Question about Metrologic Instruments Stratos®H MS2320 (MK2320AD-60B238) Barcode Scanner
I HAVE TWO MS 2322-40D (USB) SCANNERS INTERFACED TO A SAMS MODEL 520 CASH REGISTER. OUT OF BOX ONE WORKED OK NOT PROBLEM THE SECOND ONE I CAN'T GET IT SET UP AS A USB I HAVE ALL THE MANUALS BUT DON'T KNOW WHICH USB BAR CODE TO USE IF YOU CAN GIVE ME PAGE NUMBERS OR BAR CODE NUMBER TO SET THIS SCANNER UP WOULD BE A BIG HELP AS I HAVE TRIED FOR HOURS WITH NO RESULTS. THANKS DAVE C& M BUSINESS MACHINES E-MAIL dave@cmbiz.net
  • 5 Answers
SOURCE: I am trying to locate a download for software that
dsfygvrburt
Posted on Jul 29, 2009
  • 39 Answers
SOURCE: We bought casio pcr-t275 cash register from
Here is a link to the user manual. You will be able to download and save it to your computer, or print it out for future reference.
http://www.casiomobile.com/sa/products/downloads/manuals/PCR-T275_E030624A.pdf
Posted on Oct 24, 2009
SOURCE: bought a new ms 3780 scanner for my tec ma 1650
By being a sloppy blak khunt. It really is that easy.
Posted on Nov 04, 2009
benwabnick
  • 2404 Answers
SOURCE: Is there a cash register that will download
This site has a cash register that can do that:
http://www.cashregisterstore.com/
The Casio TE-2200
and the Casio TE-2400
You save backups and then can be loaded into Excel, this is the closest I have been able to find.
Posted on May 27, 2010
Testimonial: "Thanks! That's still more than we care to pay, but I'm guessing that we are not going to find anything much cheaper."
Electroboy
  • 1669 Answers
SOURCE: delete data from casio cash register, I'm starting
Which model? You don't need to clear everything, just edit existing data
Posted on Oct 06, 2010
I have a alpha 9500ml cash register.Recently I bought a Royal scanner(model:PS700-USB),but the register doesn't respond with it.Now even I switch back to my old scnner, doesn't respond either. Why?
There are many settings for scanners. You must program the register settings AND the scanner. You need the big book of setting bar codes for the scanner to change any settings in the scanner. You usually need a special cable to convert scanner to register pinout. It can be a days work even for a technician. They are the probably the trickiest thing to get working on registers so it might be best to get a dealer to do it if you don't have all of the setup information for connecting that register with that scanner.
May 12, 2017 | Retail Supplies
Casio tk-7000 scanning and PLU programming
You can add a Hand held Scannerbar with your Casio Tk -7000
Hand held bar code scanner(HHS-15) *
Essential functions for the scanning environment such as Not Found PLU(NFP),PLU batch maintenance file,bottle link and Mix & Match functions are available on the TK-7000 model.
You can attach a Voyager Scanner with your TK-7000 model.
How to add in Casio Cash Register:
1. connection to cash register - unscrew and screw back in.
2. connection to scanner, unplug using paper clip into hole and push back in again.
3. rescan default sheet given whe nyou purchased the machine.
4. clean head of scanner.
5. check for cracks on scanner, ie. loss of vacuum.
For MOre Information visit the following sites:
1. Multisoft India
2. Cash Register
3. Bar Code Basic
4. Scanner Model
5. Casio 7000
Regards
Ellin
Oct 07, 2008 | Casio Parts Cash Register PC Desktop
Scanner trouble
It sounds like you have lost the port settings. Most registers have to have the scanner port (socket) set in programming so the register knows which device you are using. I haven't worked with this model but if you need a manual, one of the users has a Royal 9155SC manual here:
http://the-checkout-tech.com/manuals/cashregisters/Royal_Alpha-9155sc_instruction_programming_manual.html
Jul 10, 2013 | Sharp Royal Alpha 9155SC Cash Register
Casio TE 2200 we are trying to input barcodes using the scanner. The Scanner beeps indicating it is reading, but the cash register does not show any acknowledgement that anything has transpired. There...
There is nothing simple about bar code systems unfortunately. Has this scanner been working with that cash register previously? Have you had a training session with the dealer when you bought it? The dealer should have set the system programming in the register and the scanner should have been set for the correct interface parameters. The Cash register settings can be found only in the dealer manual. If you want to check them yourself, the manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
Jun 12, 2011 | Casio Parts Cash Register PC Desktop
I have a royal alpha 9500 ml cash register and also a royal PS700-USB hand held barcode scanner. Everything worked great yesterday getting my barcodes in the cash and stuff, but I unplug it by accident...
the scanner comes with a programming card, just scan the barcode to start programming, then scan the barcode that says usb and then scan the barcode that says end programming, and it will start working again
Aug 11, 2010 | Royal PS700-USB Handheld Barcode Scanner
My samsung till won't talk to my lap top
Windows Vista is the last operating system that you would want to use for legacy hardware -legacy being anything that requires a usb to rs 232c adaptor. Scripts required to make this work would drive you to an abacus. If you need to have a cash register input on a permanent basis I would recommend another operating system, even a real old computer would be easier to interface or you could use the modem output of the Samsung to connect to your laptop in a LAN configuration maybe even with a null modem connection. Vista will drive you crazy with permission denials with cries of cyber-sodomy with an analog interface directly connected. The Samsung 755 has a USB interface but since you don't have the correct input for your laptop it will be far easier to use the cash register an an old (cheap) computer with an RS 232 interface and connect it to your laptop with a wired or wireless LAN configuration. Those USB to DB9 0r DB25 or PS2 adaptors still cannot match the speed parameters that the laptop US Host controller would ever find acceptable. Windows XP or 2000 might be a consideration but Vista is already neurotic enough without interfaces it was not designed to accomodate. I hope this will save you from alot of frustration. respectfully, Steve Medley
Oct 14, 2008 | Casio Parts Cash Register PC Desktop
Metrologic Instruments Stratos®H MS2320 (MK2320AD-60B238) Barcode Scanner Logo
46 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
