Question about Memorex (32023244) CD-RW/DVD-ROM Combo Drive
How do I format a CD-RW disc? Are there cetain CD-RW discs for 64-bit OS only?
    Scholar:
  • 128 Answers
Hi! You may click on start - computer and then click on the dvd drive where the CD- RW disc is located and then right click on it then choose format. CD - RW discs are compatible for both 32-64 bit os. Thank you for visiting FixYa.com!
Posted on Jun 05, 2010
Can't detect XP discs in win 64 bit
Hello Joe, 64-bit processing is faster than 32-bit processing because the CPU is handling more bits at once, However, a 64-bit OS requires more resource than a 32-bit OS, A 64-bit OS requires that device drivers operating in kernel mode be a 64-bit drivers, These drivers must be available from the device manufacturer. An application is compiled to process 64-bit or 32-bits. A 64-bit OS can run either 64-bit applications or 32-bit applications, but 64-bit applications are faster also 64-bit applications cannot run on a 32-bit OS.
A 32-bit OS can only address up to 4 GB of memory, More than that might be on the motherboard, but the OS cannot use it, because it does not have enough memory addresses to assign to the physical memory. A 64-bit OS theoretically can address up to 1 terabyte of memory although in practice, most motherboards can only hold from 12 to 16 GB of memory.( A terabyte is roughly 1000 GB or 1 trillion bytes). If you open many applications at the same time and have high computing needs and enough hard drive space and memory, you can benefit from 64-bit computing. To get most out of it, the processor, motherboard, operating system, drivers and applications must all be 64-bit, and you should have installed the maximum amount of memory the motherboard supports.
Mar 16, 2013 | ASUS G74s Cd-rw Dvdrw Super Multi Drive...
I have an ACER Extensa 4220. My OS is Windows 7 Ultimate 64-bit. My problem is: After OS installation the CD/DVD drive is working well--able to read disc in general, able to install softwares or driver via...
Purchase a new (or used) disk-drive that is compatible with your Acer notebook.
Remove the current disk-drive, and set it aside.
Connect this "alternate" disk-drive, and install Windows onto it.
Then, test the CD/DVD drive -- if it still gives problems, then you have a "hardware" problem with the CD/DVD drive, and trying to make any "configuration" changes within Windows will have *NO* effect.
Jun 01, 2011 | Acer 4220-2346 Notebook
Shows unkown disc when i put in a burned dvd-r but it will play a store boughten disc what disc format is compadible with yhis unit
This model DVD player can play the following disc formats:
DVD-Video (Region 1 or relevant region coded store-bought movies)
DVD-R (must be finalised on appropriate recording equipment for compatible playback)
CD-R (for jpeg/mp3 media files)
CD-RW (for audio such as mp3)
music CD (such as store-bought albums)
This player will NOT accept DVD-RW/+RW discs, or Blu-Ray.
I hope this helps you a tiny bit.
Mar 21, 2011 | Durabrand DVD-1002 DVD Player
PIONEER BURNER BURNING BUT DISC EMPTY SAYS DISC FINISHED BURNING BUT WHEN TRYING TO PLAY SAYS DISC EMPTY AND I CANNOT USE IT AGAIN
What OS and disc brand and type are you using? Try a different brand; some disc manufacturers seem to make more "coasters" than others. If you are not using RW(rewritable) discs, make sure to cancel the autoplay "Format disc" option for blank discs in most Windows OS versions. I chose to turn off autoplay.
I hope this helps.
(Yes I made a few coasters. So far I've found that Verbatim DVD +R DL discs are good. CDs are fine with most brands. However, other reviewers say that the plant where the optical discs were made matters.)
Jul 09, 2010 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
PS3 is not reading any discs I insert into the system.
The following types of discs can be played Blue Ray Disc - Playstation No 3 format BD-ROM, BD ROM,BD-R, BD-RE DVD - DVD-ROM, DVD+R/RW, DVD-R/RW, AVCHD, DSD disc CD - Playstation format CD-ROM,CD-DA (Audio CD), CD-R/RW
Also Check the regional code on the disc which should be compatible with the regional codes which can be played by the PS3
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
How do I format a disc (DVD or CD) on Windows XP?
You only format a CD/RW or a DVD/RW, which are re-writeable.
Regular discs do not need to be formatted (CD-R or DVD+R, DVD-R, DVD+R DL, etc.).
To format the DVD/RW idisc, use the "burner" software ( Sonic?, Nero?) and choose [Tools] [Erase Disc] (erase is the same as format)
Oct 13, 2009 | Microsoft Windows XP Professional for PC
Get windows vista home premium
You can run a 32 bit technology OS on a 64 bit technology platform.
It will run pretty fast.
You just can't run a 64 bit technology OS on a 32 bit technology platform, though the 64 bit OS is recommended on a 64 bit platform.
Love your brother, he did you no wrong.
Mar 30, 2009 | Dell 24x CD±RW/DVD Serial ATA Internal...
DVD RW problem
Please use nero version nero 7.0 or you can get new version nero 8.0 from www.soft82.com/download/Windows/Nero
It will solve your problem its beter if you get cracked version of nero 7.0 from bit torent or bearshare
Regards
Balisonu79
Feb 14, 2008 | Computers & Internet
Please help! DVD-RW problem's really pissin' me off!
Normally one sees such message when trying to write to a cd/you could uninstall/reinstall the driver for the dvd-rw
Feb 13, 2008 | HP (355282-001) DVD+RW Burner
Memorex (32023244) CD-RW/DVD-ROM Combo Drive Logo
134 people viewed this question
Top Memorex Computers & Internet Experts
Piyal Perera
Piyal Perera
Jax Planet
Jax Planet
Jose Velazquez
Jose Velazquez
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
