar 17, 2011 | Maytag MZD2766GES Side by Side...
Hiya,i have a hotpoint fridge freezer ffa91 and the fridge is no longer getting cold.The compressor seems is hot but cant hear the normal noises coming from the fridge.The digital display shows an arrow...
4. Wait one hour.
try this
Mar 12, 2011 | Hotpoint Refrigerators
FRIDGE AND FREEZER DO NOT COOL. FAN AND COMPRESSOR ARE RUNNING AND AIR IS FLOWING THREW THE VENTS BUT A WIERD NOISE APPEARS EVERY 2-3 MINUTES LIKE THE COMPRESSOR WANTS TO START BUT IS RUNNING STILL. ...
4. Wait one hour.
also are the coils clean?
Feb 26, 2011 | Maytag MBB1956GES Bottom Freezer...
MSD2454GRW. Clicking noise for about 10 seconds then shuts off. Freezer is thawing. Fridge "appears" to be cooling fine...not sure. Help...don't have the $$ to hire someone.
4. Wait one hour.
try this and let me know if it helps.
Feb 22, 2011 | Maytag MSD2454G Side by Side Refrigerator
Left the fridge door slightly open last night and fridge turned off. How do I turn it back on? Freezer is fine
4. Wait one hour.
let me know if this works.
Feb 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
Dometic Rooftop RV Air Conditioner Logo
172 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
