Question about Hotpoint VBSR3100GWW Top Load Washer
The washer water leval dose not work
The washer dose not recognies the water leval it will over flow and will not agitate.. the washer is a 18 year old hotpoint heavy duty.. ty
  • 159 Answers
There is a thin tube that plugs to the side of the tub then runs up to whats called a water level pressure switch.the tube may be old & cracked or has come off at one end.Alternitavely the inlet valve may be faulty.this can easily be tested by letting the machine fill & pull the plug out of the wall,if the water stops coming in then the valve is ok.
Posted on Jun 04, 2010
    President:
  • 1,430 Answers
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. There is a video at http://appliancehelponline.com/toppressureswitchvideo.html this will walk you thru the inspection and replacement of this part. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Buying a new washer - what type gets the clothes the CLEANEST - one with an agitator or no agitator
Whirlpool Duet, Front Loader. Large capacity, low water usage. Average electricity cost $18 per YEAR!
We see a number of washer problems, and lots with agitators and clutches. They use far too much water.
Mar 27, 2016 | Washing Machines
Agitator dose dose not agitate
Check your dog agits they are inside of the agitator, remove the cap with a flathead screwdriver then you should see a 7/16 bolt remove in order to pull out the agitator.
May 06, 2014 | Kenmore 24032\24036 Top Load Washer
Pump 14292 for power washer
Water should come out the tip even if the mechine is not running if the water is on. So there for now water is flowing through the punp at all witch mean you have a problem with a restriction of water flowing through the pump . What dose it do with the engine running dose the blow out valve open and water come out there . Dose the pump spin .Is there water in the pump oil .How often do you use the mechine and is it kepted in the cold over the winter with out winterizeing it Give more information mabey i can help you but it dosn't sound to good now
May 28, 2012 | Briggs & Stratton Garden
Washing machine dose not aditate anymore
pull up the agitator, you may need to get a belt wrap it underneath and yank it up, please be careful that it doesnt hit your eye and under the agitator is a coupler or bell that needs to be replaced, it is stripped, loosen the bolt and replace
Mar 07, 2010 | Frigidaire FEX831CS Top Load Stacked...
Machine fills up with water then when its suppose to agitate it just stops working will turn timer & push knob in & out & reset then it will work
How long do you let it sit after the water fills up, somtimes the timer will take a little extra time to get to the point that starts the agitation cycle.
When it dose this, without pulling the knob out, turn the disk on the timer clockwise 1 click and see if it starts up agitating, if it dose dont worry about it it is normal
Nov 09, 2009 | Maytag PAV2300 Top Load Washer
My washer wont stop filling with water it will run over into floor it will agitate but water keeps running . it is a whirlpoot top loading.
you nead to check the plastic hose from the water leval switch to thbe outer tub.if line is good than you have a bad water leval switch.
Oct 29, 2009 | Whirlpool LSR5132PQ Top Load Washer
Kenmore 90 Series fills with water but would not agitate or spin
You have a problem with the motor coupling. Top-load washers use what's called a direct-drive system, meaning it does not use a belt but what's called a "motor coupling". I probably replace 5 a week because these little guys break because of 2 reasons that i've found.
1) The break mechanism is too dry and causing the basket to stop at a holt, which puts a lot of strain on the coupler.
2) They break because of over-loading. I don't think you're over-loading though because it was find for 5 straight years.
Good luck to you. The repair is kind of hard to do on your own for the first time, so I would call an authorized technician. It will run you anywhere between $90 to $120 at most.
Best of luck!
Jul 14, 2009 | Kenmore 22422 Top Load Washer
My Kenmore 70 series is 18 years old. It will not
Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
Jul 06, 2009 | Washing Machines
Water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Jun 07, 2009 | GE WDSR2080D Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Hotpoint VBSR3100GWW Top Load Washer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
