Question about Tecnik TKC1426 Electric Kitchen Range
Inner door seal
The inner door glass has come away from the door how should this be re-sealed or do we need a new door.
the cooker is a tecnik range model no TKC110SS
Tkc110ss fan over stopped heating
Posted on Sep 04, 2011
  • Tecnik Master
  • 19,396 Answers
You need to disassemble the door and reassemble with the inner glass well in place, no need for a new door.
If the glass is damaged, call manufacturer and replace glass.
If some other part on the frame has bent, replace the faulty part.
The whole door is expensive.
To replace or refit the door glass you can do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagrams below as an example, I do not have Tecnik diagrams:
, click on picture to enlarge:
Contact Tecnik at the number listed on the owner manual to get diagrams for your model.
Posted on Apr 08, 2009
Tecnic 1426 inside glass of oven door smashed
It can be replaced. I am not familiar with that unit.You can check with the company at this link for more information on the part you need.
Oct 20, 2011 | Tecnik TKC1426 Electric Kitchen Range
I need to replace the seal AND the inner door glass on my Jenn-Air sve47600 range. Haven't found anything online that helps with the glass replacement. Another question: above the oven door (and...
Hello & Welcome to FixYa
The heating issue can be caused by the oven temp sensor that is bad and needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement. You can view this video for glass replacement:
Please get back to me if you have any other questions.
Kevin
May 28, 2011 | Kitchen Ranges
NEED PARKINSON COWAN - OVEN DOOR - GREEN -
Need replacement glass grill door-outer for my Parkinson Cowan Cooker No. OVA60TCGRN
Looked on all available spare parts sites and found it on none of them.
I sooo wish I had not found time to take it apart to clean!
Jun 30, 2010 | Parkinson Cowan SG320 Gas Kitchen Range
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Glass fold over lid exploded on camper wish to
 Hello- You will have to find someone who has oven door glass experience. The doors are layerd ,  3 or 4 glass, 3 or 4 steel. Insulation, screws, and hinges. Local app. parts -outer glass 85$   -2 inner heat glass 75$ ea.  if going to do this, get a new door seal too. Let me know if this info helps -have more if needed. Thanks- ED
Mar 09, 2010 | Frigidaire FEF366 Electric Kitchen Range
Condensation in oven door glass after steam clean
No solution--but I have the EXACT same problem--brand new oven and first time steam cleaned used. Wondering if you got any resolution with this...
Jun 30, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Door glass shattered 3 hours after cooking
Hi there folks It also happened to me, so after ringing rangemaster they said it can happen due to faults in the glass, unfortunately my warranity had run out and they wanted t charge a fortune to repair. so i had a look inside the door my self which is only four screws on the sides to remove the outer skin to find it was a single piece of ordinary toughend glass about 300mm x 300mm fixed in place with six clips like the ones you find one those glass picture frames, i got a new piece from me local glass merchants for less than £10 and it took only mins to fix job done, I hope this help someone and it my save you quite a bit of cash Cheers folks Markbricky
May 31, 2009 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Need to install a new inner seal on the oven door.
the rope type seal merely is friction pressed against the inner glass and the inner panel, no real fasteners other then that,the fact that you got stains inbetweeen glass not neccessarliy a sign ofbad seal, it happpens, in order to replace the gasket, youll need to completly dis-assemble th oven door , as you do you can clean the glass panes as you go
Mar 18, 2009 | Kitchen Ranges
Tecnik TKC1426 Electric Kitchen Range Logo
435 people viewed this question
Top Tecnik Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Tecnik Kitchen Range Expert? Answer questions, earn points and help others
