Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
My first proheat lasted four years so I bought a new one. After I used my Pro Heat for only the fourth time my first issue occured, the gear on the pump that runs the brushes came off, so I had the one from my old proheat, I just changed the gear spindle that is screwed to the pump and fixed that problem but now it will not pump water. That is why I bought a new proheat, I could not get the old one to pump even after a new pump and made sure all lines were not cloged.
    Problem Solver:
  • 11 Answers
Is your new machine a 2X or like the old style proheat?
Posted on Jun 04, 2010
  • iwin12 Jun 04, 2010
My new bissell proheat is making noise! any advise on what to look for?
Hi Madelyn! Sorry to hear about the rattling sound. This is most unusual. You may want to have one of our Authorized Service Centers inspect your machine.
Here's a quick link to locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Mar 20, 2013 | Bissell 1699 ProHeat Clear View Upright...
Bissell pro heat wont spray
Not to be negative but I fixed one Bissell, and it worked for a while then it broke again. My Daughter bought one and it broke on her after using it only 3 times.
buy the rug Doctor or some other brand . That is my advise. Otherwise you will have to keep fixing that one.
Oct 22, 2017 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have an upright bissell pro heat self propelled. I have had it for years and it has always worked wonderfully. Last time I was using it water started going everywhere. The self propel part is only...
If the top portion of the upright section is loose, there is a connector between the two parts that is also loose. No need to take it apart however beyond removing the black lower hose holder.
To remove the lower hose holder, just push in firmly on the tab that is the same color as the upright casing until you can pop the lower holder upward and off of the machine. Beneath the holder are four screw holes where you can tighten the upper and lower assemblies back together. This will reconnect the two connectors internally and take care of any power issue to the base.
Apr 02, 2011 | Bissell 1699 ProHeat Clear View Upright...
How do I change the belt on my Bissell Pro Heat
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
twerw
Apr 16, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Carpets soaking wet
turn dial in front on the water tank to floor not tools and thats should do it...go to bissell.com to read and print manual so you can double check everything
Feb 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1699 ProHeat Cleaner
If it is completely dead, then either a bad cord, switch, motor, or a broken connection, it will have to be taken apart to find the problem.
Aug 30, 2008 | Bissell 1699 ProHeat Clear View Upright...
Pro heat pump
That is correct; the new pump has a metal pulley, which is more durable.
J
Jun 07, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
47 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
